I have 2 machines as mentioned in the title. The samba addon for home assistant works on the 218+ but does not work on my xpenology install.
Both are clean VM's spun up for testing. I have also exported the working home assistant VM(samba works) from the 218+ into the xpenology and it loses its samba ability.
I have attempted to use MacOS samba client also but it also fails similarly
Description of the failure: Mapping the network drive brings a prompt for user and password. There is a long pause and then the prompt for user and password appears again? Then failure with the following attached message. In the log for the samba addon I can see that authentication actually succeeds?
I have done my best to config both VM's the same.
I may have one DSM configured differently than the other but I have poured through the settings and compared.
Its expenolgy related.
Thanks if anybody has any suggestions. I have always used the mounted files for configuration however I have setup workarounds
dasbooter
0 answers to this question
