brantje Posted April 3, 2017 #1 Posted April 3, 2017 Hello all, I have been helping a lot of people setup their Xpenology and also using this tool http://quickconnector.orgfree.com/index.php to generate 3615xs serial number then register it with a synology account. Recently I found that the serials generated for 3615xs are all unable to register. But if I choose another product e.g. 3612xs, the registration success. is it the serial number has been exhausted so that all the serials I generated is a duplicate one? or Synology noticed this and simply block all 3615xs registration? this is a real problem as quick connect has been so useful. Andrew Don't use quickconnect, you're destroying this project by using it!
fonix232 Posted April 3, 2017 #2 Posted April 3, 2017 For one, as above, stop using QuickConnect. For two, yes, it is a well-known "issue" that Synology changed to a new serial format ~2 years ago. Not much that you can do about it, except maybe Google a bit, because there's already a generator for the new format.
Aigor Posted April 4, 2017 #3 Posted April 4, 2017 DON'T USE QUICKCONNECT! It's more simple use DDNS and port address translation into router. Synology allow to use QC with their original product, still try to use QC and Synology can ban forum.
Salah Posted April 4, 2017 #4 Posted April 4, 2017 And a test NON quick connect box just went south, guess Synology has a clue?
Salah Posted April 4, 2017 #5 Posted April 4, 2017 you folks need a rethink discussion with current events
polanskiman Posted April 5, 2017 #6 Posted April 5, 2017 QuickConnect use is an abuse of Synology's services. This topic was already closed once and the user recreated it. I am closing this one too.
