raeesumer Posted May 24 Share #1 Posted May 24 (edited) https://www.synology.com/en-global/releaseNote/DSM Spoiler Version: 7.2-64561 (2023-05-22) Important Note After installing this update, you will not be able to downgrade to a previous DSM version. This update will restart your Synology NAS. Starting from this version, logs for drives will no longer appear in Storage Manager > HDD and will be available only in Log Center. Removed the "Automatically create port forwarding rules" option from QuickConnect advanced settings to increase network security. Users can now create a Btrfs volume of up to 1 PB on specific Synology NAS models. This update automatically converts existing volumes that use the Btrfs (Peta Volume) file system to Btrfs. However, to create a volume larger than 200 TB, a RAID 6 storage pool and at least 64 GB of system memory are still required.Learn more The maximum single volume size supported by RS2423+/RS2423RP+ has been adjusted to 200 TB (with a minimum system memory requirement of 32 GB). Starting from this version, only Windows Server 2008 R2 and above versions will be supported. After installing this update, the current Windows Server 2008 domain and earlier versions will be unavailable. For the models below, you can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM. FS Series: FS3017, FS2017, FS1018 XS Series: RS18016xs+, RS4017xs+, RS3617xs+, RS3617xs, RS3617RPxs, RS18017xs+, DS3617xs, DS3617xsII, DS3018xs Plus Series: RS2416RP+, RS2416+, DS916+, DS716+II, DS716+, DS216+II, DS216+, DS1817+, DS1517+, RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS218+, RS1219+ Value Series: DS416, DS416play, DS216, DS216play, DS116, RS816, DS1817, DS1517, RS217, DS418play J Series: DS416slim, DS416j, DS216j, DS418j, DS218j, DS419slim, DS119j What’s New Added support for WriteOnce shared folders. This feature is based on the Write Once, Read Many (WORM) technology and can be enabled to prevent files from being modified, deleted, or renamed for a specified period. Added support for volume encryption. All volume encryption keys are stored in the Encryption Key Vault, which can be set up on a local Synology NAS or via KMIP on a remote Synology NAS. Added more Synology NAS models to support M.2 NVMe SSD storage pools. Learn more Added more Synology NAS models to support the M2D18 adapter card: RS822RP+, RS822+, RS1221RP+, and RS1221+. Added more SSD cache group management options, including changing the RAID type and replacing a drive. Added support for inline zero-block removal to increase the efficiency of data deduplication. Adjusted how drive information is presented in Storage Manager. Users can now quickly check the condition of their drives by looking at the "Drive Status" field. Users can now view the amount of used and free space for each storage pool and volume in Storage Manager. Added a warning notification for when the available shared folder quota is low. Supports deleting individual desktop notifications. Supports sending DSM notifications via additional webhook providers, including LINE and Microsoft Teams. Supports creating custom notification rules for system events, giving users greater control over what notifications to receive. Supports exporting a list of users and of groups. Added support for SAML to integrate DSM with external SSO servers. Added the option to allow non-admin users to safely eject USB devices. Users can now manually input the IP addresses or FQDNs of one or more domain controllers in the trusted domain. This allows Synology NAS to sync domain data directly with the specified domain controllers. Users can now enable Synology's email server to send DSM notifications directly to their Synology Account. Fixed Issues Fixed an issue where adding drives to a JBOD storage pool did not expand its capacity. Updated Mbed-TLS to version 2.28.2 to fix multiple security vulnerabilities (CVE-2021-36647, CVE-2022-46392, CVE-2022-46393). Updated Libksba to version 1.6.3 to fix a security vulnerability (CVE-2022-3515). Updated SQLite to version 3.40.0 to fix a security vulnerability (CVE-2022-46908). Updated Certifi to version 2022.12.07 to fix a security vulnerability (CVE-2022-23491). Updated Node.js to version 14.21.1 to fix a security vulnerability (CVE-2022-43548). Updated cURL to version 7.86.0 to fix multiple security vulnerabilities (CVE-2022-27774, CVE-2022-27775, CVE-2022-27776, CVE-2022-27781, CVE-2022-27782, CVE-2022-32205, CVE-2022-32206, CVE-2022-32207, CV E-2022-32221, CVE-2022-35252, CVE-2022-42915, CVE-2022-42916). Updated PHP to version 8.1.9 to fix multiple security vulnerabilities (CVE-2019-11043, CVE-2021-21705, CVE-2022-31625). Updated Sysstat to version 12.7.1 to fix a security vulnerability (CVE-2022-39377). Updated OpenSSL to version 3.0.7 to fix multiple security vulnerabilities (CVE-2022-2068, CVE-2022-2097, CVE-2022-2274, CVE-2022-3358, CVE-2022-3602, CVE-2022-3786). Updated Expat to version 2.5.0 to fix a security vulnerability (CVE-2022-43680). Updated Libtirpc to version 2.87 to fix a security vulnerability (CVE-2021-46828). Updated GnuPG to version 2.2.39 to fix a security vulnerability (CVE-2022-34903). Updated OpenVPN to version 2.5.8 to fix a security vulnerability (CVE-2022-0547). Updated libxml2 to version 2.9.14 to fix a security vulnerability (CVE-2022-23308). Updated GMP to version 6.2.1 to fix a security vulnerability (CVE-2021-43618). Updated ImageMagick to version 6.9.12-61 to fix multiple security vulnerabilities (CVE-2020-25664, CVE-2020-25665, CVE-2020-25666, CVE-2020-25667, CVE-2020-25674, CVE-2020-25675, CVE-2020-25676, CVE-2020-27560, CVE-2020-27750, CVE-2020-27751, CVE-2020-27752, CVE-2020-27753, CVE-2020-27754, CVE-2020-27755, CVE-2020-27756, CVE-2020-27757, CVE-2020-27758, CVE-2020-27759, CVE-2020-27760, CVE-2020-27761, CVE-2020-27762, CVE-2020-27763, CVE-2020-27764, CVE-2020-27765, CVE-2020-27766, CVE-2020-27767, CVE-2020-27768, CVE-2020-27769, CVE-2020-27770, CVE-2020-27771, CVE-2020-27772, CVE-2020-27773, CVE-2020-27774, CVE-2020-27775, CVE-2020-27776, CVE-2020-29599, CVE-2021-20176, CVE-2021-20224, CVE-2021-20241, CVE-2021-20245, CVE-2021-20246, CVE-2021-20309, CVE-2021-3574, CVE-2021-3596, CVE-2021-39212, CVE-2021-4219, CVE-2022-1114, CVE-2022-1115, CVE-2022-28463, CVE-2022-32545, CVE-2022-32546, CVE-2022-32547). Updated FFmpeg to version 4.1.9 to fix multiple security vulnerabilities (CVE-2020-20892, CVE-2020-20902, CVE-2020-21688, CVE-2020-21697, CVE-2021-3566, CVE-2021-38114, CVE-2021-38291). Fixed a security vulnerability regarding Netatalk (CVE-2022-45188). Fixed multiple security vulnerabilities regarding Python3 (CVE-2020-10735, CVE-2021-28861, CVE-2022-45061). Fixed multiple security vulnerabilities regarding iproute2 (CVE-2022-3527, CVE-2022-3529, CVE-2022-3530). Fixed multiple security vulnerabilities regarding D-Bus (CVE-2022-42010, CVE-2022-42011, CVE-2022-42012). Fixed a security vulnerability regarding syslog-ng (CVE-2022-38725). Fixed a security vulnerability regarding inetutils (CVE-2022-39028). Fixed a security vulnerability regarding DNSmasq (CVE-2022-0934). Fixed a security vulnerability regarding BusyBox-udhcp (CVE-2019-5747). Fixed multiple security vulnerabilities regarding Linux Kernel (CVE-2021-22600, CVE-2021-38209, CVE-2021-4037, CVE-2022-0168, CVE-2022-1016, CVE-2022-1729, CVE-2022-1786, CVE-2022-20141, CVE-2022-20368, CVE-2022-2078, CVE-2022-2639, CVE-2022-2905, CVE-2022-29581, CVE-2022-32250, CVE-2022-3524, CVE-2022-3566, CVE-2022-3567, CVE-2022-36879, CVE-2022-36946, CVE-2022-42703). Fixed a security vulnerability regarding Nginx (CVE-2022-3638). Fixed a security vulnerability regarding ghostscript (CVE-2023-28879). Fixed a security vulnerability regarding curl (CVE-2023-23916). Limitation S.M.A.R.T. testing for M.2 NVMe SSDs is no longer supported. Starting from DSM 7.2 Beta, Virtual Machine Manager will no longer support creating clusters with older DSM versions. Please update each host in the cluster to the same DSM version or above versions for the Virtual Machine Manager cluster to operate properly. Edited May 24 by Polanskiman Added missing tags and corrected link Quote Link to comment Share on other sites More sharing options...
Polanskiman Posted May 24 Share #2 Posted May 24 This is major update. I implore anyone trying to update to DSM 7.2 not to do it first hand on a production machine. First try on a test setup. 2 Quote Link to comment Share on other sites More sharing options...
Orphée Posted May 24 Share #3 Posted May 24 (edited) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: arpl-i18n 23.5.8 SA6400 - Using custom extra.lzma: NO - Installation type: Proxmox VM - Additional comments: proxmox vm.conf args set as USB key (sata boot does not work with SA6400) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: arpl-i18n 23.5.8 DVA3221 - Using custom extra.lzma: NO - Installation type: Proxmox VM - Additional comments: NO Edited May 24 by Orphée Quote Link to comment Share on other sites More sharing options...
Biocef Posted May 24 Share #4 Posted May 24 (edited) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TinyCore RedPill v0.9.4.3 with Friend (mshell) - DS3622xs+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - Asrock H67M-ITX - Additional comments: Manual update from the DSM GUI. New DSM alert: "Unverified drive" and "Unsupported memory" warning (never shown before this 7.2 version) (Solved with "Synology HDD db" script from 007revad's github) Edited May 24 by Biocef Quote Link to comment Share on other sites More sharing options...
Sonnenblume Posted May 24 Share #5 Posted May 24 (edited) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: arpl-i18n 23.5.8, DS 920+ - Using custom extra.lzma: NO - Installation type: bare metal (hardware details in my signature) - Additional comments: Before I used another Loader: arpl-v1.1-beta2a. For updating from 7.1.1U5 to 7.2 I used arpl-i18n 23.5.8 Edited May 25 by Polanskiman Additional comment from user 1 Quote Link to comment Share on other sites More sharing options...
m3rlin76 Posted May 24 Share #6 Posted May 24 - Outcome of the update: SUCCESSFUL - DSM version prior update: ARC v23.5.x DS3622xs+ DSM 7.2 RC 64551 - Loader version and model: ARC v23.5.53 DS3622xs+ DSM 7.2 64561 - Installation type: ESX 6.5 on HPE Microserver Gen 8 with passthrough USB3 controller Quote Link to comment Share on other sites More sharing options...
Al lex Posted May 24 Share #7 Posted May 24 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TinyCore RedPill v0.9.4.3 with Friend (mshell) - DS918+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - Asus z370m 6hdd + marvel 4 hdd - Additional comments: updated manualy, got config with no sata mapping and no rtl8125. Thus marvel hdds were lost and pci-e 2.5gb lan stopped working. Made a New build in MShell. All came back to normal Quote Link to comment Share on other sites More sharing options...
kutaxov Posted May 24 Share #8 Posted May 24 - Outcome of the update: SUCCESSFUL - DSM version prior update: arpl-v1.1-beta2a, DSM 7.1.1-42962 Update 5 - Loader version and model: arpl-i18n 23.5.8, DS 920+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - ASRock J5040-ITX - Additional comments: Manual update from the DSM GUI 1 Quote Link to comment Share on other sites More sharing options...
Orphée Posted May 24 Share #9 Posted May 24 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: arpl-i18n 23.5.8 DS3622xs+ - Using custom extra.lzma: NO - Installation type: ESXi 7.0 - Additional comments: NO Quote Link to comment Share on other sites More sharing options...
real3x Posted May 25 Share #10 Posted May 25 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 // ARPL v0.4-alpha5 DS918+ - Loader version and model: arpl-i18n 23.5.8 DS918+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - GA-J3455N-D3H - Additional comments: Recreate USB loader with only serial and mac1/2 from real syno 918+ (config the loader via SSH, web console freezed) // Update via GUI with PAT file from syno // onboard LAN is ok - HW transcode is ok 1 Quote Link to comment Share on other sites More sharing options...
Huey_Pilot Posted May 26 Share #11 Posted May 26 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TinyCore RedPill v0.9.4.3 with Friend (mshell) - DS3622xs+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - THECUS N4200ECO - Additional comments: NO - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TinyCore RedPill v0.9.4.3 with Friend (mshell) - DS3622xs+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - QNAP TS-453A - Additional comments: NO Quote Link to comment Share on other sites More sharing options...
fannoute Posted May 26 Share #12 Posted May 26 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: arpl-i18n 23.5.8 DS3622xs+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - HP MediaSmart Server EX490 (Xeon E3110 / 2Gb RAM) - Additional comments: NO Quote Link to comment Share on other sites More sharing options...
turbolars Posted May 28 Share #13 Posted May 28 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TinyCore RedPill v0.9.4.6 with Friend - DS3622xs+ - Using custom extra.lzma: NO - Installation type: Vmware ESXi 8.0 - Additional comments: updated from tinycore 09.4.3, replaced rp image in vmconfig, rebuild, start, dsm detected move nas, pat install, done. Quote Link to comment Share on other sites More sharing options...
ozef Posted May 28 Share #14 Posted May 28 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TinyCore RedPill v0.9.4.6 with Friend - DS918+ - Using custom extra.lzma: NO - Installation type: Baremetal - Additional comments: * Manually install 7.2 * reboot, wait for "synology is recoverable" * Shutdown * Rebuild usb key with TCRP 0.9.4.6 * ./rploader.sh update now * ./rploader.sh fullupgrade now * ./rploader.sh serialgen DS918+ realmac * ./rploader.sh identifyusb now * ./rploader.sh satamap now * ./rploader.sh backup * ./rploader.sh build ds918p-7.2.0-64561 withfriend * ./rploader.sh backup * exitcheck.sh reboot 4 2 Quote Link to comment Share on other sites More sharing options...
Flautista1988 Posted May 28 Share #15 Posted May 28 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 (ARLP 1.1 b2) - Loader version and model: DS3622xs+ - arpl-i18n 23.5.8 - Using custom extra.lzma: NO - Installation type: BAREMETAL - Additional comments: USB loader, updated and rebuilded with arpl-i18n 23.5.8 Quote Link to comment Share on other sites More sharing options...
AlexFullmoon Posted May 28 Share #16 Posted May 28 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 1 / TCRP 0.9.2.7 / DS3622xs+ - Loader version and model: Arc 23.5.102 / DS1621+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - HP Microserver Gen 7 - Additional comments: Had to change USB drive, apparently it was too slow for Arc. Quote Link to comment Share on other sites More sharing options...
haldi Posted May 28 Share #17 Posted May 28 (edited) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 (ARPL v0.5 Alpha 1) - Loader version and model: ARC Loader v23.5.64 DS3622xs+ - Installation type: Baremetal HP Microserver Gen 8 - Additional comments: Don't select any Addons or Modules in Arc Loader. Might break Network. Edited May 28 by haldi Quote Link to comment Share on other sites More sharing options...
dim2002 Posted May 30 Share #18 Posted May 30 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 2 - Loader version and model: arpl-i18n 23.5.8, DS3622xs+ - Using custom extra.lzma: NO - Installation type: bare metal - Additional comments: Before I used another Loader: arpl-v1.1-beta2a. For updating from 7.1.1U5 to 7.2 I used arpl-i18n 23.5.8 Quote Link to comment Share on other sites More sharing options...
keqas78 Posted May 30 Share #19 Posted May 30 - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 (TCRP v0.9.4.3 with Friend 0.0.4 - DS3622xs+) - Loader version and model: TCRP v0.9.4.6 with Friend 0.0.5 - DS3622xs+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - HP ProLiant MicroServer Gen8 1 Quote Link to comment Share on other sites More sharing options...
wessu Posted May 30 Share #20 Posted May 30 (edited) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 1 - Loader version and model: TinyCore RedPill v0.9.4.6 with Friend - DS918+ - Using custom extra.lzma: NO - Installation type: Baremetal - Additional comments: * Manually install 7.2 * reboot, wait for "synology is recoverable" * Shutdown * Rebuild usb key with TCRP 0.9.4.6 * ./rploader.sh update now * ./rploader.sh fullupgrade now * ./rploader.sh serialgen DS918+ realmac * ./rploader.sh identifyusb now * ./rploader.sh satamap now * ./rploader.sh backup * ./rploader.sh build ds918p-7.2.0-64561 withfriend * ./rploader.sh backup * exitcheck.sh reboot - Additional comments: I tried v0.9.4.2 initially and even with updating it via the command it did not work. I had to start all over again and create another boot loader with v0.9.4.6 and it worked. @ozef Thank you for the steps! they helped me a lot. Edited May 30 by wessu 1 1 Quote Link to comment Share on other sites More sharing options...
DoganReis Posted May 31 Share #21 Posted May 31 - Outcome of the update: SUCCESSFUL - DSM version prior update: Fresh Install - Loader version and model: arpl-i18n 23.5.8 DS2422+ - Using custom extra.lzma: NO - Installation type: Proxmox VM - Additional comments: proxmox vm.conf file added sata hdd Quote Link to comment Share on other sites More sharing options...
newuser7 Posted June 1 Share #22 Posted June 1 Outcome of the update: SUCCESSFUL DSM version prior update: DSM 7.1.1-42962 Update 5 on ARPL v1.1 beta Loader version and model: ARPL-i18n 23.5.8 DS3622xs+ Using custom extra.lzma: NO Installation type: Baremetal - ASRock J5040-ITX Additional comments: Recreate USB boot drive with ARPL-i18n 23.5.8 Build boot loader (select model, build etc) reboot Follow prompt for upgrade from browser 1 1 Quote Link to comment Share on other sites More sharing options...
nicoueron Posted June 1 Share #23 Posted June 1 Outcome of the update: SUCCESSFUL DSM version prior update: DSM 7.1.1-42962 Update 5 on ARPL v1.1 beta Loader version and model: ARPL-i18n 23.5.10 DS920+ Using custom extra.lzma: NO Installation type: Baremetal - Intel core i7 - 10Go RAM Additional comments: Recreate USB boot drive with ARPL-i18n 23.5.10 Build boot loader (select model, SN, Mac, build) reboot Follow prompt for upgrade from browser just need to reactivate Advcanced Media Extensions (AME 1.1.0-51005) and uninstall NodeJS v12 beacause now it's NodeJS 18) 1 Quote Link to comment Share on other sites More sharing options...
David Rollin Posted June 2 Share #24 Posted June 2 Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.2-64561 - Loader version and model: TinyCore RedPill v0.9.4.3 with Friend - DS3622xs+ - Using custom extra.lzma: NO - Installation type: BAREMETAL - supermicro x10sdv-6c-tln4f - Additional comments: shows unverified drives - Storage pool contains one or more unverified drives- raid 5 array is ok but have to perform a benchmak test Quote Link to comment Share on other sites More sharing options...
shibby Posted June 3 Share #25 Posted June 3 (edited) - Outcome of the update: SUCCESSFUL - DSM version prior update: DSM 7.1.1-42962 Update 5 - Loader version and model: TCRP M-Shell Menu DS920+ (Friend) - Using custom extra.lzma: NO - Installation type: Proxmox VM - Additional comments: have to update M-Shell scripts and re-build loader. That`s all. Edited June 3 by shibby 1 Quote Link to comment Share on other sites More sharing options...
