Steve Fan Posted April 28, 2023 #1 Posted April 28, 2023 (edited) Result: Successfully - Bootloader version and model: ARPL v1.1 beta2a with DS1621+ setup - DSM version: DSM 7.1.1-42962 Update 5 - Additional modules extra.lzma: Configured to select all modules in ARPL menu - Hardware solution: Motherboard: AsRock X570M Pro4 CPU: Ryzen 5600G, configured to run in 35W mode Memory: 2x16GB Corsair Vengeance PLX + 2x8GB random offbrand RAM running in DDR4-3000MHz mode Total Cost: $3000 HKD base (~$399 USD), $5000 HKD total with drives. But all of the parts are from few years ago so with depreciation rate should be around $2600 HKD total with drives today. What works: 1. QuickConnect (but you need to BYOC) 2. VM Manager (with VirtualDSM support out of the box) 3. Model recognition works 4. Hard drive bay and identification. X570M Pro4 has 8 SATA ports and 6 of them are coalesced together that sits vertically (so the SATA ports aims into the front of the case where the front panel fans are) so it is pretty easy to recognize and remap in Synology What does not work: 1. Vega iGPU, there is no /dev/dri nor is there any driver loaded for the iGPU PCI device. So Emby and Plex probably won't work at its best possible way. Working to try and compile the amdgpu kernel module but I'm still not sure if software support is right on spot. This is because the CPU of DS1621+ itself (V1500B) does not have an iGPU either so Synology won't bother supporting it What needs to be tested: 1. SR-IOV, so far I don't have installed my CX3 Pro yet 2. Drive sense event. I've seen there are ATA critical events in dmesg log but Synology did not report that as a critical error which may need further debugging. But I do see that it can be a power supply issue or maybe the drive is faulty after 5 years of service, and I do see that none of the drives are gone in fdisk -l 3. High availability and NAS cluster, but I think this is well beyond home use. 4. Extra SATA SSD installation. Recall that X570M Pro4 has 8 SATA ports, so we can use the remaining two SATA ports for SSD Cache (in this case you don't care about speed but IOPS acceleration which SATA SSDs still works fine). However I don't think that would work out of the box because I don't remember DS1621+ has the option to install extra internal SATA SSDs so this is a mystery. I do have a 960GB SATA SSD that will be tried and installed soon. 5. PCIE Bifurcation. I see that I only have a PCIE x8 to x4x4 split option in BIOS while in the manufacturer site it claims I can have PCIE x16 on PCIE1 slot. This implies I only got PCIE x8 in reality if I used an APU, so the information right now is pretty confusing. Looking to contact AsRock with this matter. 6. NVME drives. I don't have spare NVME parts on hand since two of them are pending for another system install. I can also try U.2. too Edited April 28, 2023 by Steve Fan Quote
