vista1967 Posted August 11, 2024 #1 Posted August 11, 2024 Hello everyone, when I connect an external drive via USB port, but when I restart my PC, it disappears and appears as a normal drive. Does anyone have a solution to this problem? Thanks Quote
jacqlittle Posted August 16, 2024 #2 Posted August 16, 2024 On 8/11/2024 at 11:42 AM, vista1967 said: Hello everyone, when I connect an external drive via USB port, but when I restart my PC, it disappears and appears as a normal drive. Does anyone have a solution to this problem? Thanks USB mount (non-DT models only) Connected at boot -> USB drive is mounted as internal Not connected during boot -> USB drive is mounted as external Quote
vista1967 Posted August 17, 2024 Author #3 Posted August 17, 2024 Thanks for your reply! I'll check on the weekend, but I already think this is a problem Connected at boot -> USB drive is mounted as internal. Quote
jacqlittle Posted August 18, 2024 #4 Posted August 18, 2024 So this is how it works... If you use ARC Loader you can modify it manually in Synoinfo section: https://auxxxilium.tech/wiki/arc-loader-arc-loader/optionen/ Quote
