Power button package
21 hours ago, londoner13 said:
Works with DSM 6.1.3-15152 Update 1 on AMD Laptop.
Also could be able to create something that can be used to turn off the LCD?
Thanks
How did  you manage installing DSM 6.1.3-15152 Update 1 on a AMD laptop?
I didn't have to change anything at all I used the latest loader and installed it and it just worked. I have not had any problems whatsoever, even after improper shutdown due to low battery etc. It is a pretty old laptop though with a single core CPU. I am mainly using it as a Torrent downloader and NAS with Sickrage installed on docker. Haven't run into any performance issues, everything works beautifully.
On another note I would highly recommend running Sickrage or any other applications on docker. It makes the task of moving your existing setup to a new machine pretty seamless in case of a system failure.
  • 1 month later...
  • 4 weeks later...
On ‎15‎.‎09‎.‎2017 at 8:28 PM, abced said:
I see, that "braswell" architecture is not added in INFO file that's why we can't install. Can you make it work maybe (for DS916+ image)?
Sorry haven't been around for a while - and as I'm running DSM on ESXi not using powerbutton anymore myself.
I added braswell to INFO:
powerbutton_6.1-0005.spk
  • Thanks 2
On 28.11.2017 at 10:24 AM, ravest said:
Thanks for the app, i've been using it for a while now.
After i updated to 6.1.4, it seems the power button is not responding any more.
Do you have any suggestions to make it run again ?
Did you try to reinstall the package? For me it is working with 6.1.4. I'm on a Dell Poweredge T30 with Juns 1.02b for DS916+.
  • 1 month later...
I am pretty new to XPEnoogy and still feeling my way threw, I just found your add-on and and I want to say great job and thank you so much for this much needed app. I can confirm this works on my Supermicro X10SLL-F motherboard with a Intel Xeon E3-1231 v3 CPU....
  • 4 weeks later...
Works on baremetal (AMD Asrock FM2A85X-ITX) DSM 6.0.2-8451 Update 11 :)
Thank You wer! :D
P.S. After a power button shutdown I have a small problem with waking up NAS using WOL (from my Synology router) but that s nothing... I found a workaround.
