GavBeck Posted February 11, 2017 #1 Posted February 11, 2017 after having a hard drive crash because of a pcie card my xpenology now doesn't see my disk group at all. I then bought new motherboard with more sata ports on and I'm still having the same issues. I will allow someone to login into my xpenology to see if they can help i'm not very technical at all I need help I don't want to lose my data as I have pictures on there but I think maybe data corruption I don't. I use raid ssh I read an try a lot of things an getting no where fast
shrabok Posted February 12, 2017 #2 Posted February 12, 2017 Hi GavBeck, Not sure how much help can be given. But if you post some specifics on the current state of your system, the errors or problems you are seeing someone might be able to help walk you through your issues. Are you able to get xpenology running and to the UI? Are you able to see the status of each disk and/or disk groups?
