There were following problems when using ISCSI
1) Connection of ISCSI of a target happens rather long time from 1 to 5 min.
2) When copying big files everything is normal, but if to copy on iscsi a disk files of the small volume (kb) that copying can reach for hours
3) Also when copying small files sometimes there is a lag then only disconnection from a target helps
If who knows the solution of this problem I will be very grateful...
The storage is brought together on the supermicro server with network optical interfaces therefore connection of iscsi happens on 10G to the interface
