Vereato Posted November 30, 2022 #1 Posted November 30, 2022 Hi there i try to install the DSM on DELL Server R610 but no success i follow all the tutorials to setup the grub file i did all perfect step by step but when comes to the LAN detect from Synology Assistent not working LAN IP shows on the windows arp -a the list of the IPs on the LAN Network is the problem because i use Synology Router it may cause to block the Hacking NAS right i use Synology router it may block the LAN IP it shows on the arp -a windows the DHCP network IPs but on the router doesn't show the IP any help is welcome thanks Quote
rojoone2 Posted December 1, 2022 #2 Posted December 1, 2022 Which loader and platform are you trying to build? Quote
Vereato Posted December 1, 2022 Author #3 Posted December 1, 2022 i m using loader Jun’s Loader v1.03b DS3617xs i tried all of them versions 6.2 and redpill to install DSM 7 no sucess i did all perfect the synology assistant not detect the server and i see the ip on the arp -a windows i also use find.synology no sucess i believe my synology router is blocking the connections Quote
rojoone2 Posted December 2, 2022 #4 Posted December 2, 2022 I could be wrong, but I don't believe Synology is blocking you MAC address from the R610. You may not have the right drivers installed for your NIC which should be one of the Broadcom drivers found here: https://github.com/pocopico/rp-ext Do you still have the old 6iR storage controller or do you have a newer controller installed? This may cause a "No drives detected" issue once you build so you may look into purchasing a different controller like the H200 or H700. Before you do that, try using ARPL loader to build your NAS and see if you can find it on your network: Quote
Vereato Posted December 2, 2022 Author #5 Posted December 2, 2022 yes i do i have on my DELL Server H200 controller i had before the H700 i changed to H200 it mode the NICS the loader don't detect the NICS i had to add new NIC the DELL NICS dont show the IP and MAC the new NIC shows the IP and MAC as i said i believe the Synology router blocking the loader if you can help me out Quote
IG-88 Posted December 18, 2022 #6 Posted December 18, 2022 On 12/2/2022 at 11:13 PM, Vereato said: as i said i believe the Synology router blocking the loader no, there still other way more likely solutions how should the dhcp server on the router determine between a dell server and a dell server with a xpenology loader, it just gets a request from a mac address there is no infomtation about the rest and it way to much code and to many options to do unintended things, its way easier to secure DSM itself and i could continue why its not very logical and very unlikely imho most likely missing firmware files for the nic DELL Server R610, two dual port embedded Broadcom® NetXtreme® II 5709c Gigabit Ethernet NIC -> bnx2.ko and that driver needs firmware to work properly (can be seen when using modinfo or just looking with a hex editot for ".fw" it should be \usr\lib\firmware\bnx2\ bnx2-rv2p-06-6.0.15.fw bnx2-mips-06-6.2.3.fw bnx2-rv2p-09ax-6.0.17.fw bnx2-mips-09-6.2.1b.fw bnx2-rv2p-09-6.0.17.fw i dont know how tcrp handles firmware realted driver, the firmware is not in the driver *.gz that is used in the laoder arpl loader comes with a "firmware.tgz" and that has all 5 files in it, so try this loader to see if that it the problem (my guess is that it will be working with arpl) even jun's 1.03b loader did only contain 3 of 5 firmware files (mips files missing, did not work with all bnx2, i do remember that HPE's did work and some Dell did not) bnx2-rv2p-06-6.0.15.fw bnx2-rv2p-09ax-6.0.17.fw bnx2-rv2p-09-6.0.17.fw for 6.2 (jun's loader) there is a extended extra.lzma with all firmware files in it https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/ but as that loader ends with 6.2.3 update3 and 6.2 in in general retired 6/2023 by synology it not suggested to use that for a new install, maybe for testing using that with 3615/17 needs also csm mode in a uefi bios and it is needed that on boot the legacy usb device is used (csm is just a option, choosing the uefi usb device overrides that option) https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ Quote
painkiller895 Posted December 22, 2022 #7 Posted December 22, 2022 As you can see here bnx2 doesn't work when booting up this Dell R410 I have to add a Nic card for it to work... Quote
painkiller895 Posted December 23, 2022 #8 Posted December 23, 2022 On 12/2/2022 at 5:13 PM, Vereato said: yes i do i have on my DELL Server H200 controller i had before the H700 i changed to H200 it mode the NICS the loader don't detect the NICS i had to add new NIC the DELL NICS dont show the IP and MAC the new NIC shows the IP and MAC as i said i believe the Synology router blocking the loader if you can help me out Try adding a intel nic card and it should work...bnx2 drivers are broken on the loader for now as I can see... Quote
painkiller895 Posted December 23, 2022 #9 Posted December 23, 2022 (edited) 14 hours ago, painkiller895 said: As you can see here bnx2 doesn't work when booting up this Dell R410 I have to add a Nic card for it to work... I added a intel nic card and got this error using DS920+ bare metal install . So something is wrong on the network side using this loader. How is this fixed ??? I used ARPL loader on DS3622 and that works with no problem on this same machine... I have used this loader on my Esxi server and all works well. Edited December 23, 2022 by painkiller895 Quote
