Vodka2014 Posted October 14, 2022 #1 Posted October 14, 2022 Good Day I do not know if this is the correct please if not please move it. I have 2 Systems listed below that i want to move to DSM 7.x (Latest One) I have seen the tutorials but i am not sure what one to use for this in terms of the Version E.G broadwellnk-7.1.0-42661. Hardware: Asus TUF H370 I3-9100 16 GB RAM 1x Intel Enterprise SSD WD Drives XT-XINTE Add On Card PCIE SATA Controller SATA3.0 PCI-E x4 GEN3 Card Adapter Current DSM: DS918+ DSM 6.2.3-25426 Update 3 Jun Loader v1.04b ---------------- Hardware: HP MicroServer GEN8 Current DSM: DS3615xs DSM 6.2.3-25426 Update 3 Thanks in advanced. Quote
WiteWulf Posted October 14, 2022 #2 Posted October 14, 2022 Okay, based purely on CPU generation and the information here: - your Asus device with i3-9100 is Coffee Lake and will run anything supported in xpenology - your Gen8 is limited to pre-Haswell architectures, and I'd recommend DS3622xs+ That said, I've no idea if your SATA card will work. You'll need to find out what driver it's using and if it's in the redpill repo yet. Quote
Vodka2014 Posted October 16, 2022 Author #4 Posted October 16, 2022 Hi @WiteWulf So my Card is as per the below. I will have to test this out before I do my prod setup or just see if it is supported. 5 Port SATA3.0 JMicron JMB585 Chip Set Thanks Quote
