intelligence Posted October 22, 2013 #1 Posted October 22, 2013 Hello! Planning on what will be my next NAS. Currently I'm on a Synology DS409 which I'm very satisfied with, but of course, over the years it's become a little sluggish. So naturally for my next NAS I'm looking for good performance, for a relatively low buck. I've looked over the alternatives available from Synology at the moment, but it doesn't quite cut it. It costs too much compared to what you get. But I love the simpleness of DSM, so that when I started looking for custom solutions and found XPEnology. Now, I've been googling around for some time, looking for recommendations for builds, but I haven't found that many suggestions. So thus I'm asking here if you could help me pick out a Mini-ITX board and a CPU that would work with XPEnology. I'm aiming for a quiet, low powerusage solution, that won't have trouble transcoding stuff with Plex Media Server etc. Ideas? So for I've only chosen Node 304 from Fractal Design as the chassi. Everything else is up for discussion. Thanks for your help!
XPEH Posted October 22, 2013 #2 Posted October 22, 2013 It may not worth building it from scratch. For the same money ~$300 or less you can buy HP Microserver N54L on sale.
intelligence Posted October 25, 2013 Author #3 Posted October 25, 2013 Yeah, I get that. However the performance with a custom build would probably be better. This is what I'm looking at now, do you think it'll work with XPEnology? ASUS H87I-PLUS mITX A-Data S102 Pro 16GB USB 3.0 (storage) Intel Core i5 4570T 2.9 GHz Corsair 8GB (2x4GB) CL9 1600Mhz VENGEANCE LP Fractal Design Node 304 For me it seems like this is a good build to consider if I'd want to be able to have multiple plex streams (transcoding) and run torrents and what not aswell.
DHD Posted October 26, 2013 #4 Posted October 26, 2013 Yeah, I get that.However the performance with a custom build would probably be better. This is what I'm looking at now, do you think it'll work with XPEnology? ASUS H87I-PLUS mITX A-Data S102 Pro 16GB USB 3.0 (storage) Intel Core i5 4570T 2.9 GHz Corsair 8GB (2x4GB) CL9 1600Mhz VENGEANCE LP Fractal Design Node 304 For me it seems like this is a good build to consider if I'd want to be able to have multiple plex streams (transcoding) and run torrents and what not aswell. 32MB USB stick can use as boot disk
intelligence Posted October 26, 2013 Author #5 Posted October 26, 2013 Hehe, not available from the particular store But how about when installing packages, will that be distributed across the storage or the USB? But they probably don't take up that much space anyway. Any thoughts about the CPU or anything else? Any ideas how the CPU will cope with transcoding? Ideally it should handle multiple streams. I plan on letting my parents and friends connect to it via Plex.
maxrogers Posted November 7, 2013 #6 Posted November 7, 2013 Intelligence, have you started your project yet? This sounds like something I might like to do also (with my main concern being plex 1080p transcoding.) Needless to say I am anxious to follow your progress!
intelligence Posted November 13, 2013 Author #7 Posted November 13, 2013 Hey, not yet. Haven't found any reliable info if the mobo will work with xpenology..
disruptorx Posted November 26, 2013 #8 Posted November 26, 2013 im using Giada N70E-DR mobo, been running latest 4.2 build for couple of months..very stable and everything works oh and I use the same case as yours
soulsurfing Posted December 6, 2013 #9 Posted December 6, 2013 im using Giada N70E-DR mobo, been running latest 4.2 build for couple of months..very stable and everything works oh and I use the same case as yours Are all the 6 ports working on this motherboard? Anything that is not working correctly? Any changes you have to do? I am looking at this exact setup with that Giada board but want to check to see if this all works before I buy it.
disruptorx Posted December 8, 2013 #10 Posted December 8, 2013 im using Giada N70E-DR mobo, been running latest 4.2 build for couple of months..very stable and everything works oh and I use the same case as yours Are all the 6 ports working on this motherboard? Anything that is not working correctly? Any changes you have to do? I am looking at this exact setup with that Giada board but want to check to see if this all works before I buy it. yes all ports working fine, I’m running 6x 3TBs on mine
Vspec Posted December 11, 2013 #11 Posted December 11, 2013 Hi Intelligence I was thinking of building nearly the exact build you have! Hopefully this link answers your question. Looks like the H87i works ok with some minor issues. http://hardforum.com/showthread.php?t=1 ... =xpenology
intelligence Posted December 11, 2013 Author #12 Posted December 11, 2013 Nice! Are you going with H60 aswell? (What does he mean with caps blocking a H90 btw? From the PSU?). I've been thinking a bit and I might just go for OpenMediaVault, it's not as nice as DSM but upgradability seems easier and safer. Seems like it'll evolve into something as nice as DSM sometime in the future.
Vspec Posted December 12, 2013 #13 Posted December 12, 2013 Hi Intelligence I will most probably go with a Noctua NH-U12S want to keep it quiet plus the room that the NAS will live in is cool already. The only thing I will need to get is an Intel NIC as the onboard network doesn't seem to work with DSM 4.3 (thats the only issue at the moment). I was tempted to go with the Z87i-pro but thought it would be overkill for a NAS motherboard. I think he means the cpu plate on the H90 is probably larger than the H60 hence its hitting the capicitors on the Z87i motherboard? So my setup will be Fractal 304 (6 drive bays) ASUS H87I-PLUS (6 SATA III Ports) i5 4570S 16GB Vengence RAM 1600MHz 6x4TB Reds Seasonic 400w Platinum fanless Intel Pro NIC Noctua NH-U12S Cheers
Cozmo85 Posted December 13, 2013 #14 Posted December 13, 2013 Are you sure the h87i-plus nic doens't work? Its the intel 217 The latest changelog says NETWORK ------- Update INTEL e1000e driver to v2.5.4 (support I217x and I218x chip)
Cozmo85 Posted December 14, 2013 #15 Posted December 14, 2013 I can confirm the i217 on the H87i-plus and some other h87 chipset boards works perfectly.
manfriday Posted December 14, 2013 #16 Posted December 14, 2013 built two using: ZOTAC Atom Dual-Core 1.6GHz/MCP7A-ION/DVI&HDMI/A&V&GbE/Mini ITX Motherboard IONITX-G-E one runs 4.2 the other 4.3 with updates per these pages 2GB RAM each 4.2 unit has 3x2GB SATA (SHR) 4.3 unit has 4x1GB WD RED drives + 750GB Green drive plugged into older 4 port RocketRaid mobo combo was $69 might decommission 4.2 unit or try HA just for giggles Many thanks to all involved in making this happen!
Vspec Posted December 16, 2013 #17 Posted December 16, 2013 Hi Cozmos85 That's awesome news! I was only going by the build from the other forum. I haven't purchased the NIC yet so will do the build without it. Thanks for the heads up
fgullama Posted December 18, 2013 #18 Posted December 18, 2013 Hello all, I recently stumbled upon this forum. Very cool stuff! I am considering trying this out to refresh my old Zotac Atom running WHS v1. Looks like it might work pretty well... This is the motherboard model: IONITX-A-U Atom N330 Dual Core 90-Watt PSU WiFi ITX Intel Motherboard. I'll write in as soon as I have time to try this out with 4.3. Any input/suggestions beforehand would be appreciated if anybody has familiarity with this particular setup. It's pretty much just the motherboard using onboard VGA, wired Ethernet, and two Seagate 1.5tb hard drives. Thanks! Frank
manfriday Posted December 25, 2013 #19 Posted December 25, 2013 i run my Zotec headless. initial setup to set BIOS to boot from USB and watch install from USB, after that no VGA or keyboard. the only things plugged in externally are USB key, Ethernet cable and power cable
mypchut Posted December 26, 2013 #20 Posted December 26, 2013 Hi Cozmos85 Thank you for telling that INTEL i217 lan chipset working! Searching the forum for the answer getting the asrock B85M- Pro4. Thanks.
fgullama Posted January 3, 2014 #21 Posted January 3, 2014 Just to report back. I got XPENOLOGY 4.3 with the latest update up and running on my IONITX-A-U Atom N330. It works pretty well! My only curiosity is that I seem to get spotty performance transcoding videos via Video Station... It's curious in that sometimes it will transcode a video using 60-70 % CPU and everything is smooth, then other times it goes to around 100% cpu transcoding the same video and playback is is all jerky. This looks to be related to the ffmpeg process sucking up all available resources. I had better luck the other day with Plex, but even that now is going to 100% cpu and choking. It's very.... Unpredictable... Which is driving me nuts. I know the dual core Atom is not going to be so great at transcoding, but I know it was working better on and off. Note that I do know that it does not always transcode, depending on the video. This is only referring to when the ffmpeg process is spawned when streaming a video. With the variations occurring with the same test videos. It's very weird! Any ideas would be appreciated on that one. I'd say overall though, this board works quite well with minimal headaches setting up with XPENOLGY. Hopefully this helps somebody else out there. Frank
