Virtual machine and Mediasonic Probox 8 bay H82-SU31C, possible ?
Cyberflow
I have a similar setup but I'm using a ESATA connection instead.  I find that it struggles a bit with latency when running VM's. I'm sure with the USB 3.2 Type C connection, it should be fine. I'm curious; How are you running this external enclosure?
