KeithNet Posted June 26 Share #1 Posted June 26 On 6/15/2022 at 7:43 PM, aerolite said: 1, install a brand new DSM 7.x with this instruction. 2, backup the data for my old DSM 6.x and shut it down 3, passthrough my LSI-9211-8i to new DSM 7.x and follow web interface to finish the migration. I tried this. I'm able to get my new DSM 7.x install up. My drives don't show up when I passthrough my LSI2008. Any suggestions? Quote Link to comment Share on other sites More sharing options...
aerolite Posted June 26 Share #2 Posted June 26 try re-run "/rploader.sh build broadwellnk-7.1.0-42661" the LSI2008 driver might not installed. Quote Link to comment Share on other sites More sharing options...
KeithNet Posted June 27 Author Share #3 Posted June 27 15 hours ago, aerolite said: try re-run "/rploader.sh build broadwellnk-7.1.0-42661" the LSI2008 driver might not installed. Thank you for the suggestion. I rebooted and rebuilt the loader. No change. -Keith Quote Link to comment Share on other sites More sharing options...
KeithNet Posted June 27 Author Share #4 Posted June 27 To be clear, this in ESXi 6.7 Quote Link to comment Share on other sites More sharing options...
aerolite Posted June 27 Share #5 Posted June 27 5 hours ago, KeithNet said: Thank you for the suggestion. I rebooted and rebuilt the loader. No change. -Keith That's all I did and it works for me. Quote Link to comment Share on other sites More sharing options...
smileyworld Posted June 27 Share #6 Posted June 27 I face a similar problem however my setup is a bit different. VM or BareMetal : BareMetal Hardware (Motherboard/CPU) : MSI MPG Z390 / Intel 9900T Storage-Controller: 2x LSI SAS 9211-8i (HBA in IT mode) Hot Plug/Hot Swap Applied : Yes Network Interface 1 : Intel i217v (e1000e Not working for me in xpenology) Network Interface 2 : Intel X540-T2 (10 Gbit) Network Interface 3 : Intel X540-T2 (10 Gbit) version of rploader.sh : 0.8.3 Platform (DS3622xsp/DS918+/DS920+/DVA3221/DS1621+/DS3615xs/DS3617xs) : 3622xs+ Platform Version (6.2.4/7.0.1/7.1) : 7.1 Platform Revision (42218/42661/42661-U1) : 42661 GRUB Boot selection : USB Current Status : Boots to kernel Both of my LSI SAS 9211 are recognised but I cant add more than 13 drives. As soon as I add the 14th drive to one of my SAS controllers another HDD/SDD isn't recognised any more. I tried editing the user.conf according to this tutorial (this worked for me in DSM 6) but DSM7 keeps behaving weird. Quote Link to comment Share on other sites More sharing options...
KeithNet Posted July 2 Author Share #7 Posted July 2 On 6/27/2022 at 2:02 PM, aerolite said: That's all I did and it works for me. What version of the loader and DSM? Quote Link to comment Share on other sites More sharing options...
flyride Posted July 2 Share #8 Posted July 2 On 6/27/2022 at 1:13 PM, smileyworld said: I tried editing the user.conf according to this tutorial (this worked for me in DSM 6) but DSM7 keeps behaving weird. You must make your changes in user_config.json in TinyCore. It patches on each boot so if you edit DSM's files directly, they will be overwritten. Quote Link to comment Share on other sites More sharing options...
aerolite Posted July 3 Share #9 Posted July 3 17 hours ago, KeithNet said: What version of the loader and DSM? I use ESX7 with latest loader on DSM 7.1-42661 Quote Link to comment Share on other sites More sharing options...
KeithNet Posted July 4 Author Share #10 Posted July 4 This did the trick for me: I'm all set! Quote Link to comment Share on other sites More sharing options...
