Unbannable Posted October 10, 2022 #1 Posted October 10, 2022 (edited) Hello! i have a problem, i did everthing like in the tutorial but when it says booting the kernel and i look on the synology website or the app, the synology isn´t there. Can someone help me? Edited October 10, 2022 by Unbannable Quote
polanskiman Posted October 10, 2022 #2 Posted October 10, 2022 3 minutes ago, Unbannable said: Hello! i have a problem, i did everthing like in the tutorial but when it says booting the kernel and i look on the synology website or the app, the synology isn´t there. Can someone help me? You really need to provide some more information else I don't see much help coming your way. Quote
Unbannable Posted October 10, 2022 Author #3 Posted October 10, 2022 (edited) Im using the apollolake-7.1.0-42661 version with the redpill tinycore-redpill.v0.9.2.7.img loader on an acer H340 server! im also using a sandisk 16Gb usb stick! i used the tinycore-redpill.v0.9.2.7.img. do i need to use the v0.9.2.6? @Polanskiman Edited October 10, 2022 by Unbannable Quote
rojoone2 Posted October 10, 2022 #5 Posted October 10, 2022 26 minutes ago, Unbannable said: Im using the apollolake-7.1.0-42661 version with the redpill tinycore-redpill.v0.9.2.7.img loader on an acer H340 server! im also using a sandisk 16Gb usb stick! i used the tinycore-redpill.v0.9.2.7.img. do i need to use the v0.9.2.6? @Polanskiman Your hardware is to old to support the apollolake platform. You need a Haswell processor for that platform. Try building a DS3622xs+ (broadwellnk) which supports most hardware. You may need to edit your user_config.json manually 1 Quote
polanskiman Posted October 10, 2022 #6 Posted October 10, 2022 41 minutes ago, Unbannable said: i used the tinycore-redpill.v0.9.2.7.img. do i need to use the v0.9.2.6? Also, important to note. Be aware that you are using a development version of the loader. Stable version stops at v0.8.0.5 https://github.com/pocopico/tinycore-redpill/tree/stable 1 Quote
Unbannable Posted October 10, 2022 Author #7 Posted October 10, 2022 Now i cant build it anymore. i always get this error: @rojoone2 Quote
Unbannable Posted October 10, 2022 Author #8 Posted October 10, 2022 and i also can´t use ./rploader update Quote
rojoone2 Posted October 10, 2022 #9 Posted October 10, 2022 Looks like you are still trying with TCRP 0.9.2.7. Try your build with TCRP 0.8.0.5 like @Polanskiman suggested. It is a stable release. Quote
rojoone2 Posted October 10, 2022 #10 Posted October 10, 2022 (edited) Can you boot into the BIOS and check that your time is correct? Can you post the output of the build? Edited October 10, 2022 by rojoone2 Quote
Unbannable Posted October 10, 2022 Author #11 Posted October 10, 2022 oh i didnt read right sorry. i used the 0.9.2.5 and it didnt work... Quote
Unbannable Posted October 10, 2022 Author #12 Posted October 10, 2022 Yeah the time is correct! Quote
Unbannable Posted October 10, 2022 Author #13 Posted October 10, 2022 @rojoone2how can i use the stable version. it only comes in a .zip Quote
rojoone2 Posted October 10, 2022 #15 Posted October 10, 2022 There are three images.. you only need this one : tinycore-redpill.v0.8.0.5.img.gz. I don't believe your BIOS has UEFI. Try your build again. Quote
Unbannable Posted October 10, 2022 Author #16 Posted October 10, 2022 @rojoone2 now i cant even update it Quote
Unbannable Posted October 10, 2022 Author #17 Posted October 10, 2022 it always says Failed to connect to github.com, connection refused. But Lan is working and the time is also right. or do i need to enter a specific timezone? Quote
rojoone2 Posted October 10, 2022 #18 Posted October 10, 2022 (edited) Enter ifconfig in the terminal window and post a picture. I have not had to set my time to a different time zone to build a loader. Can you ping github.com from terminal? Edited October 10, 2022 by rojoone2 Quote
rojoone2 Posted October 10, 2022 #22 Posted October 10, 2022 6 minutes ago, Unbannable said: Dosen't look like you are able to reach github from your network. Should look like this: Check you firewall settings 1 Quote
Unbannable Posted October 10, 2022 Author #23 Posted October 10, 2022 yeah our fritz box blocked the server because we put a motherboard from a newer model inside. im sorry for wasting ur time Quote
Castelrink Posted October 21, 2022 #24 Posted October 21, 2022 Hello everyone, The oldest version of tinycore-repill that I can find is v0.9.2.6 (https://github.com/pocopico/tinycore-redpill/tags). A month ago I could do the complete installation but with the latest versions there is no way. All the best. Quote
