romansoft Posted February 15, 2017 #1 Posted February 15, 2017 Hi, Just created a VM in vmware workstation for testing xpenology (with the idea of moving to ESXi if test is ok): - hw type: workstation 11.x (esxi compatible) - sata disk: synoboot.vmdk (DS3615xs 6.0.2 Jun's Mod V1.01) - sata disk 2: new disk (8gb) - serial port: named pipe (only to have a look to console) With former config, I can boot xpenology and do basic install (DSM_DS3615xs_8451.pat) / config. I had to use option 1 from Jun's menu (yes, baremetal even being a vm!!); if esxi option is used, DSM doesn´t detect any disk and it's impossible to proceed with DSM install). Upon having a basic install, I shutdown VM. Then I added virtual hw: - sata disk 3: new disk (2gb) - sata disk 4: new disk (2gb) - sata disk 5: new disk (2gb) The problem is that I cannot init any of those 3 disks in storage manager. In particular, if I try to create a RAID group, I get this error: "System failed to create [RAID Group 1](Device Type is [basic]) with disk [5]." I also noticed that, during former raid creation process, DSM is showing a wrong capacity (tons of TBs instead of 2 gb capacity). I tried all kinds of different RAIDs (5, etc) but the problem is with those 3 disks, which btw are similar to disk2 (8gb) I created for testing (same kind of virtual sata device). I only can create a RAID group using disk2 (which is where DSM resides, and was init during DSM installation). Any ideas? What's going on? I'd appreciate some help, please, Cheers, -r Quote
billat29 Posted February 15, 2017 #2 Posted February 15, 2017 The virtual disks are too small. Try 20Gb each - and you can choose not to allocate all the disk space when you create them Quote
romansoft Posted February 15, 2017 Author #3 Posted February 15, 2017 Bingo! Thanks a lot, billat29. Cheers, -r Quote
