Patching DeviceTree to set port as eSATA?
I decided to try 1621+ on my N54L, and it worked well enough, but eSATA drive that I use for backups got recognized as internal. Before that, on 3622xs+, I used these lines in synoinfo:
"internalportcfg": "0x2f",
"esataportcfg": "0x10",
"usbportcfg": "0x1fc0",
I saw some mentions that "you'll have to patch/build device tree manually" but couldn't find any actual information on how to actually do that.
  • 2 months later...
In the Device-Tree based model, it includes the following nodes
You need to configure the model.dtb file.
	esata_port@1 {
		ahci {
			pcie_root = "00:13.0,00.0";
			ata_port = <0x3>;
*portcfg related settings are only used in Non DT based models.
I looked at the addons of the current Redfill loaders.
I am applying and following most of the scripts in the disks addon.
However, parts related to esata nodes are not supported.
I will modify and test it in TCRP to provide support if possible.
I'll have to look for a laptop with eSATA first.
Reporting is a little late.
A few days ago, I purchased the product below and tried it out.
https://www.ebay.co.uk/itm/385760379322
Tested on DT-based ds920+.
esata does not separate it into a separate device tree.
It is considered one of the sata ports.
As a result as below, model.dts and model.dtb are converted via the dtbpatch add-on..
It has been confirmed that it is created automatically.
No separate work is required on synoinfo.conf or model.dtb.
The add-on maps the disk automatically.
SynologyNAS> ll /sys/block | grep -e sata -e sd
lrwxrwxrwx    1 root     root             0 Sep  7 13:32 sata1 -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sata1
Running "install.sh" for dtbpatch->on_boot->modules
dtbpatch - modules
'dtc' -> '/usr/sbin/dtc'
'readlink' -> '/usr/sbin/readlink'
Patching /etc.defaults/
ls: /sys/bus/usb/devices/usb*: No such file or directory
/dts-v1/;
    compatible = "Synology";
    model = "synology_geminilake_920+";
    version = <0x01>;
    internal_slot@1 {
        protocol_type = "sata";
        ahci {
            pcie_root = "00:1f.2";
            ata_port = <0x04>;
backup /etc.defaults/model.dtb to model_bak.dtb
'/etc.defaults/model.dtb' -> '/etc.defaults/model_bak.dtb'
/var/run/model.dts:6.21-12.7: Warning (unit_address_vs_reg): /internal_slot@1: node has a unit name, but no reg or ranges property
'/etc.defaults/model.dtb' -> '/run/model.dtb'
System Disk: (not supported in junior mode)
Internal Disk
01: /dev/sata1
02:
03:
04:
05:
06:
07:
08:
09:
10:
11:
12:
13:
14:
15:
16:
Esata port count: 0
USB Device
Ran "install.sh" for dtbpatch->on_boot->modules - exit=0
Edited by Peter Suh
  • Like 2
  • 4 weeks later...
Okay, reporting with my results (success). Used arpl-i18n 23.9.7. See general instructions here: https://github.com/wjz304/arpl-i18n/issues/226
First, grab device tree compiler https://github.com/wjz304/arpl-i18n/files/12665011/dtc_win.zip or, if using it in in DSM, from https://github.com/wjz304/arpl-addons/tree/main/disks/all/usr/bin
(probably recommended) Connect drive and reboot so it loads into device tree.
Download current device tree from your system as described in guide (decompile /etc/model.dtb and download resulting .dts)
For your eSATA drive replace internal_slot@N with esata_slot@1.
For example, with HP Microserver gen7 eSATA is #5 on controller (with #6 supposed to be ODD):
	internal_slot@4 {
		ahci {
			pcie_root = "00:11.0";
			ata_port = <0x03>;
	internal_slot@5 {
		ahci {
			ata_port = <0x04>;
Change to:
	internal_slot@4 {
		ahci {
			ata_port = <0x03>;
	esata_port@1 {
		ahci {
			ata_port = <0x04>;
Then rebuild loader, in arpl-i18n in advanced config there's option to upload custom .dts.
That's it.
