I have now partially working my migration hardware (some problems with the second controller, which disconnect the disks connected to it after a while with the log message "Drive Plugged out"). Thread here:
Now let's say that I want to update from Jun's loader 1.04b 918+ BAREMETAL to ARC.
I investigated how to do it in the "official way" (meaning, real Synology hardware), and I found this page:
So after having a look how to update the DS918+ to the latest DSM 7.2.1, they advice:
Starting from my version: 6.2.3-25426
First update to: 6.2.4-25556
Then update to: 7.0.1-42218
Then update to: 7.2.1-69057 (with Update 1)
And finally update to: 7.2.1-69057 Update 5
So I was thinking if could be possible to do it that way:
Creating an ARC loader based on 918+ (to match exactly the current installation), and keep installing in sequence all this updates (probably changing the loader in every step of the way), so it will be smooth and with no problems instead of trying to do a migration, like even @AuxXxilium discourages to do it in his wiki, advising: "Upgrade DSM 6 to DSM 7 can cause some Issue, please use clean Disks for DSM 7 (Partition Layout and Size changed)."
ed_co
https://kb.synology.com/en-ph/DSM/tutorial/How_can_I_update_to_the_latest_DSM_version_from_an_older_version
@AuxXxilium, @Polanskiman, @IG-88, @flyride or anyone else, do you think could be possible to do it?
Thank you very much
Edited by ed_co2 answers to this question
