Gogol123 Posted November 30, 2016 #1 Posted November 30, 2016 Hi all I just upgraded my N54L from DSM 5.2 to 6.0 using jun 1.0.1 bootloader, everything look ok except the USB device are no more recognize . I'm using my NAS to also host a domotic application , so i have several USB controller attached to the host (for example a Zwave controller) , but since the upgrade none of them are recognize they are even not showing up in any log or in lsusb command. The specific driver seem to be loaded correclty ehci_hcd 39332 1 ehci_pci usbcore 174439 18 ch341,etxhci_hcd,usblp,uhci_hcd,usb_storage,cp210x,usbserial,ti_usb_3410_5052,ehci_hcd,ehci_pci,pl2303,usbhid,usbnet,ftdi_sio,ax88179_178a,xhci_hcd usb_common 1552 1 usbcore el000 14352 0 Only thing i notice is that the lsub report a strange device admin@DiskStation:/etc$ lsusb Bus 002 Device 003: ID f400:f400 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub admin@DiskStation:/etc$ lsusb -v -d f400:f400 Bus 002 Device 003: ID f400:f400 Couldn't open device, some information will be missing Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0xf400 idProduct 0xf400 bcdDevice 1.00 iManufacturer 1 iProduct 2 iSerial 3 bNumConfigurations 1 Couldn't get configuration descriptor 0, some information will be missing Couldn't get configuration descriptor 0, some information will be missing Any hint on troubleshooting action i can take to progress ? Thanks for your help
ronin Posted January 7, 2017 #2 Posted January 7, 2017 Did you ever get this to work? would be great if you could tell how? I am dealing with the same issue here.
esme518 Posted January 7, 2017 #3 Posted January 7, 2017 After I upgraded my N3700-ITX to DSM 6.0.2-8451 Update 7. All the usb3.0 port became unusable, although usb3.0 chip can be recognized as ASM107x - ASMedia Technology Inc. However usb2.0 port still works.
ronin Posted January 21, 2017 #4 Posted January 21, 2017 Hi all I just upgraded my N54L from DSM 5.2 to 6.0 using jun 1.0.1 bootloader, everything look ok except the USB device are no more recognize . I'm using my NAS to also host a domotic application , so i have several USB controller attached to the host (for example a Zwave controller) , but since the upgrade none of them are recognize they are even not showing up in any log or in lsusb command. The specific driver seem to be loaded correclty ehci_hcd 39332 1 ehci_pci usbcore 174439 18 ch341,etxhci_hcd,usblp,uhci_hcd,usb_storage,cp210x,usbserial,ti_usb_3410_5052,ehci_hcd,ehci_pci,pl2303,usbhid,usbnet,ftdi_sio,ax88179_178a,xhci_hcd usb_common 1552 1 usbcore el000 14352 0 Only thing i notice is that the lsub report a strange device admin@DiskStation:/etc$ lsusb Bus 002 Device 003: ID f400:f400 Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub admin@DiskStation:/etc$ lsusb -v -d f400:f400 Bus 002 Device 003: ID f400:f400 Couldn't open device, some information will be missing Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0xf400 idProduct 0xf400 bcdDevice 1.00 iManufacturer 1 iProduct 2 iSerial 3 bNumConfigurations 1 Couldn't get configuration descriptor 0, some information will be missing Couldn't get configuration descriptor 0, some information will be missing Any hint on troubleshooting action i can take to progress ? Thanks for your help Hi Gogel123, I am on the same machine as you and running dsm6 with jun's loader. Since the kernel is based on the DMS6 beta version it looks like it's not working. Jadahl does not support xpenology machines, so I am wondering how you did it? I use it for Domoticz RFXcom and P1 smart meter cable. Any ideas? Much appreciated.
