fbelavenuto Posted January 20 Share #1 Posted January 20 Hi guys, I'm having a problem with a module. When trying to load the kernel it complains about a missing symbol, but it exists!: DiskStation> modprobe sync_file [ 57.291977] sync_file: Unknown symbol anon_inode_getfile (err 0) modprobe: ERROR: could not insert 'sync_file': Unknown symbol in module, or unknown parameter (see dmesg) DiskStation> grep anon_inode_getfile /proc/kallsyms ffffffff811d07d0 T anon_inode_getfile It exists in Module.symvers: $ grep anon_inode_getfile Module.symvers 0x00000000 anon_inode_getfile vmlinux EXPORT_SYMBOL_GPL So I ask for help from those more experienced in linux. Quote Link to comment Share on other sites More sharing options...
Orphée Posted January 20 Share #2 Posted January 20 I'm feeling a "déjà-vu" : Quote Link to comment Share on other sites More sharing options...
fbelavenuto Posted January 20 Author Share #3 Posted January 20 4 hours ago, Orphée said: I'm feeling a "déjà-vu" : I'm sorry I hadn't seen your post! I am trying to compile i915 for broadwell. Source code is latest from Synology (linux-4.4.x.txz) Quote Link to comment Share on other sites More sharing options...
Orphée Posted January 20 Share #4 Posted January 20 15 minutes ago, fbelavenuto said: I'm sorry I hadn't seen your post! I am trying to compile i915 for broadwell. Source code is latest from Synology (linux-4.4.x.txz) Good luck, I'm currently stuck at the point in my topic above. If you succeed, please tell me 1 Quote Link to comment Share on other sites More sharing options...
fbelavenuto Posted Friday at 05:30 PM Author Share #5 Posted Friday at 05:30 PM On 1/20/2023 at 11:09 AM, Orphée said: Good luck, I'm currently stuck at the point in my topic above. If you succeed, please tell me Found a solution!! The symbol "anon_inode getfile" is called in the file "drivers/dma-buf/sync_file.c". This file was not created to be compiled as a module, so it does not link with existing symbols. To resolve this, add the following line to this file, next to "#includes": Quote #include <linux/module.h> Then add at the end of the file: Quote MODULE_LICENSE("GPL"); Once done, the file will be compiled as a GPL module and can be linked with any other kernel symbol. 1 Quote Link to comment Share on other sites More sharing options...
Orphée Posted Friday at 09:38 PM Share #6 Posted Friday at 09:38 PM 4 hours ago, fbelavenuto said: Found a solution!! The symbol "anon_inode getfile" is called in the file "drivers/dma-buf/sync_file.c". This file was not created to be compiled as a module, so it does not link with existing symbols. To resolve this, add the following line to this file, next to "#includes": Then add at the end of the file: Once done, the file will be compiled as a GPL module and can be linked with any other kernel symbol. Well played, were you able to build everything ? did you try to build trace_events.ko ? Quote Link to comment Share on other sites More sharing options...
fbelavenuto Posted Friday at 11:27 PM Author Share #7 Posted Friday at 11:27 PM 1 hour ago, Orphée said: Well played, were you able to build everything ? did you try to build trace_events.ko ? I built everything, but I got a KP! Quote Link to comment Share on other sites More sharing options...
Orphée Posted Friday at 11:45 PM Share #8 Posted Friday at 11:45 PM well I'm curious to know how you did Quote Link to comment Share on other sites More sharing options...
fbelavenuto Posted Monday at 11:29 AM Author Share #9 Posted Monday at 11:29 AM On 1/27/2023 at 8:45 PM, Orphée said: well I'm curious to know how you did I've put tests in a separate branch: https://github.com/fbelavenuto/arpl-modules/tree/test-i915 1 Quote Link to comment Share on other sites More sharing options...
