seeiis 2 Posted April 5, 2017 Share Posted April 5, 2017 yes, at first i can enter to dsm, and now no. synology assistant dont find the nas too... thank you i might this will help you synoservice {--help} synoservice {--list} [running] synoservice {--enable | --disable} service... synoservice {--start | --stop | --restart} service... synoservice {--keyon | --keyoff} service... synoservice {--detail} service... syno service dsm --start something like this via SSH http://paf.dias.ac.cy/main/support/syno ... n-commands Link to post Share on other sites
iRegue 0 Posted April 5, 2017 Share Posted April 5, 2017 yes, at first i can enter to dsm, and now no. synology assistant dont find the nas too... thank you i might this will help you synoservice {--help} synoservice {--list} [running] synoservice {--enable | --disable} service... synoservice {--start | --stop | --restart} service... synoservice {--keyon | --keyoff} service... synoservice {--detail} service... syno service dsm --start something like this via SSH http://paf.dias.ac.cy/main/support/syno ... n-commands Thank you so much! these commands i have put into ssh, its ok? Another question... I have q1900 but i renew my nas, what pieces i have to buy for the best compatibility with 6.1? thank you so much. Link to post Share on other sites
seeiis 2 Posted April 5, 2017 Share Posted April 5, 2017 Thank you so much! these commands i have put into ssh, its ok? Another question... I have q1900 but i renew my nas, what pieces i have to buy for the best compatibility with 6.1? thank you so much. Yes, its in SSH but not all the commands, maybe the DSM Service isnt working, in some part in the forum i saw that command maybe it will help you. and about the compatibility i dont know the hardware list, maybe somebody can tell you the exact piezes. Sorry in that Link to post Share on other sites
pigr8 30 Posted April 6, 2017 Share Posted April 6, 2017 There where many post on getting a migration work under vmware (no network after migration).These we're the steps I performed to update my virtual machine from dsm 6.0 to dsm 6.1 with Jun's loader v1.02a : Copy dsm6.0 vm to new folder Copy synoboot.img, synoboot.vmdk to new vm folder Boot machine Start syno, install and migrate. After migrate wait at least 5 minutes, the system will not be reachable any more. Shutdown Prepare a bootable (liliboot) Linux live cd with gparted. Boot to EFI to boot from usb. Goto gparted terminal Mount raid system partition: sudo mdadm -AU byteorder /dev/md0 /dev/sdb1 cd /mnt sudo mkdir md0 sudo mount /dev/md0 md0 sudo cd md0 Do the copy modules trick : sudo cp lib/modules/update/* /lib/modules/ Reboot, you should be able to connect thank you for the tip, had to use virtual serial console on my gen8 to restore the missing modules, everything is working fine and upgraded to update2. Link to post Share on other sites
seeiis 2 Posted April 6, 2017 Share Posted April 6, 2017 There where many post on getting a migration work under vmware (no network after migration).These we're the steps I performed to update my virtual machine from dsm 6.0 to dsm 6.1 with Jun's loader v1.02a : Copy dsm6.0 vm to new folder Copy synoboot.img, synoboot.vmdk to new vm folder Boot machine Start syno, install and migrate. After migrate wait at least 5 minutes, the system will not be reachable any more. Shutdown Prepare a bootable (liliboot) Linux live cd with gparted. Boot to EFI to boot from usb. Goto gparted terminal Mount raid system partition: sudo mdadm -AU byteorder /dev/md0 /dev/sdb1 cd /mnt sudo mkdir md0 sudo mount /dev/md0 md0 sudo cd md0 Do the copy modules trick : sudo cp lib/modules/update/* /lib/modules/ Reboot, you should be able to connect thank you for the tip, had to use virtual serial console on my gen8 to restore the missing modules, everything is working fine and upgraded to update2. how can i use the virtual serial console? is there any tutorial? Can you tell me a little bit more detailed the procedure u do to recover the network? Thanks in advance Link to post Share on other sites
wenlez 6 Posted April 6, 2017 Share Posted April 6, 2017 is KVM supported? or has anyone tried this on Proxmox / KVM? Link to post Share on other sites
cyberdott 1 Posted April 7, 2017 Share Posted April 7, 2017 Hello, i did a clean install on a Microserver gen8 with 4x3TB WD Red. Everything is running perfectly for a week with latest update. Also phpvirtualbox runs well with Apache 2.4 / PHP 7. Great Work Link to post Share on other sites
Kinoal 0 Posted April 7, 2017 Share Posted April 7, 2017 Hi, A few days ago i updated to 6.2 and it works fine. I can restart and shut down the NAS without problems, but today, when i arrived home and enter dsm to check the download station, i cant enter to DSM. It says that. What can i do? i restart the system but the message is the same. this is the correct ip and port. I need help please. Thank you so much. I have exactly the same problem ! I'm desperate to find a solution. I hope that there is a way to downgrade to 6.0 Nobody know how to downgrade to 6.0? Each time, I reboot, go to install then find.synology.com and redo an install + migrate my data and 1 day after, the dsm is crashing but services like PLEX are still up! How I'm suppose to execute SSH command, I though that SSH service was not running by default since the 6.0? Link to post Share on other sites
Olegin 499 Posted April 7, 2017 Share Posted April 7, 2017 Each time, I reboot, go to install then find.synology.com and redo an install + migrate my data and 1 day after, the dsm is crashing but services like PLEX are still up! How I'm suppose to execute SSH command, I though that SSH service was not running by default since the 6.0? Don't istall 6.1 3617, it working only for 1 day. Try 3615, it's works fine. Link to post Share on other sites
Kinoal 0 Posted April 7, 2017 Share Posted April 7, 2017 (edited) Each time, I reboot, go to install then find.synology.com and redo an install + migrate my data and 1 day after, the dsm is crashing but services like PLEX are still up! How I'm suppose to execute SSH command, I though that SSH service was not running by default since the 6.0? Don't istall 6.1 3615, it working only for 1 day. Try 3615, it's works fine. Where Can I find the 6.1.3617? And How can I choose a custom pat file when I put the bootloader to install mode? Edited April 7, 2017 by Guest Link to post Share on other sites
Olegin 499 Posted April 7, 2017 Share Posted April 7, 2017 https://global.download.synology.com/do ... _15047.pat https://global.download.synology.com/do ... _15047.pat Bootloaders is different for 3615 and 3617. Link to post Share on other sites
MGD9000 2 Posted April 7, 2017 Share Posted April 7, 2017 3617 should come with a warning before install. I was so pissed off when it crapped out on me 13 hours later. 8 TB takes a long time to retransfer. Sent from my XT1565 using Tapatalk Link to post Share on other sites
Kinoal 0 Posted April 7, 2017 Share Posted April 7, 2017 https://global.download.synology.com/download/DSM/release/6.1/15047/DSM_DS3615xs_15047.pathttps://global.download.synology.com/download/DSM/release/6.1/15047/DSM_DS3617xs_15047.pat Bootloaders is different for 3615 and 3617. Sorry I meaned the 3615 because it seems that I need the 3615:) Link to post Share on other sites
Polanskiman 443 Posted April 8, 2017 Share Posted April 8, 2017 https://global.download.synology.com/download/DSM/release/6.1/15047/DSM_DS3615xs_15047.pathttps://global.download.synology.com/download/DSM/release/6.1/15047/DSM_DS3617xs_15047.pat Bootloaders is different for 3615 and 3617. Sorry I meaned the 3615 because it seems that I need the 3615:) You might need to read again. He provided both 3615 and 3617 Link to post Share on other sites
mgrobins 0 Posted April 8, 2017 Share Posted April 8, 2017 Hi, thought I'd join this thread as I am building a new bare metal install to test and review some hardware (small home server build supported by ICYDock and some others). I'm happy to use this as a means of testing some stuff as my build is very similar in hardware to the DS3617xs. I will have: Supermicro X10SDV-4C-TLN2F which is a Xeon-D SOC. MB has the 10GBase-T onboard (X540-T2 is part of the SOC I believe or chipset). LSI 9211-8i HBA 8GB ECC I have some queries: 1. Where do I get a serial and MAC for the DS3617xs? I only have a excel spreadsheet that lists up to DS3615xs. (additional NIC MAC's can be anything yes?) 1. is 10G ethernet working for people? I recall there were some workarounds required a while back to enable the correct process. 2. For Wake on LAN will the package I have been running on an authentic DS1813+ be managed the same way? 3. To wake my NAS do I use the native NIC MAC or need to find a way to flash the NIC MAC addresses to those I use in the boot-loader. Sorry if I seem simple.... I'm new to this and have been reading a tonne of threads but am still putting things together . Link to post Share on other sites
captainfred 0 Posted April 8, 2017 Share Posted April 8, 2017 Does that page cannot be found error or whatever it says after 1 day only happen with 3617 ? Link to post Share on other sites
Polanskiman 443 Posted April 9, 2017 Share Posted April 9, 2017 Does that page cannot be found error or whatever it says after 1 day only happen with 3617 ? So far, it seems to. Link to post Share on other sites
mgrobins 0 Posted April 9, 2017 Share Posted April 9, 2017 ok. I'll try it on my hardware this week and see what it presents with. Link to post Share on other sites
lastkiss 0 Posted April 10, 2017 Share Posted April 10, 2017 MB:asrock B85M-ITX CPU:i5-4460T LAN:Qualcomm® Atheros® AR8171 DS3617xs 6.1 Jun's Mod V1.02a2 can work,Continue to test DS916p 6.1 Jun's Mod V1.02a2can not work,Synology Assistant could not find it DS916+,My router(R7000) can not be found this MAC address MB:asrock J4205-ITX LAN:Realtek RTL8111GR DS916p 6.1 Jun's Mod V1.02a2can not work,Synology Assistant could not find it DS916+,My router(R7000) can not be found this MAC address Where is wrong??? Link to post Share on other sites
mgrobins 0 Posted April 10, 2017 Share Posted April 10, 2017 I am having the same issue. Another member with the same hardware as me has his working but I cannot find my NAS using the syn assistant. I have been using Bootloader 1.01 ..... haven't gotten as far as using a version of DSM yet. The partitions were in place on my hard drive I just think it may be an Ethernet issue? my motherboard has the following: CPU and Chipset Drivers: Broadwell based SOC Intel® Xeon® processor D-1521 FCBGA 1667 Intel® D-1500 SoC 10GbE Controller SoC 10GbE X552/X557-AT 10GBASE-T Link to post Share on other sites
FiberInternetUser 5 Posted April 10, 2017 Share Posted April 10, 2017 On the v1.02A builds, I could never install the DS916P it would never show up on my network. I would say it didn't have my network card in the build. The DS3617xs would bomb out after about 12 hours. I see jun has put up new builds for both of these as v1.02A2. I just tried to boot v1.02A DS916P and it does not show up on my network. Link to post Share on other sites
sze 2 Posted April 10, 2017 Share Posted April 10, 2017 So I try the new 1.02A2 build with DS3617xs to see if time bomb exist on that release. One bad thing, if I run dmesg I get at the end following message: [15235.595668] Can't get Core 8 temperature data [15235.595670] CPU count larger than MAX_CPU 2: 2 [15235.595672] CPU count larger than MAX_CPU 2: 2 [15235.595674] CPU count larger than MAX_CPU 2: 2 I had configure the VM with 8 cores, because the original DS have also a CPU with 8 Threads (4 core with HT). Don't know was this message have an impact. Edit: Saw at top another message that is different... [0.000000] smpboot: Allowing 8 CPUs, 0 hotplug CPUs Link to post Share on other sites
ryann 0 Posted April 11, 2017 Share Posted April 11, 2017 Hi I'm running Xpenology and in a bout of reckless stupidity I clicked the upgrade button in DSM, which attempted and failed to install DSM 6.1-15047. Now I can't rollback to v5.2-5644 as it keeps saying it is an older version than 6.1. I've tried editing /etc.defaults/VERSION but this hasn't worked - can edit the file but Synology Assistant still says it is DSM 6.1-15407. Using Jun's Loader v1.02a is my last hope of recovering my data before I cave in and buy a DS416J. When I use Win32DiskImager to write synoboot.img to USB, I don't get a boot folder. I've tried several times and I believe I've read all of this thread but can't find a solution. Any assistance would be greatly appreciated. Link to post Share on other sites
sze 2 Posted April 11, 2017 Share Posted April 11, 2017 its grub\grub.cfg not boot Thats a good how-to viewtopic.php?f=2&t=22100 Link to post Share on other sites
aliens 0 Posted April 11, 2017 Share Posted April 11, 2017 hi, is possible migrate from raid5 to shr without data loss? Link to post Share on other sites
