Hello, so i'am migrating to Another Devices, using VirtualBox with ARPL, the main volume was crashing (VMDK), Basic partition, the problem is,all of my important notes was on that Partition (DS Notes), does anyone know how to recover the partition or fix it (because its single Basic Partition and i'am going crazy).
thanks in advanced
  • 1 month later...
Since the question is too old, it seems likely that the problem has already been solved.
It seems that both storage pools have problems at the same time.
Usually, when a system partition crashes (volume 1), another healthy system partition is imported and synchronized.
However, it is not certain whether even volume 2 is guaranteed to have a healthy partition.
Some of the information on storage pool 2 (volume 2) is truncated, so it is not confirmed at all.
It is not certain whether the member disk that constitutes RAID is missing.
If only a healthy system partition is guaranteed to help recover the system partition, recovering the system partition is not that risky.
Even if RAID has a problem, if proper measures are taken for recovery, it will be possible to recover without data loss.
