gizmomelb Posted April 14, 2017 #1 Posted April 14, 2017 Hi all, I've had my HP N40L microserver successfully running Xpenology / DSM 5.9 (whatever the last version was) for the past two years. This weekend I decided to open the case up and install a USB 3.0 PCI-E card, specifically one based on the NEC UPD720200 chipset (this one here - http://www.msy.com.au/peripherals/17456 ... -card.html ) Now everything is all back together but my system doesn't boot - it goes through all of the BIOS startup, detects all the drives etc. but when it finally gets to to O/S boot section I just see a black screen with a white cursor. I had a look in the BIOS and noticed I Cannot see a BOOT FROM USB option anywhere - could that be it? (I've left the original USB stick in the internal slot for the past 2 years and it's still there). Or maybe the system is confused with the USB ports because there PCI-E card has two new USB 3.0 ports on it? Any ideas / help would be most appreciated so I can get my system running again. Thank you. Quote
gizmomelb Posted April 15, 2017 Author #2 Posted April 15, 2017 ok following up my own post - the BIOS had reset (must install a new battery) and disabled the 4th and 5th SATA ports as well as the BIOS Southbridge 2 chipset options. Configured those again and still did not work. Unplugged USB stick (it's one that lights up when inserted and active.. so you know it's working) and reconnected it - NAS now boots fine. So guess maybe the USB wasn't quite connected properly? Issue resolved and the HP N40L now has two USB 3.0 ports on the rear and is currently copying files from a USB 3.0 HDD at 57 MB/s. Awesome! message closed. Quote
