c_c_b Posted June 10 #1 Posted June 10 I need help recovering a crashed SHR pool. Following a power outage and a subsequent drive issue, my pool is crashed, and the DSM web interface is inaccessible when all drives are installed. I still have SSH access. System Specifications DSM Version: 7.1.1-42962 Update 4 RAID Type: SHR with 1-drive fault tolerance Drive Configuration: 12 drives total Sequence of Events 1. A brief power outage caused one drive to show as corrupted. 2. I used Storage Manager to deactivate the corrupted drive and then rebooted the NAS. Inteded to add the drive back as I normally do in this situation. 3. I had to step away for the weekend. Upon my return, the pool was reported as "crashed." 4. All Docker services relying on the volume stopped, and the shared folders on it were no longer visible in File Station. Current Status & Symptoms • Web Interface (DSM): I get a "ERR_CONNECTION_FAILED" error when trying to access the web UI with all drives connected. • SSH Access: I can still connect to the NAS via SSH without any issues. • Temporary Workaround: If I physically disconnect one of the drives from the storage pool, the DSM web interface loads successfully. However, the volume is obviously not present. Re-connecting the drive causes the web UI to become inaccessible again. Goal My primary goal is to recover the volume. If that's not possible, I need to copy the data from the crashed volume to a safe location. I've gathered outputs from several commands via SSH based on other support threads but am concerned about running any commands that could make the situation worse. I'm looking for expert guidance on the safest way to proceed with recovery. Any and all advice is welcome. Quote ash-4.4# cat /proc/mdstat Personalities : [raid1] [raid6] [raid5] [raid4] [raidF1] md4 : active raid5 sdi5[3] sdam5[12] sdao5[13] sdan5[11] sdaq5[10](E) sdh5[9] sdap5[7] sdk5[6] sdg5[5] sdl5[4] sdj5[2] 107377588736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [12/11] [UUUUUUU_EUUU] md3 : active raid1 sde3[0] 966038208 blocks super 1.2 [1/1] [U] md2 : active raid1 sdb3[0] 477662208 blocks super 1.2 [1/1] [U] md1 : active raid1 sdb2[5] sde2[7] 2097088 blocks [16/2] [_____U_U________] md0 : active raid1 sdb1[5] sde1[7] 2490176 blocks [16/2] [_____U_U________] unused devices: <none> Quote ash-4.4# ls /dev/sd* /dev/sdam /dev/sdan1 /dev/sdao2 /dev/sdap5 /dev/sdar /dev/sdb1 /dev/sde2 /dev/sdg5 /dev/sdi /dev/sdj1 /dev/sdk2 /dev/sdl5 /dev/sdam1 /dev/sdan2 /dev/sdao5 /dev/sdaq /dev/sdar1 /dev/sdb2 /dev/sde3 /dev/sdh /dev/sdi1 /dev/sdj2 /dev/sdk5 /dev/sdam2 /dev/sdan5 /dev/sdap /dev/sdaq1 /dev/sdar2 /dev/sdb3 /dev/sdg /dev/sdh1 /dev/sdi2 /dev/sdj5 /dev/sdl /dev/sdam5 /dev/sdao /dev/sdap1 /dev/sdaq2 /dev/sdar5 /dev/sde /dev/sdg1 /dev/sdh2 /dev/sdi5 /dev/sdk /dev/sdl1 /dev/sdan /dev/sdao1 /dev/sdap2 /dev/sdaq5 /dev/sdb /dev/sde1 /dev/sdg2 /dev/sdh5 /dev/sdj /dev/sdk1 /dev/sdl2 Quote ash-4.4# ls /dev/md* /dev/md0 /dev/md1 /dev/md2 /dev/md3 /dev/md4 Quote ash-4.4# ls /dev/vg* /dev/vga_arbiter /dev/vg1: syno_vg_reserved_area volume_1 /dev/vg1001: lv /dev/vg2: syno_vg_reserved_area volume_3 Quote ash-4.4# mdadm --detail /dev/md4 /dev/md4: Version : 1.2 Creation Time : Tue Oct 29 14:24:31 2019 Raid Level : raid5 Array Size : 107377588736 (102403.25 GiB 109954.65 GB) Used Dev Size : 9761598976 (9309.39 GiB 9995.88 GB) Raid Devices : 12 Total Devices : 11 Persistence : Superblock is persistent Update Time : Tue Jun 10 10:34:14 2025 State : clean Active Devices : 11 Working Devices : 11 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : DiskStation:4 UUID : 4fa9acaa:eb658006:d157b35e:2e2cbe20 Events : 704088 Number Major Minor RaidDevice State 3 8 133 0 active sync /dev/sdi5 2 8 149 1 active sync /dev/sdj5 4 8 181 2 active sync /dev/sdl5 5 8 101 3 active sync /dev/sdg5 6 8 165 4 active sync /dev/sdk5 7 66 149 5 active sync /dev/sdap5 9 8 117 6 active sync /dev/sdh5 - 0 0 7 removed 10 66 165 8 faulty active sync /dev/sdaq5 11 66 117 9 active sync /dev/sdan5 13 66 133 10 active sync /dev/sdao5 12 66 101 11 active sync /dev/sdam5 Quote ash-4.4# mdadm --examine /dev/sdaq5 /dev/sdaq5: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 4fa9acaa:eb658006:d157b35e:2e2cbe20 Name : DiskStation:4 Creation Time : Tue Oct 29 14:24:31 2019 Raid Level : raid5 Raid Devices : 12 Avail Dev Size : 19523198016 (9309.39 GiB 9995.88 GB) Array Size : 107377588736 (102403.25 GiB 109954.65 GB) Used Dev Size : 19523197952 (9309.39 GiB 9995.88 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=64 sectors State : clean Device UUID : 424c4da1:84e41825:86840f88:c251e661 Update Time : Tue Jun 10 10:34:14 2025 Checksum : 81f080a9 - correct Events : 704088 Layout : left-symmetric Chunk Size : 64K Device Role : Active device 8 Array State : AAAAAAA.AAAA ('A' == active, '.' == missing, 'R' == replacing) Quote ash-4.4# cat /etc/fstab none /proc proc defaults 0 0 /dev/root / ext4 defaults 1 1 /dev/mapper/cachedev_0 /volume2 btrfs auto_reclaim_space,ssd,synoacl,noatime,nodev 0 0 /dev/mapper/cachedev_1 /volume3 btrfs auto_reclaim_space,ssd,synoacl,relatime,nodev 0 0 /dev/mapper/cachedev_2 /volume1 btrfs auto_reclaim_space,ssd,synoacl,relatime,nodev 0 0 Quote ash-4.4# lvdisplay -v Using logical volume(s) on command line. --- Logical volume --- LV Path /dev/vg1001/lv LV Name lv VG Name vg1001 LV UUID Bni54N-SbQB-Il1f-9RR5-LH1f-Uo2f-er32wI LV Write Access read/write LV Creation host, time , LV Status available # open 1 LV Size 100.00 TiB Current LE 26215231 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 2816 Block device 249:0 --- Logical volume --- LV Path /dev/vg2/syno_vg_reserved_area LV Name syno_vg_reserved_area VG Name vg2 LV UUID IZQ4el-aJLv-s1ui-ZA3Q-sb8c-ZFRw-jkyRPz LV Write Access read/write LV Creation host, time , LV Status available # open 0 LV Size 12.00 MiB Current LE 3 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:3 --- Logical volume --- LV Path /dev/vg2/volume_3 LV Name volume_3 VG Name vg2 LV UUID KNynWL-riAu-eTeA-ZCXG-PWnS-W0qy-LbO30y LV Write Access read/write LV Creation host, time , LV Status available # open 1 LV Size 921.00 GiB Current LE 235776 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:4 --- Logical volume --- LV Path /dev/vg1/syno_vg_reserved_area LV Name syno_vg_reserved_area VG Name vg1 LV UUID jPRfAb-MsNt-4XpF-Il27-5kPm-BE4G-L5hZA8 LV Write Access read/write LV Creation host, time , LV Status available # open 0 LV Size 12.00 MiB Current LE 3 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:1 --- Logical volume --- LV Path /dev/vg1/volume_1 LV Name volume_1 VG Name vg1 LV UUID 2OfdeC-6fKn-cGxM-ydAm-Bb8N-vW6c-2HDyH2 LV Write Access read/write LV Creation host, time , LV Status available # open 1 LV Size 455.00 GiB Current LE 116480 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:2 Quote ash-4.4# vgdisplay -v Using volume group(s) on command line. --- Volume group --- VG Name vg1001 System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 16 VG Access read/write VG Status resizable MAX LV 0 Cur LV 1 Open LV 1 Max PV 0 Cur PV 1 Act PV 1 VG Size 100.00 TiB PE Size 4.00 MiB Total PE 26215231 Alloc PE / Size 26215231 / 100.00 TiB Free PE / Size 0 / 0 VG UUID vcCPuH-fiPF-9s0B-NTOY-vVyd-OdfI-fvEhUE --- Logical volume --- LV Path /dev/vg1001/lv LV Name lv VG Name vg1001 LV UUID Bni54N-SbQB-Il1f-9RR5-LH1f-Uo2f-er32wI LV Write Access read/write LV Creation host, time , LV Status available # open 1 LV Size 100.00 TiB Current LE 26215231 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 2816 Block device 249:0 --- Physical volumes --- PV Name /dev/md4 PV UUID G60w7O-Mcxn-olQ8-9bs4-0B02-F51E-19nhOW PV Status allocatable Total PE / Free PE 26215231 / 0 --- Volume group --- VG Name vg2 System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 3 VG Access read/write VG Status resizable MAX LV 0 Cur LV 2 Open LV 1 Max PV 0 Cur PV 1 Act PV 1 VG Size 921.29 GiB PE Size 4.00 MiB Total PE 235849 Alloc PE / Size 235779 / 921.01 GiB Free PE / Size 70 / 280.00 MiB VG UUID 81uM1G-U8Kd-cKyk-2rF1-y1NM-EXq3-G6W2HH --- Logical volume --- LV Path /dev/vg2/syno_vg_reserved_area LV Name syno_vg_reserved_area VG Name vg2 LV UUID IZQ4el-aJLv-s1ui-ZA3Q-sb8c-ZFRw-jkyRPz LV Write Access read/write LV Creation host, time , LV Status available # open 0 LV Size 12.00 MiB Current LE 3 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:3 --- Logical volume --- LV Path /dev/vg2/volume_3 LV Name volume_3 VG Name vg2 LV UUID KNynWL-riAu-eTeA-ZCXG-PWnS-W0qy-LbO30y LV Write Access read/write LV Creation host, time , LV Status available # open 1 LV Size 921.00 GiB Current LE 235776 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:4 --- Physical volumes --- PV Name /dev/md3 PV UUID R7PKCN-80zW-Yrjl-KVyi-Goi4-OV87-p0BeGW PV Status allocatable Total PE / Free PE 235849 / 70 --- Volume group --- VG Name vg1 System ID Format lvm2 Metadata Areas 1 Metadata Sequence No 3 VG Access read/write VG Status resizable MAX LV 0 Cur LV 2 Open LV 1 Max PV 0 Cur PV 1 Act PV 1 VG Size 455.53 GiB PE Size 4.00 MiB Total PE 116616 Alloc PE / Size 116483 / 455.01 GiB Free PE / Size 133 / 532.00 MiB VG UUID z3FQa0-1NY0-7cGh-1XCE-Z67V-WZFO-c3RmOF --- Logical volume --- LV Path /dev/vg1/syno_vg_reserved_area LV Name syno_vg_reserved_area VG Name vg1 LV UUID jPRfAb-MsNt-4XpF-Il27-5kPm-BE4G-L5hZA8 LV Write Access read/write LV Creation host, time , LV Status available # open 0 LV Size 12.00 MiB Current LE 3 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:1 --- Logical volume --- LV Path /dev/vg1/volume_1 LV Name volume_1 VG Name vg1 LV UUID 2OfdeC-6fKn-cGxM-ydAm-Bb8N-vW6c-2HDyH2 LV Write Access read/write LV Creation host, time , LV Status available # open 1 LV Size 455.00 GiB Current LE 116480 Segments 1 Allocation inherit Read ahead sectors auto - currently set to 384 Block device 249:2 --- Physical volumes --- PV Name /dev/md2 PV UUID zOTbqz-shoH-jnrh-Fwcw-oxCV-PWLe-VNLtdi PV Status allocatable Total PE / Free PE 116616 / 133 Quote ash-4.4# lvm pvscan PV /dev/md4 VG vg1001 lvm2 [100.00 TiB / 0 free] PV /dev/md3 VG vg2 lvm2 [921.29 GiB / 280.00 MiB free] PV /dev/md2 VG vg1 lvm2 [455.53 GiB / 532.00 MiB free] Total: 3 [101.35 TiB] / in use: 3 [101.35 TiB] / in no VG: 0 [0 ] 1 Quote
Trabalhador Anonimo Posted Wednesday at 12:55 PM #2 Posted Wednesday at 12:55 PM (edited) Download M-shell here, record in a new USB drive, boot from it and use function to mount and recover your data. Look here at post #1788 to know how it works. Edited Wednesday at 01:01 PM by Trabalhador Anonimo Include more information Quote
c_c_b Posted Wednesday at 02:00 PM Author #3 Posted Wednesday at 02:00 PM 1 hour ago, Trabalhador Anonimo said: Download M-shell here, record in a new USB drive, boot from it and use function to mount and recover your data. Look here at post #1788 to know how it works. Thank you very much! I will give that a look and try later today. Do I risk losing any data with this approach? Curious if you have run into this same issue before with SHR-1 disk fault tolerance? Quote
c_c_b Posted Wednesday at 02:52 PM Author #4 Posted Wednesday at 02:52 PM Adding a little more information - Note the last drive (sdar5) is the one that was deactivated a couple days before the crash. From what I am gathering in various posts (some pretty dated now) this is a good sign that my data is in tact? Quote ash-4.4# mdadm --examine /dev/sd[ghijkl]5 /dev/sdam5 /dev/sdan5 /dev/sdao5 /dev/sdap5 /dev/sdaq5 /dev/sdar5 | egrep 'Event|/dev/sd' /dev/sdg5: Events : 704097 /dev/sdh5: Events : 704097 /dev/sdi5: Events : 704097 /dev/sdj5: Events : 704097 /dev/sdk5: Events : 704097 /dev/sdl5: Events : 704097 /dev/sdam5: Events : 704097 /dev/sdan5: Events : 704097 /dev/sdao5: Events : 704097 /dev/sdap5: Events : 704097 /dev/sdaq5: Events : 704097 /dev/sdar5: Events : 703612 Quote
c_c_b Posted Wednesday at 03:51 PM Author #5 Posted Wednesday at 03:51 PM @Trabalhador Anonimo - I created the bootable USB and added the menu entry for recovery, unfortunately it doesn't seem to work out of the box and I'm not sure where I would go from here? As far as I can tell the disk is fine, its just reported in a failed state which is preventing things from coming up as expected. Quote
Peter Suh Posted Thursday at 03:30 AM #6 Posted Thursday at 03:30 AM Here is Perplexity's answer. Please refer to it. Quote
c_c_b Posted Thursday at 03:44 AM Author #7 Posted Thursday at 03:44 AM 11 minutes ago, Peter Suh said: Here is Perplexity's answer. Please refer to it. Thank you @Peter Suh for taking the time to review and give it a whirl in perplexity. Unfortunately that doesnt get me anywhere as I cant access the web GUI, and syno_poweroff_task does not appear to exist in DSM 7? Quote
Peter Suh Posted Thursday at 04:02 AM #8 Posted Thursday at 04:02 AM 17 minutes ago, c_c_b said: Thank you @Peter Suh for taking the time to review and give it a whirl in perplexity. Unfortunately that doesnt get me anywhere as I cant access the web GUI, and syno_poweroff_task does not appear to exist in DSM 7? These commands have been verified to actually work. Quote
c_c_b Posted Thursday at 04:10 AM Author #9 Posted Thursday at 04:10 AM 6 minutes ago, Peter Suh said: These commands have been verified to actually work. Thank you again - I did actaully come across a post for DSM 7 with these commands and tried them, which gave me mixed unsuccesful results, either the command hangs indefinetly, or it would simply not unmount and would still show active in lvscan. Quote
djvas335 Posted Thursday at 04:17 AM #10 Posted Thursday at 04:17 AM I would suggest booting the server in Gparted Live and see there if you can mount the raid. 1 Quote
Trabalhador Anonimo Posted Thursday at 12:54 PM #11 Posted Thursday at 12:54 PM 22 hours ago, c_c_b said: Thank you very much! I will give that a look and try later today. Do I risk losing any data with this approach? Curious if you have run into this same issue before with SHR-1 disk fault tolerance? 1- don´t know, but Synology made a lot of improvements to avois data loss; 2- The disks in problem, are my eldest ones and maybe their live is about to end. I got new ones and I´ll replace next weekend. Quote
Trabalhador Anonimo Posted Thursday at 12:55 PM #12 Posted Thursday at 12:55 PM 8 hours ago, djvas335 said: I would suggest booting the server in Gparted Live and see there if you can mount the raid. Or you can try to create a VM and migrade the disks, or reinstall DSM. Quote
c_c_b Posted Thursday at 01:26 PM Author #13 Posted Thursday at 01:26 PM 9 hours ago, djvas335 said: I would suggest booting the server in Gparted Live and see there if you can mount the raid. Trying this wont put anything at risk of data loss? Quote
c_c_b Posted Thursday at 04:01 PM Author #14 Posted Thursday at 04:01 PM @Peter Suh - I have tried your suggestions to no success. From what I can tell from the synology assistant, when I have all the drives attached the server goes into a "checking quota" status, upon checking top i see a kworker sucking up 100% CPU. I suspect this it when GUI is unresponsive and why most commands wont finish, and SSH eventually stops connecting. I've looked around but am not coming across anyting to kill that kworker or whatever launches the quota check. I tried your new m-shell recovery tool as well but it gave me whats pictured below. Any chance you have some guidance from here? I know the drive has not failed, its just reporting that way, and it seems to me that im just fighting some incorrect status somewhere that needs to be reset to get things going again? Quote
djvas335 Posted Thursday at 06:41 PM #15 Posted Thursday at 06:41 PM It will not as long as you know what you are doing, it will be actually possible to fix and mount if damage is not severe and copy your data out. I had one issue with a server and copied the data out this way 5 hours ago, c_c_b said: Trying this wont put anything at risk of data loss? Quote
c_c_b Posted Thursday at 08:47 PM Author #16 Posted Thursday at 08:47 PM 2 hours ago, djvas335 said: It will not as long as you know what you are doing, it will be actually possible to fix and mount if damage is not severe and copy your data out. I had one issue with a server and copied the data out this way That is great to hear. I have found this to be a bit more tricky than a simple drive mount given it's 12 drives and its using Synology SHR-1...Can you provide me with the steps needed using gparted live? Quote
c_c_b Posted Thursday at 11:43 PM Author #17 Posted Thursday at 11:43 PM I was able to make slightly more progress today, I think? I discovered that if I boot my server with one of the remaining 11 drives (Pool is 12 drives, 1 was deactivated) disconnected to get the GUI working I can then connect the 11th drive well running and storage manger picks it up no problem. I'm also presented with an online assemble option (Seems good?). I have tried that however it does not appear anything is happening...system resources are less than 5% across the board, I dont see anything obvious running, and the status has been "Assembling...Waiting" for hours. It did however make volume 2 show up again under the storage pool in storage manager, but volume 2 is not mounted (verified in /etc/fstab). Anyone who has done an online assemble who can speak to what status should be seen and how long it normally takes? Am I on the right track for recovery? Quote
Peter Suh Posted Friday at 03:38 AM #18 Posted Friday at 03:38 AM (edited) 3 hours ago, c_c_b said: Anyone who has done an online assemble who can speak to what status should be seen and how long it normally takes? Am I on the right track for recovery? You already know how to find out how long it takes to rebuild RAID. cat /proc/mdstat Edited Friday at 03:38 AM by Peter Suh Quote
c_c_b Posted Friday at 03:41 AM Author #19 Posted Friday at 03:41 AM 2 minutes ago, Peter Suh said: You already know how to find out how long it takes to rebuild RAID. cat /proc/mdstat @Peter Suh - Thats part of why I dont think anything is happening as it shows nothing there: Quote cat /proc/mdstat Personalities : [raid1] [raid6] [raid5] [raid4] [raidF1] md4 : active raid5 sdi5[3] sdam5[12] sdao5[13] sdan5[11] sdaq5[10](E) sdh5[9] sdap5[7] sdk5[6] sdg5[5] sdl5[4] sdj5[2] 107377588736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [12/11] [UUUUUUU_EUUU] md3 : active raid1 sde3[0] 966038208 blocks super 1.2 [1/1] [U] md2 : active raid1 sdb3[0] 477662208 blocks super 1.2 [1/1] [U] md1 : active raid1 sdb2[5] sde2[7] 2097088 blocks [16/2] [_____U_U________] md0 : active raid1 sdb1[5] sde1[7] 2490176 blocks [16/2] [_____U_U________] unused devices: <none> Quote
Peter Suh Posted Friday at 04:56 AM #20 Posted Friday at 04:56 AM 1 hour ago, c_c_b said: @Peter Suh - Thats part of why I dont think anything is happening as it shows nothing there: I have 12 disks in VM and use 11 disks with same SHR configuration as you and use 1 as HOT SPARE. (Please ignore my system partition error, it is a separate issue.) I disabled 1 disk that had error and HOT SPARE started automatically. It seems difficult to cause error during HOT SPARE auto-recovery like you. The disk that had error during HOT SPARE auto-recovery, marked as E instead of U, seems to be stuck in the middle. [UUUUUUU_EUUU] It seems that HOT SPARE auto-recovery problem is very rare. SHR provides data protection with only 1 disk. The disk that had error was already removed and I expected this HOT SPARE disk to auto-recover, but it seems that it did not work as expected. In that case, shouldn't HOT SPARE disk be used for initialization and adding to recovery? It seems that this disk with error E status is preventing even reassembly. Since the above is a very rare case, I think the know-how is with Synology's technical team. Quote
Peter Suh Posted Friday at 05:00 AM #21 Posted Friday at 05:00 AM 1. Disable drives 43 and 44 and shut down the system. 2. Physically remove drive 43. 3. Reboot and use the auto-enabled drive 44 for recovery. IMHO, shouldn't the above process be correct? Quote
Peter Suh Posted Friday at 09:38 AM #22 Posted Friday at 09:38 AM md4 : active raid5 sdi5[3] sdam5[12] sdao5[13] sdan5[11] sdaq5[10](E) sdh5[9] sdap5[7] sdk5[6] sdg5[5] sdl5[4] sdj5[2] 107377588736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [12/11] [UUUUUUU_EUUU] However, it seems that the status of md4 was analyzed incorrectly. md4 already has 2 disks lost. [_E] As mentioned above, SHR only allows recovery of 1 disk. Data cannot be recovered when 2 disks are lost. The HOT SPARE I mentioned is also a result of incorrect analysis and should be ignored. Quote
Peter Suh Posted Friday at 09:47 AM #23 Posted Friday at 09:47 AM I asked A.I again to check the status of SHR again. I think the opinion I received again is correct. Quote
djvas335 Posted Friday at 05:06 PM #24 Posted Friday at 05:06 PM Unfortunately there is no easy way to recover from this, at this time I would have stopped trying to recover the raid in DSM and just imaged each drive and try to reassemble the raid from images for data recovery purposes, and again if you value your data then backup backup backup. Quote
Trabalhador Anonimo Posted 3 hours ago #25 Posted 3 hours ago Drive 2 - system partition fail. You can restore. Click on the disk, and a button will shows up "repair system partition". A new window will shows up asking to select the disk. I had this problem last week: 2 disks were fault. One crashed and another one had "system partition fail". I restore the first one and disable the second one. As there was 2 faults, the hot spare did not got working. After repair the first one ( with system partition fail), the hot spare went online and recover the other one. I reboot even before everything was ok, and the second disk came online. I´m backing up now to replace both disks. FYI: it is a 11 disks box. Quote
