NVMe SSDs not showing in Storage manager
here4info
I had a virtual DSM running on proxmox, using redpill loader until about a month ago (I do not remember the DSM model or version number but it must be the latest version about a month ago). I have 3 NVMe drives passed through, that was setup as storage volume and everything was working great for couple months (i had lots of files backed up to these volumes and no issues). Until:
about a month ago, my system died, and I got a replacement system, popped back in the original NVMe drives in the new system, proxmox needed some reconfig but I got that to work. However while getting proxmox to work, I deleted the old DSM installation (on a different virtual drive on 4th NVMe drive). I reinstalled DSM using redpill loader again (including option of nvme as storage volume), and this is the current versions:
DSM3622xs+
7.2.2-72803
Problem: I can see that NVMe drives are passed through correctly from proxmox to DSM, however I do not see them in DSM storage manager. How do I debug?
root@xNAS:/# ls /dev/nvme*
/dev/nvme0      /dev/nvme0n1p2  /dev/nvme1n1    /dev/nvme1n1p3  /dev/nvme2n1p1
/dev/nvme0n1    /dev/nvme0n1p3  /dev/nvme1n1p1  /dev/nvme2      /dev/nvme2n1p2
/dev/nvme0n1p1  /dev/nvme1      /dev/nvme1n1p2  /dev/nvme2n1    /dev/nvme2n1p3
root@xNAS:/# fdisk -l /dev/nvme0n1
Disk /dev/nvme0n1: 3.7 TiB, 4000787030016 bytes, 7814037168 sectors
Disk model: Samsung SSD 990 PRO 4TB
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 1BBD1C0E-1D8D-4C11-BFC6
Device            Start        End    Sectors  Size Type
/dev/nvme0n1p1     8192   16785407   16777216    8G Linux RAID
/dev/nvme0n1p2 16785408   20979711    4194304    2G Linux RAID
/dev/nvme0n1p3 21241856 7813832351 7792590496  3.6T Linux RAID
root@xNAS:/# synopartition --scan-syno-part
/dev/sdb
/dev/sdb1
/dev/sdb2
/dev/sdb3
/dev/sdb5
root@xNAS:/# synopartition --check /dev/nvme0n1
/dev/nvme0n1: partition layout is version 9, list index is 15.
As you can see the drives are visible. However synopartition do not see them (sdb is the virtual drive).
I do not want to recreate the partitions, since I want to get back original data. I am hoping that if DSM can "see" the drives, it will reconstruct the volume
More info:
root@xNAS:/# cat /etc/synoinfo.conf | grep support_m2
support_m2_pool="yes"
root@xNAS:/# cat /etc/synoinfo.conf | grep support_disk_compatibility
support_disk_compatibility="no"
What else can I check?
Edited by here4info
Thanks, i built the image three times using the addon. It just wouldn't work.
I switched to DS920+ model and 7.2.1 version and the addon just worked. For me, this is good enough.
On the m2-volume patch git page, i did see that ds3622+ has had this addon working and not working between multiple versions, that's why I decided to switch to ds920+ where was consistently working
