quiri99 Posted July 8, 2022 #1 Posted July 8, 2022 Hi guys i tried to install dsm7 on tcrp (legacy version) but don't work, the first error is that the command for mapping the usb for the installation ./rploader.sh identifyusb now , i select the usb but the answer is: Sorry, no usb disk could be identified. i tried to write the grub but i don't know if it's correct. (could you post me a grub with empty vid and pid) The second problem was in the installation with modified grub, on reboot the nas is not detected. i thought it is a driver problem, i saw that there is a package to put in the second partition but it is only for previous versions. how can i solve? hardware asus m2n68-la (lan Realtek RTL8111B/C & RTL8112L), amd athlon x2 215, 4gb ram Quote
rojoone2 Posted July 8, 2022 #2 Posted July 8, 2022 Your USB stick is the problem. You need the correct PID/VID for the pat file to install properly. What brand is it? Quote
quiri99 Posted July 8, 2022 Author #3 Posted July 8, 2022 Just now, rojoone2 said: Your USB stick is the problem. You need the correct PID/VID for the pat file to install properly. What brand is it? Kingston vid=0x0951 pid=0x1666 Quote
quiri99 Posted July 8, 2022 Author #4 Posted July 8, 2022 i tried again by changing vid and pid from nano in tiny core, now finds.synology finds 4 servers but on wrong ip they don't work... synology assistant finds 0 servers. Quote
rojoone2 Posted July 8, 2022 #5 Posted July 8, 2022 Do you have any other Synology boxes on your network? How many network cables are connected to your build? Can you post the output from your installation script? Quote
quiri99 Posted July 8, 2022 Author #6 Posted July 8, 2022 (edited) no i haven't, 1 nic i tried with another usb to install the dsm 6 with "DS3617xs 6.1 Jun's Mod V1.02b (MBR_Genesys)" with the "extra3617_v4.8" and the nas was detected but i have error no disk found without extra3617 i dont found the nas log.txt Edited July 8, 2022 by quiri99 Quote
