Rendys007 Posted June 10, 2024 #1 Posted June 10, 2024 (edited) Hello, for almost 2 years I've been running on NAS without any issues, almost non-stop. Docker, web server, etc. A few days ago, I used the web interface of Synology (clicked on renew certificate). The original certificate was still valid, I probably made a mistake. Unfortunately, since then I have no access to the Synology web interface. This error: NET::ERR_CERT_INVALID Subject: synology.com Issuer: Synology Inc. CA Expires on: 9. 6. 2025 Current date: 10. 6. 2024 PEM encoded chain: -----BEGIN CERTIFICATE----- ... -----END CERTIFICATE----- I can still access the NAS via ssh, scp, tftp, so I tried to generate my own certificates with self-signature. Like this: sudo openssl req -x509 -nodes -days 3650 -newkey rsa:2048 -keyout /usr/syno/etc/certificate/_archive/server.key -out /usr/syno/etc/certificate/_archive/server.crt sudo chmod 600 /usr/syno/etc/certificate/_archive/server.key sudo chmod 644 /usr/syno/etc/certificate/_archive/server.crt sudo chown root/usr/syno/etc/certificate/_archive/server.key sudo chown root/usr/syno/etc/certificate/_archive/server.crt It didn't help, so I tried further to modify the configuration file nginx.conf and add lines to all blocks under server with the location of the certificate where I saved them: ... server { listen 443 ssl; ssl_certificate /usr/syno/etc/certificate/_archive/server.crt; ssl_certificate_key /usr/syno/etc/certificate/_archive/server.key; ... } sudo vi /etc/nginx/nginx.conf sudo systemctl restart nginx sudo reboot And no change, I can't access the web interface neither via http nor https. Only through the terminal. Any advice on what to do next, did I copy to the wrong directories (-archive)? How to proceed? Sorry this is translator. Thanks in advance for any guidance and help. Edited June 10, 2024 by Rendys007 Quote
0 Rendys007 Posted June 11, 2024 Author #2 Posted June 11, 2024 So I finally solved it, simple. I reinstalled the NAS to the latest DSM. Quote
Rendys007
This error:
PEM encoded chain:
Like this:
... server {
listen 443 ssl;
sudo reboot
How to proceed?
Edited by Rendys0071 answer to this question
