AOOSTAR R1 (n100) - what NAS model to choose for transcoding/ML to work?
Hi
I just ordered AOOSTAR R1 with Intel N100, my use case will be mainly jellyfin and immich, both use transcoding via Intel's QuickSync, also immich has a way to use HW accelerated machine learning through OpenVINO (face and object recognition etc.). I just learned that some models don't support transcoding and others support it. How my model choice will affect my use case?
2 hours ago, Peter Suh said:
For that product, I recommend SA6400.
thanks, I just came here to answer my own post, I did what you said though, SA6400 gave me intel gpu drivers i needed, the jellyfin transcoding works, though vaapi only, quicksync crashes, i have no way to check if immich ML uses CPU or GPU though, might have to dive more into it
