Hello,
I am new in here. Reviewing all topics related to Intel Speedstep and couldn't find anything that would solve my issue with nettop GB-BACE-3000 Celeron N3000.
Processor doesn't want to run more than minimal speed 1.04GHz.
I did all checks I found on this forum:
> cat /sys/devices/system/cpu/cpu*/cpufreq/bios_limit
1041000
1041000
>cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 76
model name : Intel® Celeron® CPU N3000 @ 1.04GHz
stepping : 3
microcode : 0x34c
cpu MHz : 1041.000
cache size : 1024 KB
physical id : 0
siblings : 2
core id : 0
cpu cores : 2
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer aes rdrand lahf_lm 3dnowprefetch ida arat epb dtherm tpr_shadow vnmi flexpriority ept vpid tsc_adjust smep erms
bogomips : 2079.50
clflush size : 64
cache_alignment : 64
address sizes : 36 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 76
stepping : 3
microcode : 0x34c
cpu MHz : 1041.000
physical id : 0
siblings : 2
core id : 2
cpu cores : 2
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
bogomips : 2079.50
clflush size : 64
power management:
It seems Bios limits my CPU freq. By any chance I could set something like:
echo 2000000 > /sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq
echo 2000000 > /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq
I would be grateful for any support.
How did you assess that your CPU is not running above 1.04 GHz? As far as I can tell, the Celeron N3000 CPU's base frequency is 1.04 GHz with a burst frequency of 2.08 GHz.
What do you get if you type the following:
sudo dmidecode -t processor | grep "Speed"
You can also try this to check the maximum speed of the CPU:
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq
or
cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_max_freq
thanks for your response Polanskiman.
command doesn't work on my nanoboot.
Dysk> cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_max_freq
1041000
1041000
Dysk>
So this CPU won't run over 1041000, that's a pity :sad:
1041000
1041000
Dysk>
Have you checked the bios configuration of your mother board see if there is anything limiting the speed?
Also run this:
cat /var/log/dmesg | grep "MHz processor"
What do you get?
  • 2 years later...
Hello,
I have same problem, I check your command:
        Max Speed: 2400 MHz
        Current Speed: 1040 MHz
[Sat Jan 11 21:20:00 2020] tsc: Detected 1039.981 MHz processor
[Sat Jan 11 21:20:01 2020] tsc: Detected 1039.941 MHz processor
[Tue Jan 21 21:28:03 2020] tsc: Detected 1039.482 MHz processor
[Tue Jan 21 21:39:13 2020] tsc: Detected 1039.970 MHz processor
[Sat Jan 11 21:20:01 2020] tsc: Detected 1040.426 MHz processor
[Tue Jan 21 22:40:47 2020] tsc: Detected 1040.017 MHz processor
[Tue Jan 21 22:58:07 2020] tsc: Detected 1040.497 MHz processor
[Fri Feb 21 23:28:19 2020] tsc: Detected 1039.981 MHz processor
[Sat Feb 22 09:14:46 2020] tsc: Detected 1039.901 MHz processor
[Mon Mar  2 21:32:51 2020] tsc: Detected 1039.999 MHz processor
What is the command for make processor to 2,4Ghz ?
Edited by dyter
