drbytes Posted November 7, 2016 Share #1 Posted November 7, 2016 So my build has been working fine for the last 3 months, no issues. However, two days ago the power cut out and I believe it might have corrupted the USB where xpe is installed on. All the shares are there and the networking works but I'm unable to use a browser to log in. Apparently a bunch of files are missing. So .. what re my options? Can just start over again, i mean, put the boot on the usb and then install the pat via the syno assistant,.. will that work and keep all my files ? I have a jbod config. cheers Link to comment Share on other sites More sharing options...
berwhale Posted November 7, 2016 Share #2 Posted November 7, 2016 The USB drive is just a bootloader, so just recreate it with the correct version of Xpenology. DSM and it's config is stored across all the HDDs in your array. Link to comment Share on other sites More sharing options...
