wangsiji Posted November 18, 2022 #1 Posted November 18, 2022 This patcher enables Advanced Media Extensions 3.0 for you, without having to login account. Download AME3.0 from store. Put the following Python script to any location. Run it with root. Done. Spoiler import hashlib import os r = ['669066909066906690', 'B801000000', '30'] s = [(0x1F28, 0), (0x48F5, 1), (0x4921, 1), (0x4953, 1), (0x4975, 1), (0x9AC8, 2)] prefix = '/var/packages/CodecPack/target/usr' so = prefix + '/lib/libsynoame-license.so' print("Patching") with open(so, 'r+b') as fh: full = fh.read() if hashlib.md5(full).digest().hex() != 'fcc1084f4eadcf5855e6e8494fb79e23': print("MD5 mismatch") exit(1) for x in s: fh.seek(x[0] + 0x8000, 0) fh.write(bytes.fromhex(r[x[1]])) lic = '/usr/syno/etc/license/data/ame/offline_license.json' os.makedirs(os.path.dirname(lic), exist_ok=True) with open(lic, 'w') as licf: licf.write('[{"appType": 14, "appName": "ame", "follow": ["device"], "server_time": 1666000000, "registered_at": 1651000000, "expireTime": 0, "status": "valid", "firstActTime": 1651000001, "extension_gid": null, "licenseCode": "0", "duration": 1576800000, "attribute": {"codec": "hevc", "type": "free"}, "licenseContent": 1}, {"appType": 14, "appName": "ame", "follow": ["device"], "server_time": 1666000000, "registered_at": 1651000000, "expireTime": 0, "status": "valid", "firstActTime": 1651000001, "extension_gid": null, "licenseCode": "0", "duration": 1576800000, "attribute": {"codec": "aac", "type": "free"}, "licenseContent": 1}]') print("Checking whether patch is successful...") ret = os.system(prefix + "/bin/synoame-bin-check-license") if ret == 0: print("Successful, updating codecs...") os.system(prefix + "/bin/synoame-bin-auto-install-needed-codec") print("Done") else: print(f"Patch is unsuccessful, retcode = {ret}") 6 Quote
wangsiji Posted November 18, 2022 Author #2 Posted November 18, 2022 Note that in order to use this, you will have to use a valid SN (but doesn't have to login synology account with that SN). 2 Quote
ilovepancakes Posted February 20, 2023 #4 Posted February 20, 2023 Awesome, thank you! Activation works and initial testing seems to play HEVC files just fine now. Quote
waazdakka Posted February 21, 2023 #5 Posted February 21, 2023 (edited) Hello! Hmm it seems I don't have a valid serial (impossible to add it to my Synology Account), because it has been generated by RedPill at start and I don't have any idea how to change it for a valid one. (And I'm not even sure that I CAN change it since I use a DS3622+ ESXI installation). I tried the script anyway but I obtain: ./ame.py: line 1: import: command not found ./ame.py: line 2: import: command not found ./ame.py: line 3: $'\r': command not found ./ame.py: line 4: r: command not found ./ame.py: line 5: syntax error near unexpected token `(' ./ame.py: line 5: `s = [(0x1F28, 0), (0x48F5, 1), (0x4921, 1), (0x4953, 1), (0x4'75, 1), (0x9AC8, 2)] Some help? 😥 Thanks!!! Edited February 21, 2023 by waazdakka Quote
xpeno1 Posted February 22, 2023 #6 Posted February 22, 2023 @waazdakka normally you just need the "valid" Serial# generated by RedPill... A official Serial# should avoid you to use this patch?? I am no way a expert in programing or script... but the error you have "command not found" might indicate you are missing "Module" or "package component" to be instal??? So peoples with programing competance are more qualify to troobleshoot unless I am wrong. However if you want to change the Serial# then take a look at "Acidflash" 2nd post. The idea is to mount the partition that have the "grub.cfg" file to be modify. It is on VM machine but should be the same on "bare metal" install too. Quote
waazdakka Posted February 23, 2023 #7 Posted February 23, 2023 Nice, thanks for the fast answer! (For those who search for it: But what about finding a valid serial? I can't find any serial generator for the DS3622XS+ Or I can make a new VM installation to get RedPill again and access to the integrate seralizer 😂 Quote
ilovepancakes Posted February 24, 2023 #8 Posted February 24, 2023 On 2/23/2023 at 4:41 AM, waazdakka said: Nice, thanks for the fast answer! (For those who search for it: But what about finding a valid serial? I can't find any serial generator for the DS3622XS+ Or I can make a new VM installation to get RedPill again and access to the integrate seralizer 😂 Just boot tinycore RP on the same VM you already have running and use built-in generator to generate a SN then run commands again to build redpill using that SN. It will update your existing install to use the new SN. That being said, I don't know if using a generated serial # will work or not. Wondering if AME needs an actual real SN from a real SN unit. Quote
apriliars3 Posted March 4, 2023 #9 Posted March 4, 2023 I have this issue "MD5 mismatch" root@DVA1619:/volume1/Almacenamiento# python /volume1/Almacenamiento/ame.py Patching MD5 mismatch Quote
IG-88 Posted March 8, 2023 #10 Posted March 8, 2023 (edited) On 2/21/2023 at 5:15 PM, waazdakka said: I tried the script anyway but I obtain: ./ame.py: line 1: import: command not found ./ame.py: line 2: import: command not found ./ame.py: line 3: $'\r': command not found ./ame.py: line 4: r: command not found ./ame.py: line 5: syntax error near unexpected token `(' ./ame.py: line 5: `s = [(0x1F28, 0), (0x48F5, 1), (0x4921, 1), (0x4953, 1), (0x4'75, 1), (0x9AC8, 2)] just use: python ame.py On 3/4/2023 at 12:38 PM, apriliars3 said: root@DVA1619:/volume1/Almacenamiento# python /volume1/Almacenamiento/ame.py Patching MD5 mismatch check your installed AME (aka CodecPack) version its tested/used with "3.0.1-2004" that came out 9/2022 and it is atm still the recent version https://archive.synology.com/download/Package/CodecPack/3.0.1-2004 Edited March 8, 2023 by IG-88 1 Quote
waazdakka Posted March 9, 2023 #11 Posted March 9, 2023 (edited) Wow thanks, was stupid to not test this... AME activated, it seems I don't need to change my serial eventually.. Thanks again! (I guess I don't have AAC since I didn't install Audio Station, but I have a doubt on the version?) Edited March 9, 2023 by waazdakka Quote
IG-88 Posted March 10, 2023 #12 Posted March 10, 2023 (edited) On 3/9/2023 at 10:57 AM, waazdakka said: (I guess I don't have AAC since I didn't install Audio Station, but I have a doubt on the version?) you will also need to patch some files to get videostation working properly (at least when using any random serial) https://xpenology.com/forum/topic/24864-transcoding-without-a-valid-serial-number/?do=findComment&comment=439520 i did not use the file as it was intended i was more looking inside it to see what it was trying to do, it might work for you as it is but i did not tested it that way if you look inside the start.sh you will see that this one is about patching the files needed (starting it without anything will give you a short help but in the end you will need to start it with -p to ptach things) https://raw.githubusercontent.com/apriliars3/synocodectool-patch/master/patch.sh the AMEpack.tgz will also contain parts for aac audio so you can "enrich" the stuff you already have with that with these things videostation should work properly (also with qsv and transcoding if the i915 stuff is working properly), but i did not test it much as i usually replay just files over network shares and there is jellyfin as spk package too edit: and just to complete it, you might want to use this patch to get dts working https://raw.githubusercontent.com/AlexPresso/VideoStation-FFMPEG-Patcher/main/patcher.sh Edited March 10, 2023 by IG-88 1 Quote
wq2020wdm Posted March 26, 2023 #13 Posted March 26, 2023 Hello, I upgraded my system to 7.2 beta. But I couldn't activate the ame. Is it because the ame.py doesn't support 7.2 beta? Quote
apriliars3 Posted March 26, 2023 #14 Posted March 26, 2023 Hello, I upgraded my system to 7.2 beta. But I couldn't activate the ame. Is it because the ame.py doesn't support 7.2 beta?Other kernel. Which loader support now DSM 7.2? My bootloader fail compilation. Quote
wq2020wdm Posted March 28, 2023 #15 Posted March 28, 2023 On 3/26/2023 at 11:37 PM, apriliars3 said: Other kernel. Which loader support now DSM 7.2? My bootloader fail compilation. I got the bootloader from a Chinese website. Running dsm 7.2 very well now. Quote
AlexSoft_58 Posted March 28, 2023 #16 Posted March 28, 2023 1 час назад, wq2020wdm сказал: I got the bootloader from a Chinese website. Running dsm 7.2 very well now. Good afternoon. Share a link to the downloader if you don't mind. Quote
wq2020wdm Posted March 29, 2023 #17 Posted March 29, 2023 (edited) On 3/28/2023 at 5:25 PM, AlexSoft_58 said: Good afternoon. Share a link to the downloader if you don't mind. https://wp.gxnas.com/11849.html Browse the above website before downloading the bootloader to make sure the bootloader includes your network driver. And you can download the bootloader from here: https://d.gxnas.com/GXNAS网盘-OneDrive/黑群晖/黑群晖DSM6.24和DSM7.x测试版 Edited March 29, 2023 by wq2020wdm 1 Quote
topcat Posted April 26, 2023 #18 Posted April 26, 2023 hi, for DSM 7.2 RC with AME 3.1.0-3005, changed hash accordingly and get the following: Patching Checking whether patch is successful... Patch is unsuccessful, retcode = 256 Quote
SayonaRrRa Posted June 8, 2023 #19 Posted June 8, 2023 I patched the AME, but it still cant transcode anything. I'm on DSM 7.1.1-42962 Update 5 and have two movies in my video folder. I have two identical Baremetal installs with 3622xs+ both have AME patched/activated but only one works fine and can transcode to my vlc player on my phone. The other one does not. I don't know where I'm going wrong. Quote
loveburn Posted June 11, 2023 #20 Posted June 11, 2023 (edited) В 18.11.2022 в 11:56, wangsiji сказал: This patcher enables Advanced Media Extensions 3.0 for you, without having to login account. Download AME3.0 from store. Put the following Python script to any location. Run it with root. Done. Hello dear, after starting script system answer is Patching MD5 Mismatch how i can fix it? Latest AME 3-1-0-3005 And latest DSM 7.2.64570 DS918+ real mac real sn UPD: AME Activated via native mode! Edited June 11, 2023 by loveburn Quote
Zaico Posted June 13, 2023 #21 Posted June 13, 2023 On 6/11/2023 at 11:29 AM, loveburn said: Hello dear, after starting script system answer is Patching MD5 Mismatch how i can fix it? Latest AME 3-1-0-3005 And latest DSM 7.2.64570 DS918+ real mac real sn UPD: AME Activated via native mode! Please tell, what is native mode? Quote
loveburn Posted June 21, 2023 #22 Posted June 21, 2023 В 13.06.2023 в 18:14, Zaico сказал: native just use right MAC and SN Quote
kiberturist Posted June 23, 2023 #23 Posted June 23, 2023 (edited) В 18.11.2022 в 11:56, wangsiji сказал: This patcher enables Advanced Media Extensions 3.0 for you All fine on 7.2 arpl-i18n, thanks! Edited June 23, 2023 by kiberturist Quote
wangsiji Posted June 25, 2023 Author #24 Posted June 25, 2023 (edited) For 7.2 you may try this one (downloaded from https://mi-d.cn/d/ame72-3005.py , originating from import hashlib import os r = ['669066909066906690', 'B801000000', '30'] s = [(0x3718, 0), (0x60A5, 1), (0x60D1, 1), (0x6111, 1), (0x6137, 1), (0xB5F0, 2)] prefix = '/var/packages/CodecPack/target/usr' so = prefix + '/lib/libsynoame-license.so' print("Patching") with open(so, 'r+b') as fh: full = fh.read() if hashlib.md5(full).digest().hex() != '09e3adeafe85b353c9427d93ef0185e9': print("MD5 mismatch") exit(1) for x in s: fh.seek(x[0] + 0x8000, 0) fh.write(bytes.fromhex(r[x[1]])) lic = '/usr/syno/etc/license/data/ame/offline_license.json' os.makedirs(os.path.dirname(lic), exist_ok=True) with open(lic, 'w') as licf: licf.write('[{"attribute": {"codec": "hevc", "type": "free"}, "status": "valid", "extension_gid": null, "expireTime": 0, "appName": "ame", "follow": ["device"], "duration": 1576800000, "appType": 14, "licenseContent": 1, "registered_at": 1649315995, "server_time": 1685421618, "firstActTime": 1649315995, "licenseCode": "0"}, {"attribute": {"codec": "aac", "type": "free"}, "status": "valid", "extension_gid": null, "expireTime": 0, "appName": "ame", "follow": ["device"], "duration": 1576800000, "appType": 14, "licenseContent": 1, "registered_at": 1649315995, "server_time": 1685421618, "firstActTime": 1649315995, "licenseCode": "0"}]') print("Checking whether patch is successful...") ret = os.system(prefix + "/bin/synoame-bin-check-license") if ret == 0: print("Successful, updating codecs...") os.system(prefix + "/bin/synoame-bin-auto-install-needed-codec") print("Done") else: print(f"Patch is unsuccessful, retcode = {ret}") Edited June 25, 2023 by wangsiji 1 2 Quote
darknebular Posted June 26, 2023 #25 Posted June 26, 2023 (edited) I have a FFmpeg and (GStreamer) Wrapper that enable to you to play AAC, DTS, EAC3, TrueHD and into the installer (Option P in the Main menu) has a license's crack. The code for the crack is an adaptation and addons by me from the code of wangsiji. https://github.com/darknebular/Wrapper_VideoStation I hope that It is useful for somebody. Give me a star if you find this useful, the Advanced Wrapper is the unique Wrapper with 5.1 support when It needs to transcode something. There is a possibility to uninstall the crack too. Best regards. Edited June 26, 2023 by darknebular 3 Quote
