Bullseye Posted August 2, 2022 #1 Posted August 2, 2022 Hi, i have big problem with my "NAS"..... i format it because i wanted DVA3221 for recognization and im stuck (im not really want come back to 6.2.3 like before). With tinycore-redpill (8.0 and DEV 9.0) im always stuck when im upload PAT file. Via serial console i see some errors when create md0 raids (disc is clean): [ 375.353260] EXT4-fs (md0): couldn't mount as ext3 due to feature incompatibilities [ 379.375233] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: (null) On 918+, 920+ nad DVA 3221 and 1622. Once it install proper, im install on DSM Docker, HyperBacku and im reboot system and again it wont install PAT file. Can somebody helps me what exacly is heppend ? Full log: https://pastebin.pl/view/19e586f3 Quote
Peter Suh Posted December 9, 2022 #2 Posted December 9, 2022 I recommend you to try M SHELL for TCRP FRIEND, which I developed. It has evolved a lot from the old TCRP and has been changed to enable loader builds using convenient MENU. A user guide is also shared on Github at the link below. https://github.com/PeterSuh-Q3/tinycore-redpill/releases/tag/v0.9.3.0-1 Quote
