I’m encountering issues configuring virtual machines in Synology Virtual Machine Manager (DSM 7.2) with Arc Loader 1.1.0. The virtual machines are not receiving IP addresses from the DHCP server and lack internet access.
Configuration:
• Synology NAS running DSM 7.2
• Virtual machines created via Virtual Machine Manager
• DHCP server configured on a TP-Link MR600 router, successfully assigning IP addresses to other devices
• Firewall is disabled
• Using Arc Loader version 1.1.0
Issue:
• Virtual machines detect the network interface enp3s0 with a MAC address assigned by the host but do not obtain an IP address or internet connectivity
• Installing Synology Guest Tool is not feasible due to the lack of internet access within the guest system
Steps Taken:
1. Configured Virtual Switch:
• Created an external virtual switch linked to the LAN1 interface, which has internet access
• Connected virtual machines to this switch
2. Checked Virtual Machine Network Settings:
• Network adapters are set to obtain IP addresses via DHCP
• Tested with adapter types e1000 and others
3. Verified DHCP Settings:
• Confirmed that the IP address pool on the router is not exhausted
• Other devices on the network receive IP addresses without issues
4. Performed Network Diagnostics within Virtual Machines:
• Executed ipconfig /renew (Windows) and dhclient (Linux) commands without success
• The command ip link show displays the interface enp3s0 with a MAC address assigned by the host
Question:
What additional steps or configurations can I undertake to enable the virtual machines to receive IP addresses from the DHCP server and gain internet access? I would appreciate any assistance or suggestions.
LastSkywalker
Hello,
Configuration:
Issue:
Steps Taken:
Question:
Thank you in advance!
8 answers to this question
