ridney Posted October 21, 2016 #1 Posted October 21, 2016 Hi, I just configured my xpenology and wanted to create my 4 x SSDs for cache but I can only configure two for R/W. Is it possible to create 4 ssds for cache in a Raid 10 or Raid 5 array?
Johnvid Posted October 21, 2016 #2 Posted October 21, 2016 You can use up to 12 SSD discs for Read/Write Cache. If the Synology site is correct. But they all have to be the same model and capacity. Raid 1, 5 and 6 are supported by Synology SSD Cache. As far as I know the R/W SSD cache function does not work on Xpeneology. What version of dsm and loader are you using?
ridney Posted October 21, 2016 Author #3 Posted October 21, 2016 SSDs are 4 x 850 evo 250gb Xpenoboot 5.2-5967.1 SSD Cache works but just cant configure more than two even for R or R/W
Johnvid Posted October 22, 2016 #4 Posted October 22, 2016 Good to know. I'm gonna dive into this. SSD Cache is also on my little list.
