pocopico Posted May 27, 2023 Share #101 Posted May 27, 2023 4 minutes ago, scoobdriver said: @pocopico @Peter Suh I was able to get Jim3ma loader to boot on Esxi by passing a Physical USB to the VM (Esxi 8.0U1) I can reach the initial webpage were you would normally install the .pat file, but it detects no disks ? Does his loader have the require modules would you know ? There doesn’t seem to be an option to add any ? I’m ready to try a passthrough of my 11th gen IGPU , but unfortunately I get no disks ? Would really like to get 11th gen transcoding working in ESXi Can you clarify a bit how you boot from USB drive in ESXi ? For the "No drives detected" did you use SATA controllers ? SCSI will not work with SA6400 Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 27, 2023 Share #102 Posted May 27, 2023 1 minute ago, pocopico said: Can you clarify a bit how you boot from USB drive in ESXi ? For the "No drives detected" did you use SATA controllers ? SCSI will not work with SA6400 Yes I am using Sata controllers, tried on 0:0 , 0:1 , 1:0 and 1:1 (do I need to specify SataPortMap , DiskIdxMap , I assumed it was device tree ? ) , I added the physical USB to the VM , Then I forced the Bios to enter setup in VM options (in VM options ) , where I was able to pick the USB drive as a boot device (it did not auto detect it I had to manually pick it ) Initially I was going along these lines https://www.virtualizationhowto.com/2019/01/boot-esxi-virtual-machine-from-passthrough-usb/ , but it turns out it was not needed and it quite happily boots from the physical USB passed through , once you select it . 1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted May 27, 2023 Share #103 Posted May 27, 2023 (edited) 21 minutes ago, scoobdriver said: Yes I am using Sata controllers, tried on 0:0 , 0:1 , 1:0 and 1:1 (do I need to specify SataPortMap , DiskIdxMap , I assumed it was device tree ? ) Yes, if its AHCI SATA controller they should be detected. Did you use the TCRP addons ? specifically disks is used to build the model.dtb on the fly. Edited May 27, 2023 by pocopico Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 27, 2023 Share #104 Posted May 27, 2023 47 minutes ago, pocopico said: Yes, if it’s AHCI SATA controller they should be detected. Did you use the TCRP addons ? specifically disks is used to build the model.dtb on the fly. Something with that particular model , I tried with the i18n loader , again booting from a physical USB in ESXi, allows me to Build DS920+ and install , but again SA6400 finds no disks . Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 27, 2023 Share #105 Posted May 27, 2023 1 hour ago, pocopico said: specifically disks is used to build the model.dtb on the fly. I don’t recall seeing the disks add on on Jim3ma loader , but I saw it on i18n loader. just another thing to note make sure the usb controller matches the usb type , if it’s set in 2.0 it won’t see a physical 3.0 usb stick. I had a couple of loaders across different speed usb sticks , and I had to change it at one point to get esxi to use it as a boot device. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #106 Posted May 28, 2023 5 hours ago, scoobdriver said: I don’t recall seeing the disks add on on Jim3ma loader , but I saw it on i18n loader. just another thing to note make sure the usb controller matches the usb type , if it’s set in 2.0 it won’t see a physical 3.0 usb stick. I had a couple of loaders across different speed usb sticks , and I had to change it at one point to get esxi to use it as a boot device. Restarting my exsi environment. config for SA6400 7.2-64561 is also being built now. M SHELL already has disks addon built with SA6400. Pocopico's TCRP probably does the same. I'll let you know the results after I finish the test today. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #107 Posted May 28, 2023 (edited) 9 hours ago, scoobdriver said: Yes I am using Sata controllers, tried on 0:0 , 0:1 , 1:0 and 1:1 (do I need to specify SataPortMap , DiskIdxMap , I assumed it was device tree ? ) , I added the physical USB to the VM , Then I forced the Bios to enter setup in VM options (in VM options ) , where I was able to pick the USB drive as a boot device (it did not auto detect it I had to manually pick it ) Initially I was going along these lines https://www.virtualizationhowto.com/2019/01/boot-esxi-virtual-machine-from-passthrough-usb/ , but it turns out it was not needed and it quite happily boots from the physical USB passed through , once you select it . I upgraded from esxi 6.7 to 7.0 and I entered the BIOS from there. The USB 2.0 controller and my SanDISK 3.2Gen1 are (Connected) Is it normal to not see it in BIOS? What could be the problem? Is it because there is no VMTools? Edited May 28, 2023 by Peter Suh Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #108 Posted May 28, 2023 (edited) @Peter Suh try changing the USB controller to 3.1 , I had that happen on a usb 3 stick. when I tried to use your mshell the menus defaulted to Chinese language, how would I change this please ? Edited May 28, 2023 by scoobdriver 3.1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #109 Posted May 28, 2023 19 minutes ago, scoobdriver said: @Peter Suh try changing the USB controller to 3.0 , I had that happen on a usb 3 stick. when I tried to use your mshell the menus defaulted to Chinese language, how would I change this please ? I read your tips a bit more and booting from USB 2.0 was successful. SANDISK was not on the compatibility list, so pipbt.iso helped. https://www.plop.at/en/bootmanager/download.html Everything is fine, but after installing DSM I can't get to the next step. I am unable to switch DSM boot due to an issue where it stays in Junior mode. It seems difficult to find the cause alone. Junior log attached. Which part is the problem? Adjust disks related configs automatically - patches maxdisks=2 ls: /sys/bus/usb/devices/usb*: No such file or directory /tmp/model.dts:6.21-12.7: Warning (unit_address_vs_reg): /internal_slot@1: node has a unit name, but no reg or ranges property /tmp/model.dts:13.21-19.7: Warning (unit_address_vs_reg): /internal_slot@2: node has a unit name, but no reg or ranges property /tmp/model.dts:20.17-23.7: Warning (unit_address_vs_reg): /nvme_slot@1: node has a unit name, but no reg or ranges property '/etc/model.dtb' -> '/run/model.dtb' System Disk: (not supported in junior mode) Internal Disk 01: /dev/sata1 02: /dev/sata2 ... Extensions processed insmod: can't insert '/lib/modules/etxhci-hcd.ko': No such file or directory Starting /usr/syno/bin/synocfgen... /usr/syno/bin/synocfgen returns 0 Insert synorbd kernel module Insert synofsbd kernel module Insert libsha256 kernel module Insert sha256 kernel module All disk ready or timeout execeed Assemble args: -u f757c100:1845e22d:05d949f7:b0bbaec7 /dev/sata1p1 /dev/sata2p1 mdadm: /dev/md0 has been started with 2 drives. Partition Version=9 /sbin/e2fsck exists, checking /dev/md0... e2fsck 1.44.1 (24-Mar-2018) [QUOTA WARNING] Usage inconsistent for ID 0:actual (1318912, 12) != expected (1314816, 11) /sbin/e2fsck -yvf returns 1 All components of md0 have partition layout above v9. ForceNewestLayout: Skipped Mounting /dev/md0 /tmpRoot ------------upgrade Begin upgrade procedure Failed to found any patch No upgrade file found End upgrade procedure ============upgrade ------------bootup-smallupdate Failed to AssertDirectory[/tmpRoot/etc.defaults/] Skip bootup smallupdate, because root is not matched to junior ============bootup-smallupdate Missing directory /usr/syno/etc. Copy from /usr/syno/etc.defaults... cp: can't stat '/tmpRoot/usr/syno/etc.defaults': No such file or directory Exit on error [255] prepare /usr/syno/etc failed... Sun May 28 03:45:21 UTC 2023 /dev/md0 /tmpRoot ext4 rw,relatime,journal_checksum,prjquota 0 0 none /sys/kernel/debug debugfs rw,relatime 0 0 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #110 Posted May 28, 2023 24 minutes ago, scoobdriver said: @Peter Suh try changing the USB controller to 3.0 , I had that happen on a usb 3 stick. when I tried to use your mshell the menus defaulted to Chinese language, how would I change this please ? If you want to change the language, you can switch by pressing the l key. Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #111 Posted May 28, 2023 3 minutes ago, Peter Suh said: If you want to change the language, you can switch by pressing the l key. Thank you will try again. My Kingston stick and a few others show, my VM Bios looks different though Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #112 Posted May 28, 2023 5 minutes ago, scoobdriver said: Thank you will try again. My Kingston stick and a few others show, my VM Bios looks different though I've tried with legacy. Let's switch to UEFI. thank you Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #113 Posted May 28, 2023 You may need to change usb controller to 3.1 also Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #114 Posted May 28, 2023 3 minutes ago, scoobdriver said: You may need to change usb controller to 3.1 also Switched to EFI and booted successfully with just the USB 2.0 controller. pipbt is removed. Let's test further to see if we get out of the loop of constant migration from junior . 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2023 Author Share #115 Posted May 28, 2023 I also tried DSM 7.1, but I get a 55% file corruption message while installing DSM and cannot proceed. When I tried DSM 7.2, I got an infinite loop of SERIAL port logs. [ 95.440638] BUG: scheduling while atomic: swapper/0/0/0x00000003 [ 95.446297] Modules linked in: uas hid_generic(E) usbhid(E) hid(E) usblp(E) uhci_hcd(E) ehci_pci(E) ehci_hcd(E) epyc7002_synobios(POE) leds_atm ega1608(E) adt7475(E) hwmon_vid(OE) nfs_ssc(E) lockd(E) grace(E) sunrpc(E) hfsplus(E) md4(E) hmac(E) i40e(OE) auxiliary(OE) qede(OE) qed(OE) atlan tic(OE) r8125(OE) r8168(OE) ixgbe(OE) be2net(OE) igb(OE) i2c_algo_bit(E) e1000e(OE) vxlan(OE) ip6_udp_tunnel(E) udp_tunnel(E) ip_tunnel(E) fuse(E) vfat(E) fat(E) aesni_intel(E) glue_helper(E) crypto_simd(E) cryptd(E) ecryptfs(E) ecb(E) authenc(E) des_generic(E) libdes(E) ansi_cprng(E) cts(E) md5(E) cbc(E) cpufreq_powersave(E) cpufreq_performance(E) dm_snapshot(E) dm_bufio(E) dm_mod(E) crc_itu_t(E) crc_ccitt(E) sg(E) psnap(E) p8022(E) llc(E) ipv6(E) sha256_generic(E) libsha256(E) synorbd(POE) synofsbd(POE) vmxnet3(OE) usb_storage xhci_pci xhci_hcd usbcore usb_common [last unload ed: epyc7002_synobios] [ 95.524026] CPU: 0 PID: 0 Comm: swapper/0 Tainted: P W OEL 5.10.55+ #64561 [ 95.532240] Hardware name: VMware, Inc. VMware7,1/440BX Desktop Reference Platform, BIOS VMW71.00V.18227214.B64.2106252220 06/25/2021 [ 95.543496] Call Trace: [ 95.546203] [<ffffffff817681fa>] dump_stack+0x57/0x6a [ 95.551669] [<ffffffff81758810>] __schedule_bug.cold+0x4b/0x58 [ 95.557280] [<ffffffff8178c03c>] __schedule+0x5ec/0x8a0 [ 95.562776] [<ffffffff8178c69c>] schedule_idle+0x2c/0x40 [ 95.568300] [<ffffffff8109ab99>] cpu_startup_entry+0x19/0x20 [ 95.573864] [<ffffffff82a19ebb>] start_kernel+0x499/0x4a2 [ 95.579390] [<ffffffff810000f5>] secondary_startup_64_no_verify+0xb0/0xbb [ 95.749500] softirq: huh, entered softirq 3 NET_RX 00000000813f0cda with preempt_count 00000101, exited with 00000102? [ 96.751088] softirq: huh, entered softirq 3 NET_RX 00000000813f0cda with preempt_count 00000101, exited with 00000102? [ 97.239430] softirq: huh, entered softirq 3 NET_RX 00000000813f0cda with preempt_count 00000101, exited with 00000102? [ 97.732303] softirq: huh, entered softirq 3 NET_RX 00000000813f0cda with preempt_count 00000101, exited with 00000102? Quote Link to comment Share on other sites More sharing options...
wjz304 Posted May 28, 2023 Share #116 Posted May 28, 2023 (edited) Although the 7.1 and 7.2 kernel versions are both 5.10.55 in SA6400, but they are different toolchains, so it is best to compile lkm and modules separately. But precisely because the kver is the same, both tcrp and arpl need to make corresponding modifications to it Edited May 28, 2023 by wjz304 2 Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #117 Posted May 28, 2023 Ok, got it installed with your @wjz304 loader !!! I had to disable most of the modules , and just load those needed . something was stopping VMnet3 / network working ?! I've installed 7.2 , but I'm going to go back and install 7.1 as I understand this supports i915 ? I'd like to passthrough the intel gpu in Esxi Fingers crossed , and thanks for everyones hard work !!! Quote Link to comment Share on other sites More sharing options...
wjz304 Posted May 28, 2023 Share #118 Posted May 28, 2023 52 minutes ago, scoobdriver said: Ok, got it installed with your @wjz304 loader !!! I had to disable most of the modules , and just load those needed . something was stopping VMnet3 / network working ?! I've installed 7.2 , but I'm going to go back and install 7.1 as I understand this supports i915 ? I'd like to passthrough the intel gpu in Esxi Fingers crossed , and thanks for everyones hard work !!! Try switching to direct startup and check if vmxnet3 is working properly, there is currently an issue with dhcp, and I am still trying to figure out how to solve it. In the advanced menu of arpl-i18n, there is an option to "Allow downgrade installation", which will allow you to install versions lower than the existing system version Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #119 Posted May 28, 2023 3 minutes ago, wjz304 said: Try switching to direct startup and check if vmxnet3 is working properly, I got 7.2 working and can see from the serial port vmxnet loads. so I got 7.2 installed all good. then tried 7.1 for i915 port but it fails at 57% , corrupt pat. Quote Link to comment Share on other sites More sharing options...
wjz304 Posted May 28, 2023 Share #120 Posted May 28, 2023 11 minutes ago, scoobdriver said: I got 7.2 working and can see from the serial port vmxnet loads. so I got 7.2 installed all good. then tried 7.1 for i915 port but it fails at 57% , corrupt pat. Sorry, I'm not very familiar with graphics cards(i915). Because jim3ma has been studying it, So I haven't allocated my energy to doing repetitive things, Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #121 Posted May 28, 2023 5 minutes ago, wjz304 said: Sorry, I'm not very familiar with graphics cards(i915). Because jim3ma has been studying it, So I haven't allocated my energy to doing repetitive things, Would you know how I could build the .img from his arpl repository? Quote Link to comment Share on other sites More sharing options...
wjz304 Posted May 28, 2023 Share #122 Posted May 28, 2023 4 minutes ago, scoobdriver said: Would you know how I could build the .img from his arpl repository? I haven't seen him recently. I will inquire about his progress later Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 28, 2023 Share #123 Posted May 28, 2023 (edited) Ok, I managed to load the .ko 's associated with i915 in 7.2 built with you loader @wjz304 , booting from a external USB in ESXi , passing through the 11th gen igpu Think I'm there , dev/dri is showing up 02:02.0 VGA compatible controller: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] (rev 04) 02:02.0 VGA compatible controller: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] (rev 04) DeviceName: pciPassthru0 Subsystem: Lenovo Device 31a7 Kernel driver in use: i915 [ 1105.667560] Modules linked in: i915(OE) drm_kms_helper(OE) drm(OE) drm_panel_orientation_quirks(OE) drm_mipi_dsi(OE) hdmi(OE) fbcore(OE) fbdev(OE) video(OE) backlight(OE) backport_sa6400(OE) backport_sa6400_export(OE) synoacl_vfs(PO) fuse vfat fat tcm_qla2xxx(O) qla2xxx(O) libfc scsi_transport_fc vhost_scsi(O) vhost(O) vhost_iotlb(O) tcm_loop(O) iscsi_target_mod(O) target_core_user(O) target_core_ep(O) target_core_multi_file(O) target_core_file(O) target_core_iblock(O) target_core_mod(O) syno_extent_pool(PO) rodsp_ep(O) udf isofs btrfs xor raid6_pq adt7475 hwmon_vid hid_generic 8021q leds_atmega1608 lrw gf128mul epyc7002_synobios(PO) uhci_hcd ehci_pci ehci_hcd be2net bnxt_en(O) bnx2x(O) qede(O) qed(O) mlx5_core(O) mlx4_en(O) mlx4_core(O) atlantic_v2(O) atlantic(O) r8168(O) i40e(O) auxiliary(O) ixgbe(O) i2c_algo_bit igb(O) dm_crypt essiv loop sg dm_snapshot dm_bufio crc_itu_t crc_ccitt psnap p8022 llc hfsplus md4 hmac sit tunnel4 ipv6 flashcache_syno(O) zram syno_flashcache_control(O) Edited May 28, 2023 by scoobdriver 1 Quote Link to comment Share on other sites More sharing options...
scoobdriver Posted May 29, 2023 Share #124 Posted May 29, 2023 Ok , despite /dev/dri been present and the i915 module loading , I don’t seem to be able to get HW transcoding in Plex docker, I think the modules perhaps aren't compatible with 7.2 looks like its not just a case of copying the module from 7.1 , or I’ve missed some dependencies Quote Link to comment Share on other sites More sharing options...
wjz304 Posted May 29, 2023 Share #125 Posted May 29, 2023 (edited) Yes, it has many dependencies,I remember Jim had a separate modules compression package 3 hours ago, scoobdriver said: Ok , despite /dev/dri been present and the i915 module loading , I don’t seem to be able to get HW transcoding in Plex docker, I think the modules perhaps aren't compatible with 7.2 looks like its not just a case of copying the module from 7.1 , or I’ve missed some dependencies Edited May 29, 2023 by wjz304 Quote Link to comment Share on other sites More sharing options...
