recon55 Posted August 25 Share #1 Posted August 25 I tried with an older arpl loader and I did not have an issue with earlier versions of DSM 7. Using arpl-i18n with an external usb drive for an internal drive seems to to be broken with DSM 7.2. Any suggestion? Quote Link to comment Share on other sites More sharing options...
TJemuran Posted August 26 Share #2 Posted August 26 You can switch to arc loader, which is base on arpl. In ARC you can choose usb mode, as internal drive or normal usb. Quote Link to comment Share on other sites More sharing options...
Rayqusa Posted August 28 Share #3 Posted August 28 (edited) On 8/26/2023 at 5:03 PM, TJemuran said: You can switch to arc loader, which is base on arpl. In ARC you can choose usb mode, as internal drive or normal usb. dimana cari Arc loader? bagi link kak Edited August 28 by Rayqusa please share the link Quote Link to comment Share on other sites More sharing options...
TJemuran Posted August 28 Share #4 Posted August 28 3 hours ago, Rayqusa said: dimana cari Arc loader? bagi link kak Sedot gan: https://github.com/AuxXxilium/arc 1 Quote Link to comment Share on other sites More sharing options...
recon55 Posted August 28 Author Share #5 Posted August 28 On 8/26/2023 at 6:03 AM, TJemuran said: You can switch to arc loader, which is base on arpl. In ARC you can choose usb mode, as internal drive or normal usb. Is there a special option I am missing. I still can't seem to get it to work. Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
recon55 Posted September 4 Author Share #6 Posted September 4 On 8/28/2023 at 10:47 AM, recon55 said: Is there a special option I am missing. I still can't seem to get it to work. Any help is appreciated. Guess I just have to use a model that is not Device Tree driven. Quote Link to comment Share on other sites More sharing options...
Marawan Posted September 16 Share #7 Posted September 16 On 8/26/2023 at 1:03 PM, TJemuran said: You can switch to arc loader, which is base on arpl. In ARC you can choose usb mode, as internal drive or normal usb. I tried what you said with latest ARC, still USB drives show as fixed drives! Quote Link to comment Share on other sites More sharing options...
recon55 Posted September 16 Author Share #8 Posted September 16 What DSM version are you using? I've been successful with several different models using ARC Loader. Quote Link to comment Share on other sites More sharing options...
TJemuran Posted September 18 Share #9 Posted September 18 On 9/17/2023 at 3:27 AM, Marawan said: I tried what you said with latest ARC, still USB drives show as fixed drives! After some research using newer hardware, indeed ARC loader usb mode doesn't work properly as standard usb mount instead of usb internal drive. But, this work with older CPU gen. Quote Link to comment Share on other sites More sharing options...
Marawan Posted September 18 Share #10 Posted September 18 16 hours ago, TJemuran said: After some research using newer hardware, indeed ARC loader usb mode doesn't work properly as standard usb mount instead of usb internal drive. But, this work with older CPU gen. My Test CPU Ivy Bridge E i7-4930 is 10 years old!! Quote Link to comment Share on other sites More sharing options...
wjz304 Posted September 21 Share #11 Posted September 21 https://github.com/wjz304/arpl-i18n/issues/226 Quote Link to comment Share on other sites More sharing options...
