After a power failure, my main volume went into "crashed" state. This volume contained all the main files, as well as all applications. I have backups of important files, but no backups of applications, and setting them up again is very time-consuming and difficult.
My Xpenology is installed in a virtualization environment (ESXi).
I would really like to return everything to its original state. I have read many articles and recovery methods, but none of them work for me.
~# btrfs fi show -d
Label: '2023.06.05-19:54:16 v64561' uuid: 63832383-0407-45db-b727-75fd04f545ed
Total devices 1 FS bytes used 765.58GiB
devid 1 size 1.35TiB used 796.02GiB path /dev/mapper/cachedev_1
Label: '2023.06.05-19:54:33 v64561' uuid: 8db7f514-8914-4a51-9148-fcc2bc05340e
Total devices 1 FS bytes used 3.36TiB
devid 1 size 3.62TiB used 3.49TiB path /dev/mapper/cachedev_0
Label: '2023.06.05-19:43:57 v64561' uuid: cdc33873-8b6c-478f-bff3-02ed855b3b07
Total devices 1 FS bytes used 814.03GiB
devid 1 size 1.76TiB used 868.02GiB path /dev/mapper/cachedev_2
~# btrfsck /dev/mapper/cachedev_2
parent transid verify failed on 905269411840 wanted 2591264 found 2591272
Ignoring transid failure
Couldn't setup extent tree
Couldn't open file system
~# mount -t btrfs -o ro,usebackuproot /dev/mapper/cachedev_2 /volume1
mount: /volume1: wrong fs type, bad option, bad superblock on /dev/mapper/cachedev_2, missing codepage or helper program, or other error.
DimChik2903
~# btrfs fi show -d Label: '2023.06.05-19:54:16 v64561' uuid: 63832383-0407-45db-b727-75fd04f545ed Total devices 1 FS bytes used 765.58GiB devid 1 size 1.35TiB used 796.02GiB path /dev/mapper/cachedev_1 Label: '2023.06.05-19:54:33 v64561' uuid: 8db7f514-8914-4a51-9148-fcc2bc05340e Total devices 1 FS bytes used 3.36TiB devid 1 size 3.62TiB used 3.49TiB path /dev/mapper/cachedev_0 Label: '2023.06.05-19:43:57 v64561' uuid: cdc33873-8b6c-478f-bff3-02ed855b3b07 Total devices 1 FS bytes used 814.03GiB devid 1 size 1.76TiB used 868.02GiB path /dev/mapper/cachedev_2~# btrfsck /dev/mapper/cachedev_2 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 Ignoring transid failure Couldn't setup extent tree Couldn't open file systemhttps://stackoverflow.com/questions/46472439/fix-btrfs-btrfs-parent-transid-verify-failed-on
~# mount -t btrfs -o ro,usebackuproot /dev/mapper/cachedev_2 /volume1 mount: /volume1: wrong fs type, bad option, bad superblock on /dev/mapper/cachedev_2, missing codepage or helper program, or other error.https://lists.opensuse.org/archives/list/users@lists.opensuse.org/message/XCLAIJ7FUHZUBQIKJPU6VXJAOICKSTOT/
From this article I tried all the steps, not one worked, giving out different errors.
btrfs rescue chunk-recovererrors out with "couldn't open RDWR because of unsupported option features".
~# btrfs check --clear-space-cache v2 /dev/mapper/cachedev_2 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 parent transid verify failed on 905269411840 wanted 2591264 found 2591272 Ignoring transid failure Couldn't setup extent tree Couldn't open file systemMaybe someone else will have ideas for how to restore volume? Thank you in advance.
0 answers to this question
