Tinycore-Redpill DSM 7.1 ACPI Power Button question
Thank to pocopico's effort, I can install DSM 7.1 42661 on the ASRock Q1900B-ITX.
However, I find that I am not able to use the power button to shutdown the NAS.
Here is my code
sudo ./rploader.sh update && \
sudo ./rploader.sh fullupgrade && \
sudo ./rploader.sh identifyusb && \
sudo ./rploader.sh serialgen DS918+ && \
sudo ./rploader.sh satamap && \
sudo ./rploader.sh ext apollolake-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json && \
sudo ./rploader.sh build apollolake-7.1.0-42661 && \
sudo ./rploader.sh clean now && \
sudo rm -rf /home/tc/oldpat.tar.gz && \
sudo rm -rf /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles && \
sudo rm -rf /home/tc/custom-module && \
sudo ./rploader.sh backup now
After the backup, I unplug my router WAN. Then I can install DSM 7.1 using the official installation file DSM_DS918+_42661.pat
Do my step wrong or DSM 7.1 do not allow power button to poweroff the NAS?
Try your commands without "sudo" its not needed anymore for the build process:
Also, why are you doing a clean command after the build?
Are you getting any errors during the build?
I'm assuming this is a new build so try doing these commands:
[DS918+]
./rploader.sh listmods apollolake-7.1.0-42661 (to see what modules you need and add them)
exitcheck.sh reboot
I have never had an issue building a DS918+ with these commands..
Yes I can turn off with the power button. Granted my hardware is a little different than yours, but you should be able to use your power button.
These are the specs of my build:
Gigabyte B365M DS3H
Intel Core i7 9700
16gb DDR4 2666
RealTek RTL8125 dual port NIC
4 Seagate 4TB IronWolf Pro hard drives
I know its a little overkill, but initially built it for TrueNAS and had 32gb of memory.
Problem solved. I reboot the NAS and I can now shutdown by power button.
./rploader.sh update now && \
./rploader.sh fullupgrade now && \
./rploader.sh backup now && \
./rploader.sh identifyusb now && \
./rploader.sh satamap now && \
./rploader.sh ext apollolake-7.1.0-42661 add \
https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json && \
