1812+ - Expanded SHR-1 system errors - caused system reboot and scan
Hi All!
I have a 1812+ 8-bay system. I recently added another 20TB drive... so my makeup is the following:
3 20TB HDD
5 8TB HDD
After rebuilding the array (SHR-1) for 5 days - i received a notification system errors occurred. The process did finish and it said 'Healthy' but had a 'Warning' that there were some system errors. The recommendation was to reboot and do a system scan. I allowed it to reboot and do this scan.
When this scan was occurring after reboot, it was doing a e2fsck scan. This took about 5/6 hours. And has since finished - based on checking 'top'.
Another process is now running and has been for about 90 minutes. This process is:
/sbin/debugfs -q /.remap.vg1000.lv /dev/vg1000/lv
Should i let this process finish? I assume the answer is yes! Please confirm?
I have done some other system checks/commands, and the outputs are below. It LOOKS to me that the volume is still generally OK... but i do not see if when i do a 'df -h'.
Here is the output:
lvm vgscan
Reading all physical volumes.  This may take a while...
Found volume group "vg1000" using metadata type lvm2
lvm lvscan
ACTIVE            '/dev/vg1000/lv' [70.92 TiB] inherit
pvs
  PV         VG     Fmt  Attr PSize  PFree
  /dev/md2   vg1000 lvm2 a--  19.07t    0
  /dev/md3   vg1000 lvm2 a--  19.10t    0
  /dev/md4   vg1000 lvm2 a--  10.92t    0
  /dev/md5   vg1000 lvm2 a--  21.83t    0
vgs
  VG     #PV #LV #SN Attr   VSize  VFree
  vg1000   4   1   0 wz--n- 70.92t    0
lvs
  LV   VG     Attr       LSize  Pool Origin Data%  Meta%  Move Log Cpy%Sync Convert
  lv   vg1000 -wi-ao---- 70.92t
pvdisplay
--- Physical volume ---
  PV Name               /dev/md2
  VG Name               vg1000
  PV Size               19.07 TiB / not usable 2.94 MiB
  Allocatable           yes (but full)
  PE Size               4.00 MiB
  Total PE              4999687
  Free PE               0
  Allocated PE          4999687
PV UUID               39SMYw-LvD9-csns-Ibx0-Xk6L-NcRN-gH5z57
  PV Name               /dev/md3
  VG Name               vg1000
  PV Size               19.10 TiB / not usable 1.31 MiB
  PE Size               4.00 MiB
  Total PE              5007581
  Free PE               0
  Allocated PE          5007581
PV UUID               zigxlk-rzBz-w71G-XG0c-T5NK-Kdty-2asJUO
  PV Name               /dev/md4
  VG Name               vg1000
  PV Size               10.92 TiB / not usable 2.69 MiB
  PE Size               4.00 MiB
  Total PE              2861564
  Free PE               0
  Allocated PE          2861564
PV UUID               gaMsmu-3noo-SQlO-A2Ol-9irc-OeQP-PAsC7H
  PV Name               /dev/md5
  VG Name               vg1000
  PV Size               21.83 TiB / not usable 3.94 MiB
  PE Size               4.00 MiB
  Total PE              5721574
  Free PE               0
  Allocated PE          5721574
  PV UUID               cMM5qC-lxe1-ET5H-uUjR-1X0R-9oqd-2mf5pX
vgdisplay
--- Volume group ---
VG Name               vg1000  System ID
  Format                lvm2
  Metadata Areas        4
  Metadata Sequence No  57
  VG Access             read/write
  VG Status             resizable
  MAX LV                0
  Cur LV                1
  Open LV               1
  Max PV                0
  Cur PV                4
  Act PV                4
  VG Size               70.92 TiB
  PE Size               4.00 MiB
  Total PE              18590406
  Alloc PE / Size       18590406 / 70.92 TiB
  Free  PE / Size       0 / 0
VG UUID               R3FyH1-QjrW-UoEu-xDM6-Ihzq-AuQ0-45PC2M
lvdisplay
--- Logical volume ---
  LV Path                /dev/vg1000/lv
  LV Name                lv
  VG Name                vg1000
  LV UUID                7dAjuW-c4q8-223V-L2QF-DmFw-dfJv-UR5ZND
  LV Write Access        read/write
  LV Creation host, time ,
  LV Status              available
  # open                 1
  LV Size                70.92 TiB
  Current LE             18590406
  Segments               4
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     4096
Block device           253:0
cat /etc/fstab
none /proc proc defaults 0 0
/dev/root / ext4 defaults 1 1
/dev/vg1000/lv /volume1 ext4 usrjquota=aquota.user,grpjquota=aquota.group,jqfmt=vfsv0,synoacl,relatime 0 0
I just would like someone to confirm with me that the debugfs is an EXPECTED process of the reboot/scan following the completion of the e2fsck scan? If so, I will be PATIENT and wait for it to finish and i assume reboot the NAS and allow me to login into the web GUI... if it is NOT expected to run, any recommended next steps?
Edited by ccfc1986
ease of reading - bolded and underlined commands
4 answers to this question
Update:
After some patience - the server DID reboot itself. However, it still showed the storage volume the old size (60TB) in the disk area, but did show it sees 70TB in main page. When i went to the drives page it showed a warning, that i needed to complete the SHR process, so i clicked through the pop up, and it started 'Checking consistency' again. Then it immediately shut itself down. Completely. No lights no nothing after about 1 minute. I just restarted it (clicking the power button) - and its loading back up again.
Very weird behavior. Going to try doing the same step again - but if anyone has any ideas - how to get it to see the full new size (as it seems to have correctly rebuilt the array with the new disk).
Thanks all!
Update 2:
Drive is currently doing a "Verifying drives in the background - check disk parity consistency 1.01%)".
Its running at about 200k/second. The time to finish is roughly 24 hours. I hope this connects the dots of the process and everything is working roughly this time tomorrow! Will keep you all posted.
In the meantime - if anyone has any suggestions on speeding the process up, or validating things are going smoothly (using cat /proc/mdstat currently to see what its doing).
ash-4.3# cat /proc/mdstat
md3 : active raid5 sdh6[15] sdc6[10] sdd6[9] sdb6[12] sda6[11] sde6[13] sdf6[8] sdg6[14]
      20511053696 blocks super 1.2 level 5, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
md4 : active raid5 sdc7[7] sdf7[10] sdh7[6] sdg7[5] sde7[4] sdd7[3] sdb7[9] sda7[8]
      11720969472 blocks super 1.2 level 5, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
      [>....................]  reshape =  0.8% (16664348/1953494912) finish=1476.6min speed=21860K/sec
md5 : active raid5 sdc8[0] sdb8[2] sda8[1]
      23435571712 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
md2 : active raid5 sda5[13] sdh5[8] sdg5[9] sdf5[10] sde5[11] sdd5[14] sdc5[15] sdb5[12]
      20478721536 blocks super 1.2 level 5, 64k chunk, algorithm 2 [8/8] [UUUUUUUU]
md1 : active raid1 sda2[0] sdb2[1] sdc2[2] sdd2[3] sde2[4] sdf2[5] sdg2[6] sdh2[7]
      2097088 blocks [8/8] [UUUUUUUU]
md0 : active raid1 sda1[0] sdb1[1] sdc1[2] sdd1[3] sde1[4] sdf1[5] sdg1[6] sdh1[7]
      2490176 blocks [8/8] [UUUUUUUU]
Was able to 'expand'. Now says 'Available Capacity' is 0 bytes under 'Storage Pool'. But i have over 12TB free when in the 'Volume' section. Any ideas why? I want to put in another 20TB disk - but don't want to do this until these numbers make complete sense etc.
Thanks all!
Answer this question...
