polanskiman Posted February 8, 2024 #1 Posted February 8, 2024 Wanted to update to dsm 7.2.1 so I updated the loader first. Currently using the ARC loader. Once updated, all was find, DSM upgraded fine and I was on DSM 7.2.1 until I rebooted. After the reboot all volumes had crashed. I had already experienced something similar in the past and a force reinstall had fixed it. So I did the same. It fixed it, except when I reboot, all volumes crash again. Did this like 4-5 time with the same outcome each time. The last time I tried I wasn't able to upload the .pat file and I was greeted with the dreaded: Quote Failed to install DSM. Available system space is insufficient. What's the deal here and how can I get out of this pickle? Thanks all. Quote
polanskiman Posted February 8, 2024 Author #2 Posted February 8, 2024 Ok so I was able to mount /dev/md0 and delete a .pat file that was in the @autoupdate directory. This said I dont think I still have enought space since the 7.2.1 dsm pat file is over 400MB. SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.9G 296.6M 87% /tmp/test Question is, what else can be removed? I see plenty of data in 3 directories, namely upd@te, usr and var but I am not sure what can safely be deleted: SynologyNAS> du -hs * 4.0K @autoupdate 26.8M @smallupd@te_deb_uploaded 0 bin 4.0K config 8.0K dev 4.8M etc 2.5M etc.defaults 4.0K initrd 0 lib 0 lib32 0 lib64 4.0K lost+found 4.0K mnt 4.0K proc 28.0K root 24.0K run 0 sbin 0 stopping 4.0K sys 4.0K tmp 376.9M upd@te 1.2G usr 242.2M var 9.2M var.defaults 4.0K volume1 4.0K volume2 The upd@te directory contains the following: SynologyNAS> cd upd@te SynologyNAS> ls -la drwxr-xr-x 3 root root 4096 Jan 1 00:00 . drwxr-xr-x 26 root root 4096 Jan 1 00:01 .. -rw-r--r-- 1 root root 5273600 Sep 23 2023 DiskCompatibilityDB.tar -rw-r--r-- 1 root root 102 Sep 23 2023 GRUB_VER -rwxr-xr-x 1 root root 1010425 Sep 23 2023 H2OFFT-Lx64 -rw-r--r-- 1 root root 5998 Oct 12 2023 Synology.sig -rwxr-xr-x 1 root root 678 Sep 23 2023 VERSION -rw-r--r-- 1 root root 24992123 Oct 12 2023 autonano.pat -rwxr-xr-x 1 root root 8388608 Sep 23 2023 bios.ROM -rw-r--r-- 1 root root 2931 Oct 12 2023 checksum.syno -rw-r--r-- 1 root root 1302 Sep 23 2023 expired_models -rw-r--r-- 1 root root 55 Sep 23 2023 grub_cksum.syno -rw-r--r-- 1 root root 239517368 Sep 23 2023 hda1.tgz -rw-r--r-- 1 root root 6478104 Sep 23 2023 indexdb.txz -rwxr-xr-x 1 root root 917504 Sep 23 2023 oob.ROM drwxr-xr-x 2 root root 4096 Jan 1 00:01 packages -rwxr-xr-x 1 root root 40610 Sep 23 2023 platform.ini -rw-r--r-- 1 root root 7157584 Sep 23 2023 rd.gz -rw-r--r-- 1 root root 22217596 Sep 23 2023 synohdpack_img.txz -rwxr-xr-x 1 root root 16488320 Aug 30 2023 updater -rw-r--r-- 1 root root 3437904 Sep 23 2023 zImage Quote
polanskiman Posted February 8, 2024 Author #3 Posted February 8, 2024 Ok so I solved the "Failed to install DSM. Available system space is insufficient." error. I deleted entirely the upd@te directory first (which was no enough initially) and then the /var/log. I then ended up with: SynologyNAS> mount /dev/md0 /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.4G 780.3M 65% /tmp/test which was enough to allow the pat file to be uploaded and deployed without any errors Something I noticed. Anything bellow 750M/700M is no good because although the pat file size is inferior than the available space you need extra space for the file to be deployed after beeing uploaded. Below you can see how the space shrinks to 0 after the upload. I was nervous when I saw that the available space reached 0 and I was expecting once again the dreaded "Failed to install the file. The file is probably corrupt." The space was bordeline enough. SynologyNAS> mount /dev/md0 /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.4G 780.3M 65% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 383.7M 83% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 2.0G 117.4M 95% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 2.1G 108.0M 95% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 2.2G 0 100% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 373.3M 83% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 373.3M 83% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 373.3M 83% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 341.4M 85% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.9G 314.6M 86% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 395.2M 82% /tmp/test SynologyNAS> df -h /dev/md0 Filesystem Size Used Available Use% Mounted on /dev/md0 2.3G 1.8G 395.2M 82% /tmp/test SynologyNAS> Connection closed by foreign host. My problem number 1 where all volumes are crashed after a reboot is still persistent. Anyone got any clues what is happening here and how I can solve this? Quote
polanskiman Posted February 10, 2024 Author #4 Posted February 10, 2024 Problem got worse. I can't even access DSM through network anymore after a force reinstall. Looking at the console logs after a force reinstallation a get of bunch of errors such as: [FAILED] Failed to start Adjust NIC sequence. See "systemctl status SynoInitEth.service" for details. [FAILED] Failed to start Out of Band Management Status Check. See "systemctl status syno-oob-check-status.service" for details. [FAILED] Failed to start synoindex check if ... any synoindex-related packages. See "systemctl status synoindex-checkpackage.service" for details. I was able to access DSM by poking around and re-enabling the NICs by command line (through a serial cable>consol) but once I get into DSM GUI I can see DSM is not acting normally. So it looks like something got corrupt somewhere along the process. Does anyone know how I can recover from this? I would hate to have to nuke the DSM partition. This would force me to have to reinstall all apps and reconfigure everything which would be a major pain. Quote
polanskiman Posted February 10, 2024 Author #5 Posted February 10, 2024 Well since I could not figure it out and had no feedback here I decided to nuke the DSM partition (sdx1 of each drive). There it's done. 3 days trying to solve this shit. At least now it's all clean and new and the box can run again althoug still needs some configuring. Quote
klez Posted February 17, 2024 #6 Posted February 17, 2024 (edited) I'm thinking of moving to ARC loader of my old j3455 (before it was j1900) DSM 7.2-64570 installation - which was before dsm 6.0 surely - maybe even dsm 5 - I'm wondering how to check this btw - the initial dsm version. In any case I found info in ARC wiki - https://github.com/AuxXxilium/AuxXxilium/wiki#important - that dsm v6 have different partitions layout, maybe this is related to your issue @Polanskiman /dev/md0 of mine: df -h /dev/md0 Filesystem Size Used Avail Use% Mounted on /dev/md0 2.3G 1.4G 822M 63% / Edited February 17, 2024 by klez Quote
polanskiman Posted February 20, 2024 Author #7 Posted February 20, 2024 On 2/18/2024 at 3:54 AM, klez said: I'm thinking of moving to ARC loader of my old j3455 (before it was j1900) DSM 7.2-64570 installation - which was before dsm 6.0 surely - maybe even dsm 5 - I'm wondering how to check this btw - the initial dsm version. In any case I found info in ARC wiki - https://github.com/AuxXxilium/AuxXxilium/wiki#important - that dsm v6 have different partitions layout, maybe this is related to your issue @Polanskiman /dev/md0 of mine: df -h /dev/md0 Filesystem Size Used Avail Use% Mounted on /dev/md0 2.3G 1.4G 822M 63% / I was moving from DSM 7.2 to DSM 7.2.1 and I think my DSM7 install I did last year was a clean one although I can't be sure, so it could have been that. In fact, nuking the first partition was the smartest thing I could have done since all it took me was 2-3 hours of reconfiguring everything vs 3 days trying to debug something that was driving me nuts. Since I had a backup of DSM config and most of the app configs are saved in your Volume, it was just a matter of reinstalling all the apps and making sure all was configured as I wanted. Quote
HHawk Posted September 11, 2024 #8 Posted September 11, 2024 @Polanskiman and @klez I am experiencing a similar issue... Went from Jun's Loader (DSM 6.x) trying to get DSM 7.x with various loaders. ARC Loader, TinyCore Redpill (original) and TinyCore Redpill M-Shell... Well, what can I say. It was a pain to do so. Ugh. I got those annoying messages like DSM installation failed, not enough space, damaged, etc. Anyways, now I finally got TinyCore Redpill M-Shell running with DSM 7.1.x, but apparently all my settings, applications and so on are completely gone. Sigh. Data is luckily still there. I have backups of everything nevertheless (took me a couple of days to rsync everything to a temp server based on RAID 0; yeah I know, but I needed the space for the backups, so no other choice). Anyways, I checked my partition: Quote XX@DiskStation:/$ df -Th Filesystem Type Size Used Avail Use% Mounted on /dev/md0 ext4 2.3G 1.8G 440M 81% / devtmpfs devtmpfs 3.7G 0 3.7G 0% /dev tmpfs tmpfs 3.8G 232K 3.8G 1% /dev/shm tmpfs tmpfs 3.8G 16M 3.8G 1% /run tmpfs tmpfs 3.8G 0 3.8G 0% /sys/fs/cgroup tmpfs tmpfs 3.8G 748K 3.8G 1% /tmp /dev/mapper/cachedev_0 ext4 19T 7.5T 11T 41% /volume1 I also find some command online for listing all Synology partitions? Anyways: Quote XX@DiskStation:~# synopartition --list Index Version 1-Bay Size of Root/Swap/Reserved Partition 1. 1 YES 273042/ 787185/ 273042 sectors ( 133/ 384/ 133 MB) 2. 2 YES 4980087/ 1044225/ 257040 sectors ( 2431/ 509/ 125 MB) 3. 3 YES 530082/ 787185/ 16002 sectors ( 258/ 384/ 7 MB) 4. 5 YES 722862/ 594405/ 16002 sectors ( 352/ 290/ 7 MB) 5. 6 YES 4980087/ 4192965/ 257040 sectors ( 2431/ 2047/ 125 MB) 6. 7 YES 4980480/ 4194304/ 262144 sectors ( 2431/ 2048/ 128 MB) 7. 8 YES 4980480/ 4194304/ 260352 sectors ( 2431/ 2048/ 127 MB) 8. 9 YES 16777216/ 4194304/ 262144 sectors ( 8192/ 2048/ 128 MB) 9. 1 NO 1574307/ 787185/ 273105 sectors ( 768/ 384/ 133 MB) 10. 2 NO 4980087/ 1044225/ 257040 sectors ( 2431/ 509/ 125 MB) 11. 6 NO 4980087/ 4192965/ 257040 sectors ( 2431/ 2047/ 125 MB) 12. 7 NO 4980480/ 4194304/ 262144 sectors ( 2431/ 2048/ 128 MB) 13. 8 NO 4980480/ 4194304/ 260352 sectors ( 2431/ 2048/ 127 MB) 14. 9 NO 16777216/ 4194304/ 262144 sectors ( 8192/ 2048/ 128 MB) Also did fdisk, but that was a little bit too big to list here, so I attached it as an attachment (fdisk.txt). No clue if that's useful for anyone. Anyways, what's my best bet to proceed now? You mentioned nuking the DSM partition (sdx1 of each drive). A few questions about that; How did you nuke it? My data will be safe I guess. I do not mind reinstalling DSM as I currently have to redo all applications anyways. Also everything seems to be really slow and also installation and running e.g. Docker is already causing issues (cannot start). I am getting (for Docker) the message: Cannot start packet service or something (sorry translated it). Maybe there are permission errors because of the upgrade from DSM 6.x to DSM 7.x, who knows? What can you recommend? I just want to run DSM 7.x like before; I never had issues with DSM 6.x, but it was getting older and older. In the meantime I will try to update DSM to 7.2. Perhaps another shot with ARC loader. People seem to be favouring that one over TinyCore Redpill M-Shell as far as I can tell. Maybe it's even better to delete just everything and start fresh. I think I backed up everything in terms of my data and made several backups of MariaDB database and all container settings (e.g. SabNZBD, Sonarr, Radarr, Hydra2, etc.). Like you said; it will take quite some time setting up everything, but it beats to trouble shoot these issues. I also don't know if setting up a clean/fresh installation of DSM 7.2.x be different in terms of partitions, etc. I think I did a fresh install of DSM 6.x years ago (4 years ago, or even longer). Anyways, I hope you can advice me or someone else. In the meantime I will try ARC Loader and DSM 7.2 and see what happens. Thanks in advance. Regards, HHawk fdisk.txt Quote
djvas335 Posted September 12, 2024 #9 Posted September 12, 2024 I had similar issue while updating to 7.2.2, the problem is the size of the system partition going back from dsm6, dsm7 creates a larger 7.6gb partition when installed from scratch, so my solution was to backup the nas to another nas, erase the whole nas and reinstall the dsm, which created the new partition layout with a larger system partition 11 hours ago, HHawk said: @Polanskiman and @klez I am experiencing a similar issue... Went from Jun's Loader (DSM 6.x) trying to get DSM 7.x with various loaders. ARC Loader, TinyCore Redpill (original) and TinyCore Redpill M-Shell... Well, what can I say. It was a pain to do so. Ugh. I got those annoying messages like DSM installation failed, not enough space, damaged, etc. Anyways, now I finally got TinyCore Redpill M-Shell running with DSM 7.1.x, but apparently all my settings, applications and so on are completely gone. Sigh. Data is luckily still there. I have backups of everything nevertheless (took me a couple of days to rsync everything to a temp server based on RAID 0; yeah I know, but I needed the space for the backups, so no other choice). Anyways, I checked my partition: I also find some command online for listing all Synology partitions? Anyways: Also did fdisk, but that was a little bit too big to list here, so I attached it as an attachment (fdisk.txt). No clue if that's useful for anyone. Anyways, what's my best bet to proceed now? You mentioned nuking the DSM partition (sdx1 of each drive). A few questions about that; How did you nuke it? My data will be safe I guess. I do not mind reinstalling DSM as I currently have to redo all applications anyways. Also everything seems to be really slow and also installation and running e.g. Docker is already causing issues (cannot start). I am getting (for Docker) the message: Cannot start packet service or something (sorry translated it). Maybe there are permission errors because of the upgrade from DSM 6.x to DSM 7.x, who knows? What can you recommend? I just want to run DSM 7.x like before; I never had issues with DSM 6.x, but it was getting older and older. In the meantime I will try to update DSM to 7.2. Perhaps another shot with ARC loader. People seem to be favouring that one over TinyCore Redpill M-Shell as far as I can tell. Maybe it's even better to delete just everything and start fresh. I think I backed up everything in terms of my data and made several backups of MariaDB database and all container settings (e.g. SabNZBD, Sonarr, Radarr, Hydra2, etc.). Like you said; it will take quite some time setting up everything, but it beats to trouble shoot these issues. I also don't know if setting up a clean/fresh installation of DSM 7.2.x be different in terms of partitions, etc. I think I did a fresh install of DSM 6.x years ago (4 years ago, or even longer). Anyways, I hope you can advice me or someone else. In the meantime I will try ARC Loader and DSM 7.2 and see what happens. Thanks in advance. Regards, HHawk fdisk.txt 8.39 kB · 0 downloads Quote
Stalnoff Posted April 8 #10 Posted April 8 (edited) Hi! After the flash drive failed and several attempts to install ARC (the "next" version, then the old one, because DSM didn't work correctly on the "next", and I didn't want to reinstall it), I had the same problem: Цитата Failed to install DSM. Available system space is insufficient. But I found a solution on ARC Wiki how to free the system space. To do this, you need: USB Flash with ARC Next version (I did this on version 2.0.2) Boot in DSM Recovery Mode Go to: http://ip:5000/webman/clean_system_disk.cgi Done! I hope this helps someone! Edited April 8 by Stalnoff Quote
DSfuchs Posted April 8 #11 Posted April 8 Beforehand, you would normally take a larger data hard drive. Set it up with an 8GB partition scheme and mirror the old system partition onto it. Then expand the ext4 file system to 8GB. Otherwise, as happened in my case, a lot of data would be lost. Because this isn't even recorded in a full backup. Quote
Stalnoff Posted April 9 #12 Posted April 9 (edited) http://ip:5000/webman/clean_system_disk.cgi leaves the data unchanged, only deletes unnecessary data. Edited April 9 by Stalnoff Quote
