Добрый день!
Dual-Core AMD Opteron(tm) Processor 2212
Встроенный SATA Marvell. В БИОС выставляется только режим АТА.
Использовал несколько загрузчиков.
ARPL, ARС, TCRP - Загрузка доходит до Booting the kernel. Захожу по IP:5000 но диски не находятся "No Drives Detected".
Также пробовал RAID контроллер, но результат такой же.
--------------------------------------={ TinyCore RedPill Friend }=-------------------------------------- TCRP Friend Version : 0.0.9 0.0.8g Added retry processing when downloading rp-lkms.zip of ramdisk patch fails 0.0.8h When performing Ramdisk Patch, check the IP grant status before proceeding. Thanks ExpBox. 0.0.9 Added IP detection function on multiple ethernet devices IP Detecting on eth0 IP Address : 192.168.10.121, Module Processing Method : DDSML Detecting upgrade : Ramdisk OK ! zImage OK ! Checking for latest friend -> OK, latest Loader BUS: usb Running on 4 Processor Dual-Core AMD Opteron(tm) Processor 2212 With 1.9G Memory System has 0 SAS/RAID HBAs and 2 Network cards System is running in Legacy boot mode Model : DS723+, Serial : 2270TQRMAXPFL, Mac : 00188B77519C, DSM Version : 7.2.1-69057, Update : 0, RedPillMake : prod zImage : /mnt/tcrp/zImage-dsm initrd : /mnt/tcrp/initrd-dsm cmdline : withefi disable_mtrr_trim=1 earlyprintk syno_hw_version=DS723+ console=ttyS0,115200n8 netif_num=2 synoboot2 pid=0xc95a earlycon=uart8250,io,0x3f8,115200n8 mac2=00188B77519D mac1=00188B77519C sn=2270TQRMAXPFL SMBusHddDynamicPower=1 vid=0x125f elevator=elevator loglevel=15 DiskIdxMap vender_format_version=2 log_buf_len=32M root=/dev/md0 SataPortMap syno_ttyS1=serial,0x2f8 syno_ttyS0=serial,0x3f8 Access http://192.168.10.121:7681 via the TTYD web terminal to check the problem. (If you have any problems with the DSM installation steps, check the /var/log/linuxrc.syno.log file in this access) Default TTYD root password is blank
До загрузки DSM
root@tcrpfriend:~fdisk -l Disk /dev/sda: 3.76 GiB, 4040748544 bytes, 7892087 sectors Disk model: USB Flash Drive Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf110ee87 Device Boot Start End Sectors Size Id Type /dev/sda1 * 2048 147455 145408 71M 83 Linux /dev/sda2 147456 301055 153600 75M 83 Linux /dev/sda3 301056 2097151 1796096 877M 83 Linux Disk /dev/sdb: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors Disk model: HGST HDN724040AL Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: 8BBD78AE-5304-BB4C-963E-4B8EC06708DB Disk /dev/sdc: 3.64 TiB, 4000787030016 bytes, 7814037168 sectors Disk model: HGST HDN724040AL Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: gpt Disk identifier: B1990E24-817F-414D-9CB4-D38AD70E2428 root@tcrpfriend:~#
После загрузки "Junior mode"
SynologyNAS> lspci -k 0000:00:01.0 Class 0604: Device 1166:0036 0000:00:02.0 Class 0600: Device 1166:0205 Subsystem: Device 1166:0201 0000:00:02.2 Class 0601: Device 1166:0234 Subsystem: Device 1028:01eb 0000:00:03.0 Class 0c03: Device 1166:0223 (rev 01) Subsystem: Device 1028:01eb 0000:00:03.1 Class 0c03: Device 1166:0223 (rev 01) Subsystem: Device 1028:01eb 0000:00:03.2 Class 0c03: Device 1166:0223 (rev 01) Subsystem: Device 1028:01eb Kernel driver in use: ehci-pci 0000:00:04.0 Class 0300: Device 1002:515e (rev 02) Subsystem: Device 1028:01eb 0000:00:07.0 Class 0604: Device 1166:0140 (rev a2) Kernel driver in use: pcieport 0000:00:08.0 Class 0604: Device 1166:0142 (rev a2) Kernel driver in use: pcieport 0000:00:09.0 Class 0604: Device 1166:0144 (rev a2) Kernel driver in use: pcieport 0000:00:0a.0 Class 0604: Device 1166:0142 (rev a2) Kernel driver in use: pcieport 0000:00:0b.0 Class 0604: Device 1166:0144 (rev a2) Kernel driver in use: pcieport 0000:00:18.0 Class 0600: Device 1022:1100 0000:00:18.1 Class 0600: Device 1022:1101 0000:00:18.2 Class 0600: Device 1022:1102 0000:00:18.3 Class 0600: Device 1022:1103 0000:00:19.0 Class 0600: Device 1022:1100 0000:00:19.1 Class 0600: Device 1022:1101 0000:00:19.2 Class 0600: Device 1022:1102 0000:00:19.3 Class 0600: Device 1022:1103 0000:01:00.0 Class 0200: Device 14e4:1659 (rev 21) Subsystem: Device 1028:01eb Kernel driver in use: tg3 0000:02:00.0 Class 0200: Device 14e4:1659 (rev 21) Subsystem: Device 1028:01eb Kernel driver in use: tg3 0000:03:0d.0 Class 0604: Device 1166:0104 (rev c0) 0000:03:0e.0 Class 0101: Device 1166:024b Subsystem: Device 1028:01eb 0000:06:00.0 Class 0604: Device 8086:032c (rev 09) 0000:07:08.0 Class 0100: Device 1000:0054 (rev 01) Subsystem: Device 1028:1f06 Kernel driver in use: mptsas 0001:01:00.0 Class 0106: Device 1b4b:9235 (rev 11) SynologyNAS>
SynologyNAS> fdisk -l Disk /dev/synoboot: 3853 MB, 4040748544 bytes, 7892087 sectors 1018 cylinders, 125 heads, 62 sectors/track Units: sectors of 1 * 512 = 512 bytes Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type /dev/synoboot1 * 0,32,33 9,45,36 2048 147455 145408 71.0M 83 Linux Partition 1 has different physical/logical start (non-Linux?): phys=(0,32,33) logical=(0,33,3) Partition 1 has different physical/logical end: phys=(9,45,36) logical=(19,3,20) /dev/synoboot2 9,45,37 18,188,42 147456 301055 153600 75.0M 83 Linux Partition 2 has different physical/logical start (non-Linux?): phys=(9,45,37) logical=(19,3,21) Partition 2 has different physical/logical end: phys=(18,188,42) logical=(38,105,46) /dev/synoboot3 18,188,43 130,138,8 301056 2097151 1796096 877M 83 Linux Partition 3 has different physical/logical start (non-Linux?): phys=(18,188,43) logical=(38,105,47) Partition 3 has different physical/logical end: phys=(130,138,8) logical=(270,75,2) SynologyNAS>
на AMD по моему только одну модель можно поставить
ну по крайне мере я сходу смог поставить.
вот я ставил на AMD
- Результат: Успешно   (DS2422+)
- Версия и модель загрузчика: arpl-latest
- Версия DSM:  DSM 7.1.1-42962 Update 1
- Аппаратное решение: Bare Metal, Supermicro H11SSL-i, AMD EPYC 7551P, 128Gb RAM EСC Kingston 2400
пробовал поставить 3622+ не взлетела, 2422+ взлетела сразу без проблема,
установка - запуск загрузчика, выбор модели, генерация серийника, билд загрузчика и загрузка - ВСЕ
Вряд ли буду рассматривать эту конфигурацию как постоянную - так был просто интерес взлетит или нет.
32 ядра и 128 памяти как то не разумно тратить на NAS - если только не поднимать на нем кучу виртуалок.
Поставил VMM - видит только 16 ядер из 32.
3 часа назад, -iliya- сказал:
СПАСИБО. Попробовал установить с ARPL, DS3622xs+, Версия DSM:  DSM 7.1.1-42962, addon добавил lsiutil и все получилось. SATA отключил и вернул диски на DELL LSI контроллер.
Привет немного офтоп.
Поставил ARC - loader latest, DSM 7.2  DS923+. На Hp ProLian N40L(AMD Athlon II Neo N40L 1.5 GHz 8GB DDR3 AMD SATA controller). Полет стабилен. Но со временем возникла проблема, система не видит внешних устройств, хотя раньше спокойно монтировала как флешки так и диски подключенные по usb. Причем если зайти в консоль и проверить по lsusb все показывается, если вручную примонтировать в какую-нибудь папку то также можно просмотреть файлы, и даже покажет сообщение что диск заполнен(флешка почти под заязку). Это касается как тех флешек что подключал раньше так и новых. Подскажите куда копать.
