High FAN speed on HP350P Gen8 with p420i controller in HBA
Hi al,
I have an issue with my HP ML350P GEN8 server which is quite a nice machine for virtualsation and usage as mass storage device based on its slot.
I want t use the raid controller as passtruth so tht Xpenology can manager my disks in raw mode also providing smart status etc.
I am using ESXI 6.5 and first enable HBA mode on the P420i controller (which means passtruth disk and disable raid), than i install june loader a vmware.
Adding additonal CPU's + the PCI card ass passtrtuth device. Immediatly when i start my VM the CPU Fans go up to 100% and dont go done when i shutdown the VM. Only solution is to reboot the entire machine.
Anyone else a clue or seen this problem ?
