Ariloum Posted November 7, 2022 Share #1 Posted November 7, 2022 (edited) Hello, I used to try installing with the TCRP loader (tinycore-redpill-uefi.v0.9.2.9) a few different builds/DSM versions, but all of them were stucked on same step: "Starting kernel with USB boot" I tried these platforms: DS3615xs, DS1621+ (2-3 versions of each like 7.1.0-42661) I also tried to disable in the BIOS C1M, hyperthreading and few other options I tried https://finds.synology.com/ - nothing found there is no option in bios to turn on/off sata hot swap there is no option in bios to disable m2 and audio Hardware: motherboard Biostar B550T-silver cpu Ryzen 5 5600G memory 2x8Gb Kingston 3200 (non-ECC) disks: 4x16TB Seagate linux commands: I started with short way ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh serialgen DS1621+ ./rploader.sh build ds1621p-7.1.0-42661 ./rploader.sh backup exitcheck.sh reboot after searching google/reading some forums ended up with this (tried to add Realtek RTL8125B drivers, but there was only RTL8125): ./rploader.sh update ./rploader.sh fullupgrade ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh ext ds1621p-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/r8125/rpext-index.json ./rploader.sh serialgen DS1621+ realmac ./rploader.sh build ds1621p-7.1.0-42661 manual ./rploader.sh backup ./rploader.sh backuploader exitcheck.sh reboot Is there any logfile which I could check? Any other suggestions? Edited November 7, 2022 by Ariloum Quote Link to comment Share on other sites More sharing options...
Ariloum Posted November 8, 2022 Author Share #2 Posted November 8, 2022 > hyperthreading I mean virtualization - misstyped Quote Link to comment Share on other sites More sharing options...
rojoone2 Posted November 8, 2022 Share #3 Posted November 8, 2022 Other users have had problems with the Realtek 8125B NIC. You may have to put in a driver request here: Quote Link to comment Share on other sites More sharing options...
