Automated RedPill Loader (ARPL)
fbelavenuto
39 minutes ago, Joge said:
Hello fbelavenuto,
Thanks for your work !
I've an issue with my HP Microserver Gen8 with an HP NC365T network card (Intel 82580).
I'm stuck on Booting...
I tried 2 different USB keys, same problem.
Any idea ?
Thanks
Hello, I have HP Microserver Gen8 with an HP NC365T. Explain what is your problem. I have DSM 7.1.1-42661 Update 4 with ARPL 0.4 alpha 4 witouth issues.
update arl to alpha 5 and loader dont boot, hang here
edit: ok , i can start menu.sh from console, but i think something is wrong
edit2: ,update addons, modules etc etc, i build 42962 (im on 42951) add 9p addon (my system is vm proxmox machine, need virtio), boot DSM and nas miss my virtio eth, i dont have a IP.
Edited by frezeen
update
Hello apriliars3,
I was in 6.2 and my boot was corrupted.
I took the opportunity to switch to 7.1 with tinycore-redpill but I loaded the wrong .pat file, I loaded 7.1.1-42962...
By searching a little I saw that this version is compatible and I fell on the ARPL but the last version does not boot.
I don't know if is it difficult to change the version on the bootloader.
Same with Proxmox and VMWare. @fbelavenuto ARPL 0.4 alpha 5 is corrupt
Edited by apriliars3
35 minutes ago, Joge said:
Hello apriliars3,
arpl 0.4 alpha 5 no works. No boot Configuration loader.
Just tried 0.4 alpha 4 and arpl does'nt give me an IP, my network card driver on TCRP is recognized as an e1000e.
Now i'm gonna try the new alpha5, finger crossed
Update: no luck with alpha 5 either, no ip assigned at all (checked on router) so port 7681 or whatever doesn't matter
Edited by Herrnobiz
Thanks for the info apriliars3
I will test.
EDIT : It works for me
Just need to find the good IP and add the port 7681.
Thank you again apriliars3 for your help and fbelavenuto for ARPL !
Edited by Joge
ok i success update to 42962 from 42951
from web nas i manual install 42962, vm reboot to config loader... from console or loader interface, update arpl to apha5, selct what i need (9p addon) , build loader, restart and system is updated
im not sure if u can skip some steps, this is what i do for update my system
Edited by frezeen
please have a lokk at the arpl issues: Klick
28 minutes ago, nk950357 said:
just ask a noob question:
does arpl needs boot display?
after update can it run postupdate without keyboard and display, only by http://ip:7681? thanks
You can use:
- menu.sh
- ssh (WinScp, Putty, etc)
- ip:7681
Asrock QC5000 8GB, 1 HDD, clean installation. After compiling the bootloader and booting from it, the system freezes, the link disappears and the usb ports are disconnected. I waited for 10-15 minutes. I used alpha 5 and alpha 6, on alpha 4 the link in the router is defined as 10 Mbit, but after a few minutes it also disappears. Tried builds from DS3617 and DS918+, 7.0.1-7.1.1
After rebooting the assembled loader, the network disappears. I assume that the problem is that there is no driver for network adapters Intel 82579LM Gigabit Ethernet; Intel Pro 1000 CT Gigabit.
Version 03 alpha built correctly.
