smileyworld Posted June 30 Share #1 Posted June 30 I am currently switching from DSM 6.2 to 7.1 and my setup is as follows: How to expand drive number in DSM7? Now my problem is, that it is not possible to do the same trick in DSM 7 to expand beyond x drives like it was in 6.2. (My setup would allow 22 in total from which 14 are used for now) I already chattet with @Peter Suhabout this topic but unfortunetly we could not solve my problem. Things I tried: Building the loader as described by @Peter Suh (Guide) installed the latest tcrp image with rufus on usb booted in tc & connected via ssh ./rploader.sh update ./my.sh ./rploader.sh clean ./my.sh DS3622xs+J poco noclean Building the loader as described by @flyride (Guide) installed the latest tcrp image with rufus on usb booted in tc & connected via ssh ./rploader.sh update ./rploader.sh fullupgrade ./rploader.sh identifyusb ./rploader.sh serialgen DS3622xs+ #I tried building the loader with and without this command ./rploader.sh satamap vi user_config.json # adding those lines: "maxdisks" : "22", "esataportcfg" : "0x00", "usbportcfg" : "0xc000000", "internalportcfg" : "0x3fffff", ./rploader.sh build broadwellnk-7.1.0-42661 ./rploader.sh backup ./rploader.sh backuploader exitcheck.sh reboot Seutp & outcome VM or BareMetal : BareMetal Hardware (Motherboard/CPU) : MSI MPG Z390 / Intel 9900T Storage-Controller: 2x LSI SAS 9211-8i (HBA in IT mode) Hot Plug Applied : Yes Network Interface 1 : Intel i217v (e1000e) Network Interface 2 : Intel X540-T2 (10 Gbit) Network Interface 3 : Intel X540-T2 (10 Gbit) Loader : TCRP 0.4.6 version of rploader.sh : 0.8.3 Platform : 3622xs+ Platform Version : 7.1 Platform Revision : 42661-U1 GRUB Boot selection : USB Unfortunetly both methods resulted in the same outcome which is the following: My NAS looks physically like this. I numbered the drive slots from 1 - 22 to have an easier time explaining my issue. So slotnumber 1-8 are connected to HBA 2 9,10 and 17-22 are connected to HBA 1 11-16 are connected to the mainboard SATA ports I have 3 PCIx16 Slots on my mainboard First one is used for Intel X540 T2 10 GBit NIC Second one is used for HBA1 Third one is used for HBA2 Currently the slots below are occupied: 1-4 = 4 HDDs 6-9 = 4 HDDs 11-13 = 3 SSDs 17-19 = 3 SSDs = 14 drives in total. Now in this config either slot 6 or 7 isnt recognised in DSM, every other drive works. When I put the drive from slot 6 into slot 5 it is reconised, BUT unfortunately one drive from slots 1-4 is missing then. I tried this with multiple combinations. The outcome was always that 1 drive was missing (not a specific HDD/SSD or SLOT). As soon as I add more than 13 drives it keeps getting weird. Since my setup worked in DSM6 my guess is that either I am missing something or TCRP is missing something. Troubleshooting: TinyCore sd list lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop0 -> ../devices/virtual/block/loop0 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop1 -> ../devices/virtual/block/loop1 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop10 -> ../devices/virtual/block/loop10 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop11 -> ../devices/virtual/block/loop11 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop12 -> ../devices/virtual/block/loop12 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop13 -> ../devices/virtual/block/loop13 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop14 -> ../devices/virtual/block/loop14 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop15 -> ../devices/virtual/block/loop15 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop16 -> ../devices/virtual/block/loop16 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop17 -> ../devices/virtual/block/loop17 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop18 -> ../devices/virtual/block/loop18 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop19 -> ../devices/virtual/block/loop19 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop2 -> ../devices/virtual/block/loop2 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop20 -> ../devices/virtual/block/loop20 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop21 -> ../devices/virtual/block/loop21 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop22 -> ../devices/virtual/block/loop22 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop23 -> ../devices/virtual/block/loop23 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop24 -> ../devices/virtual/block/loop24 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop25 -> ../devices/virtual/block/loop25 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop26 -> ../devices/virtual/block/loop26 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop27 -> ../devices/virtual/block/loop27 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop28 -> ../devices/virtual/block/loop28 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop29 -> ../devices/virtual/block/loop29 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop3 -> ../devices/virtual/block/loop3 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop30 -> ../devices/virtual/block/loop30 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop31 -> ../devices/virtual/block/loop31 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop32 -> ../devices/virtual/block/loop32 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop33 -> ../devices/virtual/block/loop33 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop34 -> ../devices/virtual/block/loop34 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop35 -> ../devices/virtual/block/loop35 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop36 -> ../devices/virtual/block/loop36 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop37 -> ../devices/virtual/block/loop37 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop38 -> ../devices/virtual/block/loop38 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop39 -> ../devices/virtual/block/loop39 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop4 -> ../devices/virtual/block/loop4 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop40 -> ../devices/virtual/block/loop40 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop41 -> ../devices/virtual/block/loop41 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop42 -> ../devices/virtual/block/loop42 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop43 -> ../devices/virtual/block/loop43 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop44 -> ../devices/virtual/block/loop44 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop45 -> ../devices/virtual/block/loop45 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop46 -> ../devices/virtual/block/loop46 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop47 -> ../devices/virtual/block/loop47 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop48 -> ../devices/virtual/block/loop48 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop49 -> ../devices/virtual/block/loop49 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop5 -> ../devices/virtual/block/loop5 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop50 -> ../devices/virtual/block/loop50 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop51 -> ../devices/virtual/block/loop51 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop6 -> ../devices/virtual/block/loop6 lrwxrwxrwx 1 root root 0 Jun 26 09:08 loop7 -> ../devices/virtual/block/loop7 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop8 -> ../devices/virtual/block/loop8 lrwxrwxrwx 1 root root 0 Jun 26 09:11 loop9 -> ../devices/virtual/block/loop9 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram0 -> ../devices/virtual/block/ram0 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram1 -> ../devices/virtual/block/ram1 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram2 -> ../devices/virtual/block/ram2 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram3 -> ../devices/virtual/block/ram3 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram4 -> ../devices/virtual/block/ram4 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram5 -> ../devices/virtual/block/ram5 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram6 -> ../devices/virtual/block/ram6 lrwxrwxrwx 1 root root 0 Jun 26 09:08 ram7 -> ../devices/virtual/block/ram7 lrwxrwxrwx 1 root root 0 Jun 26 09:08 sda -> ../devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jun 26 09:08 sdb -> ../devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jun 26 09:08 sdc -> ../devices/pci0000:00/0000:00:17.0/ata5/host4/target4:0:0/4:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Jun 26 09:08 sdd -> ../devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/host6/target6:0:0/6:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Jun 26 09:08 zram0 -> ../devices/virtual/block/zram0 Synology sd list dummy@NAS:~$ ll /sys/block total 0 drwxr-xr-x 2 root root 0 Jun 26 11:00 . dr-xr-xr-x 12 root root 0 Jun 26 11:00 .. lrwxrwxrwx 1 root root 0 Jun 26 11:05 dm-0 -> ../devices/virtual/block/dm-0 lrwxrwxrwx 1 root root 0 Jun 26 11:05 dm-1 -> ../devices/virtual/block/dm-1 lrwxrwxrwx 1 root root 0 Jun 26 11:05 dm-2 -> ../devices/virtual/block/dm-2 lrwxrwxrwx 1 root root 0 Jun 26 11:05 dm-3 -> ../devices/virtual/block/dm-3 lrwxrwxrwx 1 root root 0 Jun 26 11:00 dm-4 -> ../devices/virtual/block/dm-4 lrwxrwxrwx 1 root root 0 Jun 26 11:00 dm-5 -> ../devices/virtual/block/dm-5 lrwxrwxrwx 1 root root 0 Jun 26 11:00 dm-6 -> ../devices/virtual/block/dm-6 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop0 -> ../devices/virtual/block/loop0 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop1 -> ../devices/virtual/block/loop1 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop2 -> ../devices/virtual/block/loop2 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop3 -> ../devices/virtual/block/loop3 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop4 -> ../devices/virtual/block/loop4 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop5 -> ../devices/virtual/block/loop5 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop6 -> ../devices/virtual/block/loop6 lrwxrwxrwx 1 root root 0 Jun 26 11:05 loop7 -> ../devices/virtual/block/loop7 lrwxrwxrwx 1 root root 0 Jun 26 11:00 md0 -> ../devices/virtual/block/md0 lrwxrwxrwx 1 root root 0 Jun 26 11:00 md1 -> ../devices/virtual/block/md1 lrwxrwxrwx 1 root root 0 Jun 26 11:00 md2 -> ../devices/virtual/block/md2 lrwxrwxrwx 1 root root 0 Jun 26 11:00 md3 -> ../devices/virtual/block/md3 lrwxrwxrwx 1 root root 0 Jun 26 11:00 md5 -> ../devices/virtual/block/md5 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram0 -> ../devices/virtual/block/ram0 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram1 -> ../devices/virtual/block/ram1 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram10 -> ../devices/virtual/block/ram10 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram11 -> ../devices/virtual/block/ram11 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram12 -> ../devices/virtual/block/ram12 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram13 -> ../devices/virtual/block/ram13 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram14 -> ../devices/virtual/block/ram14 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram15 -> ../devices/virtual/block/ram15 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram2 -> ../devices/virtual/block/ram2 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram3 -> ../devices/virtual/block/ram3 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram4 -> ../devices/virtual/block/ram4 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram5 -> ../devices/virtual/block/ram5 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram6 -> ../devices/virtual/block/ram6 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram7 -> ../devices/virtual/block/ram7 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram8 -> ../devices/virtual/block/ram8 lrwxrwxrwx 1 root root 0 Jun 26 11:05 ram9 -> ../devices/virtual/block/ram9 lrwxrwxrwx 1 root root 0 Jun 26 11:00 sda -> ../devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdb -> ../devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jun 26 11:00 sde -> ../devices/pci0000:00/0000:00:17.0/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdg -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host6/port-6:0/end_device-6:0/target6:0:0/6:0:0:0/block/sdg lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdh -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host6/port-6:1/end_device-6:1/target6:0:1/6:0:1:0/block/sdh lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdi -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host6/port-6:2/end_device-6:2/target6:0:2/6:0:2:0/block/sdi lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdj -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host6/port-6:3/end_device-6:3/target6:0:3/6:0:3:0/block/sdj lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdk -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host8/port-8:0/end_device-8:0/target8:0:0/8:0:0:0/block/sdk lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdl -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host8/port-8:1/end_device-8:1/target8:0:1/8:0:1:0/block/sdl lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdm -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host8/port-8:2/end_device-8:2/target8:0:2/8:0:2:0/block/sdm lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdn -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host8/port-8:3/end_device-8:3/target8:0:3/8:0:3:0/block/sdn lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdo -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host8/port-8:4/end_device-8:4/target8:0:4/8:0:4:0/block/sdo lrwxrwxrwx 1 root root 0 Jun 26 11:00 sdp -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host8/port-8:5/end_device-8:5/target8:0:5/8:0:5:0/block/sdp lrwxrwxrwx 1 root root 0 Jun 26 11:00 synoboot -> ../devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/host7/target7:0:0/7:0:0:0/block/synoboot lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram0 -> ../devices/virtual/block/zram0 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram1 -> ../devices/virtual/block/zram1 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram2 -> ../devices/virtual/block/zram2 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram3 -> ../devices/virtual/block/zram3 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram4 -> ../devices/virtual/block/zram4 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram5 -> ../devices/virtual/block/zram5 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram6 -> ../devices/virtual/block/zram6 lrwxrwxrwx 1 root root 0 Jun 26 11:00 zram7 -> ../devices/virtual/block/zram7 Ubuntu tryout sd list root@ubuntu:~# ll /sys/block total 0 drwxr-xr-x 2 root root 0 Jun 26 09:24 ./ dr-xr-xr-x 13 root root 0 Jun 26 09:24 ../ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop0 -> ../devices/virtual/block/loop0/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop1 -> ../devices/virtual/block/loop1/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop2 -> ../devices/virtual/block/loop2/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop3 -> ../devices/virtual/block/loop3/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop4 -> ../devices/virtual/block/loop4/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop5 -> ../devices/virtual/block/loop5/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop6 -> ../devices/virtual/block/loop6/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 loop7 -> ../devices/virtual/block/loop7/ lrwxrwxrwx 1 root root 0 Jun 26 09:25 loop8 -> ../devices/virtual/block/loop8/ lrwxrwxrwx 1 root root 0 Jun 26 09:27 loop9 -> ../devices/virtual/block/loop9/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sda -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host0/port-0:0/end_device-0:0/target0:0:0/0:0:0:0/block/sda/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdb -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host0/port-0:1/end_device-0:1/target0:0:1/0:0:1:0/block/sdb/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdc -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host0/port-0:2/end_device-0:2/target0:0:2/0:0:2:0/block/sdc/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdd -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host0/port-0:3/end_device-0:3/target0:0:3/0:0:3:0/block/sdd/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sde -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host7/port-7:0/end_device-7:0/target7:0:0/7:0:0:0/block/sde/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdf -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host7/port-7:1/end_device-7:1/target7:0:1/7:0:1:0/block/sdf/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdg -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host7/port-7:2/end_device-7:2/target7:0:2/7:0:2:0/block/sdg/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdh -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host7/port-7:3/end_device-7:3/target7:0:3/7:0:3:0/block/sdh/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdi -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host7/port-7:4/end_device-7:4/target7:0:4/7:0:4:0/block/sdi/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdj -> ../devices/pci0000:00/0000:00:1b.4/0000:04:00.0/host7/port-7:5/end_device-7:5/target7:0:5/7:0:5:0/block/sdj/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdk -> ../devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/host8/target8:0:0/8:0:0:0/block/sdk/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdl -> ../devices/pci0000:00/0000:00:17.0/ata1/host1/target1:0:0/1:0:0:0/block/sdl/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdm -> ../devices/pci0000:00/0000:00:17.0/ata2/host2/target2:0:0/2:0:0:0/block/sdm/ lrwxrwxrwx 1 root root 0 Jun 26 09:24 sdn -> ../devices/pci0000:00/0000:00:17.0/ata5/host5/target5:0:0/5:0:0:0/block/sdn/ I would appreciate any hints Quote Link to comment Share on other sites More sharing options...
IG-88 Posted June 30 Share #2 Posted June 30 7 minutes ago, smileyworld said: "usbportcfg" : "0xc000000", "internalportcfg" : "0x3fffff", in theory there should be one zero less in usbportcfg 0xc00000 0x3fffff the 3 and the c shold be on the same position but i dont think that causes a problem here maybe you try to do the same with 3617 (broadwell-7.1.0-42661) Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 1 Author Share #3 Posted July 1 @IG-88Thanks for correcting my mistake. Nonetheless, when I try it with the DS3617xs loader the outcome unfortunately still the same. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 2 Share #4 Posted July 2 It seems to be right to have a list of 14 disks from the beginning and compare them from there. First install the scsi driver below on TC linux tce-load -iw scsi-5.10.3-tinycore64.tcz Please upload only the disk list again with the command below. ll /sys/block | grep ata Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 2 Author Share #5 Posted July 2 @Peter SuhLooks like only drives in slot 11-13 are recognised by tc even though the scsi-5.10.3-tinycore64.tcz was saved and I got an OK message. lrwxrwxrwx 1 root root 0 Jul 2 03:52 sda -> ../devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jul 2 03:52 sdb -> ../devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jul 2 03:52 sdc -> ../devices/pci0000:00/0000:00:17.0/ata5/host4/target4:0:0/4:0:0:0/block/sdc Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 2 Share #6 Posted July 2 @Peter SuhLooks like only drives in slot 11-13 are recognised by tc even though the scsi-5.10.3-tinycore64.tcz was saved and I got an OK message. lrwxrwxrwx 1 root root 0 Jul 2 03:52 sda -> ../devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sdalrwxrwxrwx 1 root root 0 Jul 2 03:52 sdb -> ../devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sdblrwxrwxrwx 1 root root 0 Jul 2 03:52 sdc -> ../devices/pci0000:00/0000:00:17.0/ata5/host4/target4:0:0/4:0:0:0/block/sdc As I mentioned last time, I use the same HBA. I think the disks were all listed up when I used that scasi driver. I will let you know after doing the same test. Did you check /sys/block on junior with me and PM? This is actually the most important point.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 2 Share #7 Posted July 2 1 hour ago, Peter Suh said: As I mentioned last time, I use the same HBA. I think the disks were all listed up when I used that scasi driver. I will let you know after doing the same test. Did you check /sys/block on junior with me and PM? This is actually the most important point. Sent from my iPhone using Tapatalk The grep filter I gave you is wrong. Try changing it to target as shown below. I also installed 7 disks in HBA2, but there was a problem that 1 was not visible. action is being taken ll /sys/block | grep target tc@box:~$ ll /sys/block | grep target lrwxrwxrwx 1 root root 0 Jul 2 08:16 sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdc -> ../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdd -> ../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Jul 2 08:16 sde -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdf -> ../devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0/5:0:0:0/block/sdf lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdg -> ../devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/host6/target6:0:0/6:0:0:0/block/sdg lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdh -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:0/end_device-7:0/target7:0:0/7:0:0:0/block/sdh lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdi -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:1/end_device-7:1/target7:0:1/7:0:1:0/block/sdi lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdj -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:2/end_device-7:2/target7:0:2/7:0:2:0/block/sdj lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdk -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:3/end_device-7:3/target7:0:3/7:0:3:0/block/sdk lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdl -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:4/end_device-7:4/target7:0:4/7:0:4:0/block/sdl lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdm -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:5/end_device-7:5/target7:0:5/7:0:5:0/block/sdm Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 2 Share #8 Posted July 2 (edited) This is my case. 1-6 are internal Sata Port (6 port) 7-14 are connected to HBA 1 (8 port) 15-22 are connected to HBA 2 (8 port) I have 1 PCIx16 Slot and 2 PCIx4 Slots on my mainboard First one is used for HBA2 Second one is empty ( PCIx16 ) Third one is used for HBA1 Currently the slots below are occupied: 1-3 = 3 SSDs & HDDs 7-9 = 3 HDDs 15-21 = 7 HDDs = 13 drives in total. But, In HBA2 only one Disk is disapear, same as you. This is my Mobo bios , HBA bios and TC linux screen shot. Edited July 2 by Peter Suh Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 2 Author Share #9 Posted July 2 14 hours ago, Peter Suh said: As I mentioned last time, I use the same HBA. I think the disks were all listed up when I used that scasi driver. I will let you know after doing the same test. Did you check /sys/block on junior with me and PM? This is actually the most important point. Sent from my iPhone using Tapatalk Yes that was me and I checked it. 13 hours ago, Peter Suh said: The grep filter I gave you is wrong. Try changing it to target as shown below. I also installed 7 disks in HBA2, but there was a problem that 1 was not visible. action is being taken ll /sys/block | grep target tc@box:~$ ll /sys/block | grep target lrwxrwxrwx 1 root root 0 Jul 2 08:16 sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdc -> ../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdd -> ../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Jul 2 08:16 sde -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdf -> ../devices/pci0000:00/0000:00:1f.2/ata6/host5/target5:0:0/5:0:0:0/block/sdf lrwxrwxrwx 1 root root 0 Jul 2 08:16 sdg -> ../devices/pci0000:00/0000:00:14.0/usb3/3-3/3-3:1.0/host6/target6:0:0/6:0:0:0/block/sdg lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdh -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:0/end_device-7:0/target7:0:0/7:0:0:0/block/sdh lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdi -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:1/end_device-7:1/target7:0:1/7:0:1:0/block/sdi lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdj -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:2/end_device-7:2/target7:0:2/7:0:2:0/block/sdj lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdk -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:3/end_device-7:3/target7:0:3/7:0:3:0/block/sdk lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdl -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:4/end_device-7:4/target7:0:4/7:0:4:0/block/sdl lrwxrwxrwx 1 root root 0 Jul 2 08:17 sdm -> ../devices/pci0000:00/0000:00:01.1/0000:02:00.0/host7/port-7:5/end_device-7:5/target7:0:5/7:0:5:0/block/sdm I will report back tomorrow. Maybe I found something which would explain the behavior, but I want to double check first. Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 4 Author Share #10 Posted July 4 @Peter Suh I am not so sure anymore that it has solely to do with tcrp or DSM7. I tried plugging in 22 drives and even in mint only 20 are recognized. Maybe there is also an issue with the HBA or a cable. I also saw during boot that there my two HBAs are on different BIOSes. My plan is to identify the missing drives first and then changing the drives to different slots, so I can be sure all drives are ok. Next thing will be to upgrade firmware of my HBAs. If that doesnt help, than i really dont know where to look even further. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 5 Share #11 Posted July 5 (edited) I am also perplexed as I first discovered this issue in the SAS2008 IT Mode firmware. I think we should do a search on the internet to see if this issue originally existed. I also have a Dell Perc H200, with the same firmware and The same phenomenon occurs when drives disappear one by one. I'll have to double-check all the firmware versions currently being applied. Currently, only legacy firmware is applied and used. I'm thinking of trying to change to EFI firmware. Edited July 5 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 5 Share #12 Posted July 5 I found one case where 4 out of 8 disks disappeared. https://www.truenas.com/community/threads/lsi-sas2008-only-shows-4-disks-instead-of-8.97462/ Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 5 Author Share #13 Posted July 5 There also seems to be a known issue with duplicate drives which is documented even by broadcom itself. Interestingly this is also a bad firmware problem. https://www.broadcom.com/support/knowledgebase/1211161495925/flash-upgrading-firmware-on-lsi-sas-hbas-upgraded-firmware-on-92 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 5 Share #14 Posted July 5 7 hours ago, smileyworld said: There also seems to be a known issue with duplicate drives which is documented even by broadcom itself. Interestingly this is also a bad firmware problem. https://www.broadcom.com/support/knowledgebase/1211161495925/flash-upgrading-firmware-on-lsi-sas-hbas-upgraded-firmware-on-92 However, this solution seems to have been shared too long ago. The latest revision is already up to P20. Problems solved in P9 are likely to be included in P20 as well. Perhaps you too will use the P19 or P20 revision. If you enter the SAS BIOS by pressing CTRL+C, it is the first number in the FW revision item. Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 5 Author Share #15 Posted July 5 (edited) @Peter Suh Yes that's true. It looks like it's a firmware issue after all. I connected my NAS to a display and was wondering why only one of the HBAs was displaying in BIOS (ctrl +c). Now 2 hours later I learned that I have 2 different controller cards even though they were sold both as LSI 9211-8i (IT-mode). It seems there was so much rebranding and the companies used same or similar chips (sas2008) but different BIOSes. At least someone mentioned this here -------------------------------------------------------------------------------------------- -------------------------------------------------------------------------------------------- MegaRAID is however able to see both HBAs and collects the following data from both cards. I thought it would make troubleshooting easier when I simplify things (install same Firmware/BIOS) but oh boy it keeps getting more and more complex HBA SGX-SAS6-INT-Z has BIOS version 07.39.02.00_07.24.01.00 is working but I cannot enter the BIOS at all It wont let me "update" the BIOS with 07.39.02.00 probably because downgrading firmware is not allowed windows server 2016 cant find a suitable driver for this card HBA SAS9211-8i has BIOS version 07.39.02.00 has a working BIOS which I can enter with Ctrl + C. windows server 2016 installs the best driver for this card on its own. So at this point I do not know where to find either a firmware newer than 07.39.02.00_07.24.01.00 with a working BIOS or a way to downgrade the SGX-SAS6-INT-Z HBA to 07.39.02.00. Furthermore I am not sure if this would fix my/our problem. Do both of your HBAs have the same BIOS version? Edited July 5 by smileyworld Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted July 6 Share #16 Posted July 6 To be precise, I have a total of 4 HBAs. Two of them are Dell Perc H310 1 x Dell Perc H200 The last one is the 9211-4i for 4 ports. The HBA used in this test was One Dell Perc H310 and one Dell Perc H200. I tried to install 7-8 disks in H310. Bios version and firmware revision seem to be managed as separate versions. As you can see in the picture, my version of Bios is v7.39.02.00. The target that needs to be updated is not the Bios version. It's like a FW revision. This firmware revision was mentioned as P7, P8, P9, P19, P20, etc. Among them, it seems that I am already using the P20. As you can see in the picture, both HBA cards are using the same IT mode FW revision. This FW revision can be freely changed, However, to change it, it seems to apply the desired FW revision after using the P7 first. This part seems to be in the Broadcom guide you linked above. If the FW revision of the two cards is different, will the issue disappear? Quote Link to comment Share on other sites More sharing options...
smileyworld Posted July 9 Author Share #17 Posted July 9 I can finally report that I fixed it. What I did to resolve my issue tried to determine if it is a hardware/software failure connected 8 disks to 1 HBA (HBA2 was not installed at that time) and checked if every disk was listed (computer management in windows server 2016, another OS would probably work as well) unplugged HBA1 and connected HBA2 -> also checked if 8 disks were listed -> one disk was missing, so I checked all connectors and one was loose. flashed firmware of my second HBA. connected both HBAs, installed 22 disks and all were listed in WIN server 2016 unplugged my X540-T2 10Gbit NIC installed Xpenology as follows ran command by command ./rploader.sh clean ./rploader.sh update ./rploader.sh fullupgrade ./rploader.sh identifyusb ./rploader.sh serialgen DS3622xs+ vi user_config.json adapted my user_config.json to my environment { "extra_cmdline": { "pid": "0x1000", "vid": "0x090c", "sn": "xxxxxxxxxxxxx", "mac1": "xxxxxxxxxxxxx", "mac2": "xxxxxxxxxxxxx", "mac3": "xxxxxxxxxxxxx", "SataPortMap": "", "DiskIdxMap": "" }, "synoinfo": { "esataportcfg" : "0x00", "usbportcfg" : "0xc00000", "internalportcfg" : "0x3fffff", "maxdisks": "22", "support_bde_internal_10g": "no", "support_disk_compatibility": "no", "support_memory_compatibility": "no" }, "ramdisk_copy": {} ran these commands to finish the tcrp loader ./rploader.sh build broadwellnk-7.1.0-42661 ./rploader.sh backup ./rploader.sh backuploader exitcheck.sh reboot plugged my x540 in connected my LAN cable to one of the LAN ports booted from USB and installed the appropriate DSM_DS3622xs+_42661.pat Special thanks to @Peter Suh @IG-88 @flyride for your support. 1 Quote Link to comment Share on other sites More sharing options...
