jurgenautt Posted February 18, 2017 #1 Posted February 18, 2017 Hi, I have a nas with an asus h87i-plus mini-itx board Has 6sata and I put a controller lsi sas3041e of 4 sata I have it mounted on a silverstone box DS380, 8 discs I recently updated to version 6.0 and everything is correct The problem I have is that I needed to have more discs, I chose to buy The sharkoon external disk box 5, with esata and usb connection Remove the controller lsi and put a controller of startech pexesata2, 2 external pciex ports esata I connected the cable, and I configured in non-raid mode the rear switch configuration box External. I put 5 sata disks in the sharkoon box I start the nas, it detects the six discs that I have in the nas, and only one more appears Corresponding to the first disc of the box sharkoon, the other four do not appear For any place, how do I have them detected? I have tried everything and there is no way, I have seen some information about modifying the ports in the grub.cfg configuration file, but I do not have it clear thanks for the help Quote
htpcdude Posted February 18, 2017 #2 Posted February 18, 2017 First determine if this is a hardware or software issue. I would try booting with a linux live USB drive to make sure you can see all the hard drives via gparted. Which DSM version and loader are you using? Quote
jurgenautt Posted February 18, 2017 Author #3 Posted February 18, 2017 hello I have installed 6.0.2 update 9, I will try ubuntu live usb, Quote
jurgenautt Posted February 19, 2017 Author #4 Posted February 19, 2017 Hi, I have tried with a live ubuntu and with gparted if all the hard disks appear, both those that are inside the nas, as those that I have connected to the box sharkoon. It must be a dms problem with the drivers, or some configuration that has to be enabled in grug.cfg Quote
jurgenautt Posted February 21, 2017 Author #5 Posted February 21, 2017 Hi, does anyone know any solution to this problem that I have?,thanks Quote
