SMB / Copy speed on esxi SLOW
tested the new 6.5 build , non HPE version, same issue
then disabled ahci : esxcli system module set --enabled=false --module=vmw_ahci
same issue
i think above is another issue, its an issue/case to have better speeds
the issue i have here , is that smb speed actually drops to 0 kb and eventually fails
  • 3 weeks later...
  • 3 weeks later...
On 30/08/2017 at 0:05 PM, NoFate said:
so to be sure, my ram wasnt defect, i used another 2 x 2 GB ram in my system
on 2 GB host synology 5.2 is stable when copying
when i put 3 GB or 4 GB on the virtual machine, i have the smb issue again
Hello,
I downgrade my VM 4 GB --> 2GB
See you in few days for the result
Thanks NoFate for your work.
34 minutes ago, koroziv said:
this:
up to esxi 6.0 - downgrade hpvsa driver ( use "scsi-hpvsa-5.5.0-88OEM.550.0.0.1331820.x86_64.vib" )
esxi 6.5 - downgrade hpvsa driver (same as above) and disable the esxi ahci module
Hi, yes, that's also a bug, but resolved in 6.5 update 1 , but that was an other story, that bug was more like that the speeds were not faster then 60 MB / sec...
The bug we have is that it starts at 110  , but drops to 0 and even crashes... That's something else...
I resolved it on my ASRock from changing 4 GB ram to 2, but on my gen8 it didn't help..
Also to be sure, I tried older esxi like 5.5, also same story, so it has nothing to do with hpsva driver... Tried all that stuff also ;)
to all,
i found another way to make it work on my hp gen 8
bought a 2 sata controller with asmedia chipset (marevell doesnt work, not compatible with vt-d) http://www.sybausa.com/index.php?route=product/product&path=64_77_85&product_id=151
installed esxi on a microsim card (on the mainboard)
boot esxi from microsd
attached 1 ssd drive to that asmedia sata controller, so my datatstore in on that ssd
passthrough the whole cougar controller with 4 bay
no issues now anymore, copy is working perfect! and i have the smart status now visible in synology
me happy
  • 2 years later...
On 9/15/2017 at 12:47 PM, NoFate said:
to all,
me happy
Good!
Same situation for me, but if i want to run 3 xpenology (2 ipcam for vm) e 1 win10 for torrent emule download, can i passthrought 1 hdd at time to every vm? thnx
5 hours ago, thecatman said:
Good!
why 2 for IP cam?
anyway, thats not possible i think, you can only passthrough the whole controller, so all disks
why nut just create volumes, i map then to the hosts as SMB folders? you need to create your hosts , primary disks on your data store anyway, thats on your ssd disk
my configuration includes a gen8 16gb ram xeon e3-1265l v3, esxi 6.7 standard on usb pendrive, ssd on the odd port as datastore and 4 hdd wd red 4tb in front. the problems are low network performance (fast start but then it becomes a snail) and low data transfer (hdd always 100% overload). i tried to change the hp scsi driver to an old one but with no useful result. today I try to use esxi 7 maybe they solved something otherwise or I buy the asmedia controller or I buy a sas lsi megaraid controller it mode
Edited by thecatman
yes, its because of the odd port, you need to boot the SSD from a seperare sata mini card, they use the cougar as passthrough
then my slow smb copy speed want away
i struggled also a long time with this... it starts copying fine ... then after a faw sec, it drops to zeo or crashes...
