DSM 7.1-42661 Update 4
Message added by Polanskiman,
Please read the READ ME topic before posting:
Révélation
Important notes
  1. Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it. Only Synology NAS with DSM 7.1 installed can be updated to this version.
    • The update is not available in your region yet. The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
    • Your DSM is working fine without having to update. The system evaluates service statuses and system settings to determine whether it needs to update to this version.
  2. This update will restart your Synology NAS.
Fixed Issues
  1. Fixed an issue where after restarting DSM, certain packages might fail to function properly if users had installed Synology High Availability.
  2. Fixed an issue where users might not be able to sign in to their Gmail account when configuring the sender at Control Panel > Notification > Email.
- Outcome of the update: SUCCESSFUL
- DSM version prior update: DSM 7.1-42661 Update 3
- Loader version and model: Automated Redpill Loader DVA3221
- Using custom extra.lzma: NO
- Installation type: BAREMETAL – HP Envy 800 PC Series (with Nvidia GTX 1650)
- Loader version and model: Yet Another Jun`s Mod x RedPill DS2422+ v7.0.1-42218
- Installation type: BAREMETAL – Lenovo ThinkCentre Edge71 Intel i3 2120
- Loader version and model: Automated Redpill Loader DS918+
- Installation type: VIRTUAL VMWARE – NUC J3455
- Loader version and model: Yet Another Jun`s Mod x RedPill DS3622xs+ v7.0.1-42218
- Installation type: BAREMETAL – HP Microserver Gen 8
- Loader version and model: Tinycore Redpill DS3615xs
- Installation type: BAREMETAL – HP Microserver Gen8
Notes: straight from 7.1 to U4. Ran postupdate via TCRP SSH - seemed to think I was on U3 but still worked. Weirdly rebooted back into TCRP loader again, so had to restart and manually select DSM.
- DSM version prior update: DSM 7.1.0-42661 Update 3
- Loader version and model: Tinycore-Redpill v0.8.0.3 - DS3622xs+
- Installation type: BAREMETAL - HPE MicroServer Gen10 Plus
- Additional comments: step 1: Upgraded to DSM 7.1.0-42661u4 via GUI. After Step 1 update, booted into TCRP and run:
./rploader.sh update
sudo ./rploader.sh postupdate broadwellnk-7.1.0-42661
exitcheck.sh reboot
Note: It may find in TCRP when doing postupdate step, that it has found update 3. But ignore it and say yes. DSM will be updated to Update 4 anyway.
- Loader version and model: Tinycore-Redpill v0.8.0.5 - DS918+
- Installation type: BAREMETAL - Ryzen 3900x
- Additional comments: Upgraded to DSM 7.1.0-42661u4 via GUI
- Loader version and model: Tinycore-Redpill v0.8.0.5 - DS3622xs+
- Installation type: BAREMETAL - Thecus - N4200eco
- Installation type: BAREMETAL - Qnap - TS-453A
- Loader version and model: Automated Redpill Loader 0.3a7 DS920+
- Installation type: VMWare ESXi 7.03f @ custom Z490-i build (i3-10100T)
- Additional comments: Upgraded: via GUI, no fancy stuff to do. Everything works great, CometLake Sata and iGPU in passthrough for real smart data and transcoding.
- Installation type: VMWare ESXi 6.7.0 U3b @ custom build Asus Z170I-PRO, Intel Core i5-6600K, passthrough: LSI SAS9211-8i IT mode controller.
- Additional comments: Upgraded: DSM 7.1.0-42661u4 via GUI, no additional steps.
- Installation type: BAREMETAL - Supermicro X10SDV-TLN4F, LSI SAS2008
- Additional comments: Upgraded via GUI
- Loader version and model: TinyCore RedPill v0.8.0.5 - DS3622xs+
- Installation type: BAREMETAL - HP ProLiant MicroServer Gen8
- Additional comments: DSM 7.1.0-42661 Update 4 via GUI
- DSM version prior update: DSM 7.1.0-42661-3
- Loader version and model: TinyCore RedPill v0.8.0.5 - DVA3221
- Installation type: BAREMETAL - QNAP TS-469 Pro
- Additional comments: Update was executed via GUI and executed postinstall command right after reboot.
- DSM version prior update: DSM 7.1.0-42661 Update 2
- Loader version and model: Tinycore-Redpill v0.8.0.3 - DS3617xs
- Additional comments: step 1: Upgraded to DSM 7.1.0-42661u4 via GUI. Booted into TCRP and run:
exitcheck.sh reboot
- DSM version prior update: DSM 7.1.0-42661 Update 4
- Loader version and model: Tinycore-Redpill 0.8.0.3 - DS3622xs+ (tinycore-redpill-uefi.v0.8.0.0.img.gz)
- Installation type: BAREMETAL - MACHINIST X99 Motherboard LGA 2011-3/ Intel Xeon E5 2673 V3/ 16GB (2*8GB) DDR4 (non ECC)  2666MHz RAM
1:    From DSM Control Panel> Update & Restore>Manual DSM Update and wait for reboot
2:
tc@box:~$ ./rploader.sh update
3:
tc@box:~$ sudo ./rploader.sh postupdate broadwellnk-7.1.0-42661
4:
 tc@box:~$ exitcheck.sh reboot
- Installation type: BAREMETAL - HP N40L
- Additional comments: After manually installed .pat update from GUI,booted into TCRP and run
exitcheck.sh reboot
- Loader version and model: Tinycore-Redpill v0.9.0.2 - DS918+
- Additional comments: Upgraded to DSM 7.1.0-42661 Update 4 via GUI. Booted into TCRP and run:
sudo ./rploader.sh postupdate apollolake-7.1.0-42661
exitcheck.sh reboot
Transcoding is still working:
cat /usr/syno/etc/codec/activation.conf
{"success":true,"activated_codec":["hevc_dec","ac3_dec","h264_dec","h264_enc","aac_dec","aac_enc","mpeg4part2_dec","vc1_dec","vc1_enc"],"token":"12345678XXXXXXXXX"}
- Loader version and model: TCRP v0.8.0.5 DS918+
- Installation type: BAREMETAL – Celeron G4900; Asrock H310M-HDV; 4GB DDR4, 3 disks, onboard NIC RTL8111H
- Additional comments: Installed DSM 7.1.0-42661 Update 4 from the GUI; then booted into tinycore:
sudo -i
(note: Update 3 was detected, selected “Yes” to continue)
exitcheck.sh reboot
- Installation type: BAREMETAL – ASROCK J3455B-ITX; 8GB DDR4
- DSM version prior update: 7.1-42661-3
- Loader version and model: Tinycore-Redpill 0.9.0.2 DS918+ 7.1-42661-4
- Installation type: Baremetal Asrock J3455m
exitcheck.sh reboot
- DSM version prior update: DSM 7.1.0-42661 Update 1
- Loader version and model: Tinycore-Redpill v0.9.0.2 - DS3622xs+
- Using custom extra.lzma: YES - ACPID & VIRTIO
- Installation type: VM - PROXMOX
- Installation type: BAREMETAL - Gigabyte GA-H81M-S1, ASMEDIA 1061
- Loader version and model: Tinycore-Redpill v7.1.0. - DS3622xs+ Beta
- Using custom extra.lzma: No
exitcheck.sh reboot
- DSM version prior update: DSM 7.1-42661 Update 4
- Lo ader version and model: Automated Redpill Loader v0.4-alpha4 V0.8- DS918+
- Installation type: BAREMETAL - Msi B360m Pro-vd / Intel Celeron G5400 Gold / 2x4Gb ram DDR-4
- Additional comments: Reboot require
