Hi there i try to install the DSM on DELL Server  R610  but no success
i follow all the tutorials to setup the grub file  i did all perfect step by step
but when comes to the LAN  detect from Synology Assistent  not working
LAN IP shows on the windows arp -a  the list of the IPs on the LAN Network
is the problem  because i use Synology Router it may cause to  block the Hacking NAS  right
i use Synology  router  it may block the LAN  IP
it shows on the arp -a   windows   the DHCP  network  IPs   but on the router doesn't show  the IP
any help is welcome thanks
