alantang Posted July 7 Share #1 Posted July 7 Hello: No matter whay model I choose it always use DS920+? I have try DS3615xs & DS3622xs+ but it also show DS920+ Did I have somthing missed? Below is the command that I use. 1.) After login tc with password, it show "tc@box:~$" at command prompt 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3615xs realmac 6.) ./rploader.sh build geminilake-7.1.0-42661 7.) exitcheck.sh reboot I answer "y" when it prompt on each items after reboot, it show the model is DS920+ in the Synology Assistant Quote Link to comment Share on other sites More sharing options...
0 rojoone2 Posted July 7 Share #2 Posted July 7 2 hours ago, pocopico said: Geminilake is the ds920 , bromolow is the DS3615. It would make more sense to just use the model for building, but that was decided when the platforms were only two Yeah.. kinda over looked his build command! For the DS3615xs it should be: 1.) ./rploader.sh clean 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3615xs realmac 6.) ./rploader.sh build bromolow-7.1.0-42661 7.) exitcheck.sh reboot For the DS3622xs+ 1.) ./rploader.sh clean 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3622xs+ realmac 6.) ./rploader.sh build broadwellnk-7.1.0-42661 7.) exitcheck.sh reboot For the DS920+: 1.) ./rploader.sh clean 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS920+ realmac 6.) ./rploader.sh build geminilake-7.1.0-42661 7.) exitcheck.sh reboot Quote Link to comment Share on other sites More sharing options...
0 rojoone2 Posted July 7 Share #3 Posted July 7 1 hour ago, alantang said: Hello: No matter whay model I choose it always use DS920+? I have try DS3615xs & DS3622xs+ but it also show DS920+ Did I have somthing missed? Below is the command that I use. 1.) After login tc with password, it show "tc@box:~$" at command prompt 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3615xs realmac 6.) ./rploader.sh build geminilake-7.1.0-42661 7.) exitcheck.sh reboot I answer "y" when it prompt on each items after reboot, it show the model is DS920+ in the Synology Assistant I don't see a "clean" command in toy steps. Are you using the same USB drive? You may need to create a new USB and start fresh. I found that starting fresh solves many issues. Try adding this as the first step in your commands: ./rploader.sh clean now Quote Link to comment Share on other sites More sharing options...
0 pocopico Posted July 7 Share #4 Posted July 7 (edited) 2 hours ago, alantang said: Hello: No matter whay model I choose it always use DS920+? I have try DS3615xs & DS3622xs+ but it also show DS920+ Did I have somthing missed? Below is the command that I use. 1.) After login tc with password, it show "tc@box:~$" at command prompt 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3615xs realmac 6.) ./rploader.sh build geminilake-7.1.0-42661 7.) exitcheck.sh reboot I answer "y" when it prompt on each items after reboot, it show the model is DS920+ in the Synology Assistant Geminilake is the ds920 , bromolow is the DS3615. It would make more sense to just use the model for building, but that was decided when the platforms were only two Edited July 7 by pocopico Quote Link to comment Share on other sites More sharing options...
0 alantang Posted July 8 Author Share #5 Posted July 8 4 hours ago, rojoone2 said: Yeah.. kinda over looked his build command! For the DS3615xs it should be: 1.) ./rploader.sh clean 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3615xs realmac 6.) ./rploader.sh build bromolow-7.1.0-42661 7.) exitcheck.sh reboot For the DS3622xs+ 1.) ./rploader.sh clean 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS3622xs+ realmac 6.) ./rploader.sh build broadwellnk-7.1.0-42661 7.) exitcheck.sh reboot For the DS920+: 1.) ./rploader.sh clean 2.) ./rploader.sh update 3.) ./rploader.sh fullupgrade 4.) ./rploader.sh identifyusb 5.) ./rploader.sh serialgen DS920+ realmac 6.) ./rploader.sh build geminilake-7.1.0-42661 7.) exitcheck.sh reboot Thanks all! I think that is the point of why always show DS920+. I just new in using tinycore redpill loader. May I know how can I found those information regarding to which model using the specific build? I will try it on tonight to test again! *PS: I just a new USB STick to perform a new build! Quote Link to comment Share on other sites More sharing options...
0 alantang Posted July 8 Author Share #6 Posted July 8 Is refer to this one? e.g. for use DS918+ should use "./rploader.sh build apollolake-7.1.0-42661" Correct? Thanks! Quote Link to comment Share on other sites More sharing options...
0 rojoone2 Posted July 8 Share #7 Posted July 8 8 hours ago, alantang said: Is refer to this one? e.g. for use DS918+ should use "./rploader.sh build apollolake-7.1.0-42661" Correct? Thanks! Yes, that is correct. Quote Link to comment Share on other sites More sharing options...
0 alantang Posted July 11 Author Share #8 Posted July 11 On 7/8/2022 at 5:39 PM, rojoone2 said: Yes, that is correct. Thanks for all to guide me solving this issue! Quote Link to comment Share on other sites More sharing options...
alantang
Hello:
7 answers to this question
