NoFate Posted January 3, 2017 #1 Posted January 3, 2017 Hi, when running dsm 5.2 on esxi systems, the copy speed is terrible slow for example if i copy over like 100 gb over gb network, it starts good at like 110MB / sec, but after a few min , it drops to 5 MB and eventually windows stops copying changing from e1000 to vmxnet doesnt make any difference running on baremetal, then there is no issue what are the tweaks for this copy speed? to make it normal ? i had an asrock mainboard, now i switched to hp gen 8 microserver (xeon model) thnx Quote
NoFate Posted January 3, 2017 Author #2 Posted January 3, 2017 extra info followed this guide: viewtopic.php?f=15&t=3132 i am using AHCI mode and mapped RDM files for my disks Quote
jms667 Posted January 6, 2017 #3 Posted January 6, 2017 Hi NoFate, I had pretty same behavior with my setup : esxi + RDM + DSM 5.2 The issue was the same with uploads (from DSM to anywhere else), starting correctly (100MB) then dropping to a few MB after a couple of min with some complete freeze sometimes. But Dowmloads were ok. I checked a lot of things (cable, switch, ethernet config at both sides, etc ...) no success. In a last resort, I changed the raid controller type into the DSM vm, set it to 'VMware Paravirtual' instead of 'LSI logic ...' and it did the trick ! Now both upload and download are stable and with a pretty good bandwidth (80-100MB). I hope it will help. Quote
Dutchman Posted January 6, 2017 #4 Posted January 6, 2017 cant reproduce this, running on ESXi and dont have this behaviour. i had 1 issue in the past which looked like this and entered my ESXi monitoring. Here i saw that my DISK latency was running on 100-12000 MS !!!! Problem solved by providing the right power to my motherboard, somehow a connector was misse and my motherboard didnt get the power it needed to handle the storage controller as a result my disk latency was very high. Place power cord == issue solved, latency < 20ms Quote
NoFate Posted January 6, 2017 Author #5 Posted January 6, 2017 Hi NoFate, I had pretty same behavior with my setup : esxi + RDM + DSM 5.2 The issue was the same with uploads (from DSM to anywhere else), starting correctly (100MB) then dropping to a few MB after a couple of min with some complete freeze sometimes. But Dowmloads were ok. I checked a lot of things (cable, switch, ethernet config at both sides, etc ...) no success. In a last resort, I changed the raid controller type into the DSM vm, set it to 'VMware Paravirtual' instead of 'LSI logic ...' and it did the trick ! Now both upload and download are stable and with a pretty good bandwidth (80-100MB). I hope it will help. ok, going to try that out but i was pretty sure i choose paravirtual at the first setup wizard, now i see its LSI logic also tried dsm 6 now, the issue is gone on dsm 6 but i want it to work also on 5.2 , going to try out this weekend, thnx for the tip Quote
NoFate Posted January 7, 2017 Author #6 Posted January 7, 2017 tried the paravirtual setting, same behaviour after 2 mins of copying from DSM to local drive, speed drops from +- 110 MB to like 500KB and crashes copying but seems its only on the first boot of dsm, after testing again after like 10 min, the copy speed is normal again and stable too bad , i had the same behaviour on another mainboard, asrock n3150 , now i have it also on hp microserver gen8 but anyway, didnt have the issue on DSM 6 , so waiting for the new loader , hopefully this weekend, then going to migrate to 6 Quote
NoFate Posted January 7, 2017 Author #7 Posted January 7, 2017 ps : this issue only happens when copy a large folder, like 50 GB or something it not happens when copying like 2-5 GB Quote
sagrotan Posted February 12, 2017 #8 Posted February 12, 2017 (edited) Which ESX version? Edited February 12, 2017 by Guest Quote
sagrotan Posted February 12, 2017 #10 Posted February 12, 2017 ?? Sorry, which ESX version? Try also a copyjob to another VM on same host. With vmxnet3 the vSwitch should have 10GE, so storage controller is the limit. If you run 5.5 or 6.0 (not 6.5), you have to downgrade the hpvsa to .88 version. All later versions have this performance bug. Maybe this is your bottleneck. Change the driver is a good decision anyway. https://communities.vmware.com/thread/505233?start=0&tstart=0 Quote
NoFate Posted February 13, 2017 Author #11 Posted February 13, 2017 hi, before i had an asrock with maibnoard n3150 , esxi 6.0 , dsm 5.2 now i have a hp microserver gen8 xeon processor, esxi 6.6 dsm 5.2 both mianboards gave the same copy result when copy large files/directorys over smb , but NO problems when running 6.02 junes loader when copying on the same host, there is no issue Quote
ygor Posted July 12, 2017 #12 Posted July 12, 2017 On Synology, on advanced smb protocol are enable with encryption. This slow down file transfert of files. Also dépend of cpu usage/power while doing à transfert. Disabling Can help Quote
NoFate Posted July 12, 2017 Author #13 Posted July 12, 2017 yes, tried those settings also because on baremetal everything works fine, only on esx it doesnt work Quote
lunzet Posted July 12, 2017 #14 Posted July 12, 2017 copied again 30GB. speed never went below 75Mbyte/sec. did you try ftp/sftp while transferring 30GB or more? Quote
NoFate Posted July 12, 2017 Author #15 Posted July 12, 2017 Hi, no only tried SMB ..can you maybe make an export of your settings? I don't use passthrough btw Quote
lunzet Posted July 12, 2017 #16 Posted July 12, 2017 8 minutes ago, NoFate said: Hi, no only tried SMB ..can you maybe make an export of your settings? I don't use passthrough btw which settings mate? Quote
NoFate Posted July 12, 2017 Author #17 Posted July 12, 2017 Hi, the settings of your your vmware host,like paravirtual or sas, your vmxnet, controller... I think you can make an export template Quote
lunzet Posted July 12, 2017 #18 Posted July 12, 2017 and btw I am using RDM not passthru: https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=1017530 Quote
NoFate Posted July 12, 2017 Author #19 Posted July 12, 2017 Yes, me too...can you create a vmxnet file or ovf , that way I can make the same config Quote
lunzet Posted August 1, 2017 #20 Posted August 1, 2017 so any news nofate as I di provide the vmx file? just wondering why this topic here is not active but in other threads some people are still reporting this issue. so i do not have it Quote
NoFate Posted August 1, 2017 Author #21 Posted August 1, 2017 hi, at the moment still running baremetal, dont have time testing this out just became father 1 Quote
lunzet Posted August 1, 2017 #22 Posted August 1, 2017 congrats and full acknowledgment so maybe others can provide more data on this. Quote
palcica Posted August 1, 2017 #23 Posted August 1, 2017 I tried once more again with a new station as Still after few seconds, transfer stops. Quote
lunzet Posted August 2, 2017 #24 Posted August 2, 2017 Could u try FTP? Gesendet von meinem Z2 Plus mit Tapatalk Quote
NoFate Posted August 2, 2017 Author #25 Posted August 2, 2017 i didnt test ftp before maybe it has todo with the installtion itself normally on first boot, in the boot menu, you can choose install for Vmware or something like that but becuase boot menu is verry fast, always the first option was selected maybe that can cause an issue? Quote
